Shingles Sealing?
Old 11-15-2009, 10:15 AM   #1
Coastalbuilders's Avatar
Shingles Sealing?
We've put on my roofs but I had my own home roofed by my best crew 1 week ago with a 30 year laminted shingle but noticed that the roof has not layed flat yet. I never noticed this as much doing other peoples roofs because I don't usually go back and check and have not had any complaints. My question is how long does it take for the shingles to lay flat and seal with the cooler temperatures that we are having here in the south.
Coastalbuilders is offline
Old 11-15-2009, 02:34 PM   #2
2ndGen's Avatar
Trade: Thoroughbred Roofer
Re: Shingles Sealing?
In Texas? Most of those shingles should be down after a couple of 80 degree days. Even if it's not "that" hot, the sun will help warm them up (surface temps) a lot.
Don't know what your pitch is, but on a lower slope roof the shingles will stand out more noticeably.
I wouldn't stress it. Even if it takes a couple of weeks. If your customers didn't give you any complaints, then you shouldn't worry either.
Hey, if you have any problems, at least you know where The Contractor lives!
"I've been up on the roof. I know what those guys go through.
My whole life has been about making that profession respectable
Ken Hendricks
www.SolutionsRoofing.com
2ndGen is offline
Old 11-15-2009, 08:09 PM   #3
kubie's Avatar
Trade: general contractor
ya around here HO always ask if the will lay down. every time....should start charging for the same answer. lol
we did a few roofs and told the HO that the shingles should lay down around june.
but i have had roofs seal in 30 degrees and sunny before, so i wouldnt say it would take weeks to seal down, but ya never know
kubie is online now
Old 11-16-2009, 07:47 AM   #4
Bah Humbug!
Grumpy's Avatar
Were the shingles stored over the ridge? That'll do it. A couple of warm days fixes most of these laying flat issues, unless the shingles were abused.
Grumpy is offline
Old 11-24-2009, 08:31 PM   #5
Tile roof and PV systems
Joe Roofer's Avatar
Trade: Roofer
Bent bundles need to sit flat on the deck in the sun to "iron them out" for best application. If it was applied cold they will tighten up some in the heat. Nailed on at 110F with a big fish mouth and it probably will not go away.
Joe Roofer is offline
Old 11-29-2009, 04:59 PM   #6
robert's Avatar
Trade: roofing contractor
Really depends if theres a lot of shade and who installed the roof if the shingles were buckeled when installed they may take a very long time to smooth out,but from what im reading you just installed it so give it time its cool this time of year
robert is offline
Tips/Tricks for removing shingles Jambruins Roofing 34 04-30-2010 11:23 AM
Maibec Shingles Staining Problem KWVILLA General Discussion 5 09-12-2009 12:53 AM
Stripping shingles off of ice guard manland2319 Roofing 15 09-09-2009 12:19 PM
Questions about Hardie Shingles Shocker00 Windows, Siding and Doors 17 08-26-2009 09:29 PM
Metal Roof OVER shingles? MHMConstruction Roofing 9 12-22-2008 10:14 AM
