Shingles On Low Pitched Roof?
Old 07-25-2007, 10:58 AM   #1
Can't Post
sandyman720's Avatar
Trade: Construction
My shed type roof for my addition will have a 2.6 slope. Will shingles be ok for this? Does code say anything about this?
sandyman720 is offline
Old 07-25-2007, 11:37 AM   #2
reveivl's Avatar
Trade: Renovations
Re: Shingles On Low Pitched Roof?
Some manufacturers allow down to 2:12, you have to double up on the felt underneath.
reveivl is offline
Old 07-25-2007, 12:40 PM   #3
tinner666's Avatar
Sa modified bitimin roof would be better. If you're determined to do shingles, use Dimensionals, shorter exposure, and LAP them 4-6", side to side. NO Butt joints.
These are Elks at 4" exposure, lapped 4-6" on a 2.5/12.
http://www.rooferscoffeeshop.com/sho...&file=1976&s=0
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 07-25-2007, 06:40 PM   #4
3rd gen,it's in the blood
roofwiz74's Avatar
Trade: roofing
my god who ridged it?
what's that black on the chimney?uncured?don't laugh I've seen it.
personally if it's a low slope,use low slope materials.whole crap load out there.
You have ONE advantage over me.....you can kiss my butt and I can't!!
roofwiz74 is offline
Old 07-25-2007, 06:57 PM   #5
Bah Humbug!
Grumpy's Avatar
Rather than shortening exposures or double felt, I just prefer to ice shield the whole damned thing. However Mod bit would be better.
I used to shorten exposures until it was excplained to me that actually I was doing more harm than good since seal strips are supposed to line up... At least that's what the rep said. But Ice shield it and forget it.
Grumpy is offline
Old 07-25-2007, 09:08 PM   #6
RooferJim's Avatar
Trade: roofing
Shortening the exposures makes them much more likley to blow off and is against manufactures specs. doubleing felt is what they did 30 years ago before ice and water shield was invented. either full coverage I&W or treat it as a flat roof.
RooferJim
www.jbennetteroofing.com
RooferJim is offline
Old 07-25-2007, 09:24 PM   #7
tinner666's Avatar
Those TImbertex look rough alright. Not to mention a few framing zigs and zags. Owner/GC has rebuilt this houe several times. Had Mod-bit on low area before. Then, 2 changes later, this is where we are for the next 2-5 years.
That's aluminum on the chimney.
Old 07-25-2007, 09:27 PM   #8
tinner666's Avatar
I forgot to mention the 3/8-7/16" plywood. Get betwwen rafters and less than 12" strips, and the ridge work becomes problamatic. It was cobra vent too.
Old 07-25-2007, 09:31 PM   #9
roofwiz74's Avatar
Trade: roofing
i was talking about the 3" exposeure on one ridge cap,then 5 on the next.more than one in the pic too.sry,tinner it popped out.years of being a warranty man.
Old 07-25-2007, 09:42 PM   #10
tinner666's Avatar
You're right! Not sure what that was about. 2 of us were there. It could have had something to do with trying to get them staggered into existing. No clue at this point in time. Not sure If I screwed that or my brother!
Looks like something wrong though.
The GC even had a weird area that the plywood stopped really short on an eave. His boys added a dripedge later after doubling the fascia in that spot. I get a call about a leak. DE is sitting flat on fascia and water hitting the edge of it ran into soffit.
His crew wasn't the easiest to follow behind.
Old 07-25-2007, 09:47 PM   #11
roofwiz74's Avatar
Trade: roofing
i hear you my friend.wasn't picking just pointing out.I would post pics of my work but I'm afraid.
Old 07-25-2007, 09:52 PM   #12
tinner666's Avatar
I'm not upset. Need a little humble pie at times.
Old 07-25-2007, 11:26 PM   #13
dougger222's Avatar
Trade: Roofing Contractor
I've got 8sq's of 2.5/12 comming up and after torching down 4sq's today on a garage I don't feel like torching for a while.
Going to install Winterguard on the whole thing and will run Landmark 30's with a 8-10in offset with a the normal 5 5/8th exposure. Has a 4ftx4ft stone chimney which will need new flashing and a cricket built, and were going to add a half dozen air vents so shingles will be much easier on the roof than torch down. State Farm job so the money will be good just want to make sure the city inspector will pass the roof with shingles before I do it.
dougger222 is offline
Old 07-29-2007, 11:43 PM   #14
Expert Roofer
theroofinggod's Avatar
Trade: ROOFING/HOME IMPROVEMENTS-WINDOWS/SIDING/GUTTERING/COPPER WORK,ETC
Send a message via MSN to theroofinggod Send a message via Yahoo to theroofinggod
red the wrapper,dougger-should be okay
theroofinggod is offline
Old 07-30-2007, 12:30 AM   #15
liltrainerboy's Avatar
Trade: Siding & remodeling
i put ****ty 20 shangles 8 years ago... or had it done ( before i got into roofing) and they should last another 8 at least in chicago.... never had a probb
liltrainerboy is offline
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 09:10 AM
Owens corning a solid strip of tar nolo Roofing 26 01-29-2008 01:25 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
