Shingle Selection - Timberline, Duration, Oakridge Or Landmark
Old 02-15-2012, 12:00 AM   #1
Nick_M's Avatar
Hello All,
I am new to this forum and this is my first post so go easy on me!
I am building my house in southeastern WI and need some advice on shingles. The roofer I am using has come back and said that he can use any of the following shingles for almost the same price:
GAF Timberline HD
Owens Corning Duration
Owens Corning Oakridge
Certainteed Landmark
The house is a 3000sqft 2 story colonial with roof pitches that are mostly either 8/12 and 12/12. The color will most likely be something like the Landmark's Weathered Wood. The crystal ball tells me that I will be in this house for 15 years.
Given the above info, which would be the best overall choice? Also, how would you rank them for durability and looks.
Thanks in advance for taking the time to review this post and respond to it.
Nick
Nick_M is offline
Old 02-15-2012, 03:10 AM   #2
erniesgutter's Avatar
Trade: Roofing Vinyl Siding Rain Gutter Vinyl Windows
Rewards Points: 29
Re: Shingle Selection - Timberline, Duration, Oakridge Or Landmark
in my opinion I would go with the GAF products they have the best and easiest guarantee when it comes to a replacement ... We have used them all it all come back to time and aggravation...
Ernie Ruiz
VISIT OUR SITE:http://erniesgutter.com [B] VISIT OUR BLOG: http://erniesgutter.com/blog
erniesgutter is offline
Old 02-15-2012, 05:46 AM   #3
PRO
BrandConst's Avatar
Rewards Points: 1,000
Originally Posted by Nick_M View Post
Hello All,
GAF Timberline HD
Nick
Buddy, your going to get a million different opinions here. All shingles you mentioned are of great quality and any would work great on your home but I'm a certain teed guy
BrandConst is offline
Old 02-15-2012, 07:08 AM   #4
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
Well, I am in southeastern WI and I prefer the CertainTeed Landmarks. What type of extended warranties is this roofer giving you?
I would stay away from the OC line, at least around here.
BamBamm5144 is offline
Old 02-15-2012, 07:22 AM   #5
welterweight's Avatar
Trade: sales
why would you suggest staying away from the OC line ?
welterweight is offline
Old 02-15-2012, 07:27 AM   #6
General Contractor
greg24k's Avatar
Rewards Points: 7,360
Just did a house using Owens Corning Duration
greg24k is offline
Old 02-15-2012, 07:35 AM   #7
apkole's Avatar
Trade: Residential roofing contractor
Rewards Points: 186
Greg,
Did OC change the profile of the seal strip/nail line area on the Duration? The Durations I looked at last year still had that area indented and I've been finding that it was holding water and rusting nail heads on the lower pitch roofs (4/12 - 8/12). I haven't looked at them in awhile though.
OP, I happen to be pretty convinced of the performance and value in the Certainteed Landmark. Check the rating in the nationally distributed consumer mag. Take a look at the Pro series Landmark. Has a great SureStart warranty features and extended algae resistant period. A little heavier (250 lb/sq) and (I think) richer colors. For not much more money.
Not impressed with OC or GAF, just my .02.
apkole is offline
Old 02-15-2012, 07:49 AM   #8
Trade: sales
OC originally had a continuous adhesive and that ( at times ) causesd concern regarding the possibility of trapping moisture. OC redesigned their duration shingle, upgraded it by adding a reinforced fabric to their sure nail technology and also putting slots in the adhesive so moisture could drain if need be. OC also has about double the advesive as gaf or certainteed although they are both good shingles. i just think OC is a great shingle..
Old 02-15-2012, 09:32 AM   #9
Nick_M's Avatar
Not that I have decided to go the OC route, but if I did, which would be a better choice for the same money - Duration or Oakridge. Duration seems like a more premium shingle, but the oakridge was rated much higher by Consumer Reports back in June-2009. I did notice on the OC website that the TruDefinition Duration shingles say "New" on them and from some of the posts, it sounds like they may have been redesigned. Would that now put the Duration ahead of the Oakridge if CR redid their testing?
Nick_M is offline
Old 02-15-2012, 09:38 AM   #10
If you're basing off consumer reports you should be going with the landmarks.
Old 02-15-2012, 09:55 AM   #11
Nick_M's Avatar
I am not basing my decision strictly on CR, otherwise I wouldn't be asking you fine people your opinions. CR doesn't live & breathe this stuff day in and day out like many of you do. Thus, I highly value your opinions as well. It is interesting though that if my decision was based off of CR than you indicated my choice should be Landmark. However, the Oakridge is rated higher than the Landmark?
Nick_M is offline
Old 02-15-2012, 10:14 AM   #12
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Rewards Points: 1,772
What does your contractor prefer. If they don't have a preference, they are not roofers.
I'm surprised this thread is still open.....
MJW is offline
Old 02-15-2012, 10:26 AM   #13
Me too.
Where is this job located? Sounds like the guy doing it isn't an actual roofer since they don't have a preference. Every roofer I know has preferences.
Old 02-15-2012, 10:51 AM   #14
Trade: sales
Bamm
you never said why you do t like OC ?
also sounds like the OP is using a handyman who will do a chop job install for a cheap price.. i will gladly take the job when the roof needs ro be redone in a few years.
Old 02-15-2012, 11:44 AM   #15
Originally Posted by welterweight View Post
Bamm
I laid a lot of the oakridge last year and I didn't like how the laid, nailed and the amount of granules that came out of the package.
Old 02-15-2012, 12:52 PM   #16
Nick_M's Avatar
Let me clarify. The roofer typically uses Landmark but recently did a job with Timerline and liked it. I basically asked what shingles are available in the same price range and those were the 4 provided. This is a reputable roofer but I just wanted to know my options so that I could do the research and come up with an independent decision and not be completely biased to just what they typically use. We all know that contractors dont always look out for the best interest of the consumer and I am jus doing my due dilegence. Hope that makes sense.
Nick_M is offline
Old 02-15-2012, 01:01 PM   #17
Trade: sales
Bamm
the oak ridge is OC 's lower grade shingle.. the new Duration is much better..
Old 02-15-2012, 01:14 PM   #18
MJW's Avatar
Where are the mods? This is a homeowner question.
MJW is offline
Old 02-15-2012, 01:16 PM   #19
Bamm
I might have a job coming up installing them.
Old 02-15-2012, 01:26 PM   #20
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,063
The guys are correct; this is a homeowner question rather than peer-to-peer consulting.
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Tinstaafl is online now
GAF Elk Timberline: Are you using the updated January 2011 Instructions? JonDesignBuild Roofing 27 11-07-2011 05:58 AM
CertainTeed Roofing Updates Exclusive Shingle Applicator's Manual (SAM 10) for Roofin Grumpy Roofing 0 04-27-2011 10:01 PM
OC Duration Shingles marsat Roofing 5 03-03-2011 08:48 AM
Granule loss on Landmark shingle MEL Roofing 25 05-25-2010 01:44 PM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
