Seal Gable Vents After Ridge Vent Installed?
Old 09-09-2007, 09:09 PM   #21
dennis's Avatar
Trade: Roofing
Rewards Points: 150
Re: Seal Gable Vents After Ridge Vent Installed?
reveivl, my thoughts exactly.
http://roofersreview.com/htmlpage2( my page on the subject )
Ed,
I would prefer not to put too much emphasis on anecdotal evidence posted on forums or otherwise. You never know the exact circumstances. Was the vent installed or designed properly? Was the story related by a friend of a friend? etc. I can understand rare circumstances, say when fine dry snow for example, blows through a vent under heavy winds. But i don't think it's the norm.
As for no ventilation, I think it's possible. Depends on a lot of variables though.
Still readin.
dennis is offline
Old 09-09-2007, 11:25 PM   #22
Expert Roofer
theroofinggod's Avatar
Trade: ROOFING/HOME IMPROVEMENTS-WINDOWS/SIDING/GUTTERING/COPPER WORK,ETC
Rewards Points: 250
Send a message via MSN to theroofinggod Send a message via Yahoo to theroofinggod
actually the canadian topic I read from the ministry study is more to your line of thinking Dennis--they feel that sealing the attic from the home heating area is more important-a friend gave it to me ,I`ll see if I can get the link to e-mail you a copy
theroofinggod is offline
Old 01-16-2008, 05:47 PM   #23
Ed the Roofer's Avatar
Trade: Roofing Contractor
Rewards Points: 2,054
Dennis,
I found theat Hinrichs, 1962 document you were looking for.
http://www.osti.gov/bridge/servlets/...e/10186298.PDF
Ed
Ed the Roofer is offline
Old 01-17-2008, 08:51 PM   #24
dennis's Avatar
Trade: Roofing
Rewards Points: 150
Ed, thanks. But I've already got that one.
The one I was looking for was the original Hinrichs study. I found it after a bit of searching.
dennis is offline
Old 01-17-2008, 11:42 PM   #25
I posted that link before I thoroughly read it, but it was too late.
Can you share the original 1962 Hinrichs with me, either in a post or via e-mail?
Thanks,
Ed
Old 01-18-2008, 09:12 PM   #26
dennis's Avatar
Trade: Roofing
Rewards Points: 150
Ed, I scanned it and have it as a pdf, but the file is too large to upload here.
Send me your email and I will pass it along.
dennis is offline
Old 01-18-2008, 10:50 PM   #27
Thanks Dennis.
Message sent to you.
Ed
Old 04-23-2012, 08:45 PM   #28
joshf77's Avatar
Trade: General contractor/Roofing specialist
Thumbs up
Heres the ticket... there is a scientific formula for calculating the proper attic ventillation. In most states, local codes are now requiring that you have a 300 to 1 ratio for your attic venting. Check with your local building code to see if this applies to you. Most manufacturers of roofing products will void their warranties if this is not met. Here is the formula Sq. Footage of roof i.e (using a round number)
1000 square feet of roof....... 1000/300=3.33333. then take that number and multiply it by 144 putting it in square inches. 3.33333x144=479.99999. now divide that by 2. this will give you the exhaust amount and the intake amount. in this case would be, 239.999 (just round up) to 240 for exhaust and 240 for intake.
Ridge vent typically equals 11 sq in. per foot
soffit vents =24 sq in.
box vents=50 sq in.
so for this case you would just divide your final number for the top by 11 and the bottom by 24.
240/11=22 ft of ridge vent
240/24=10 soffit vents.
Hope this was helpful. no need to ask for docs as this was a harvard study.
Josh (roofing specialist)
joshf77 is offline
Old 04-23-2012, 08:52 PM   #29
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,702
Harvard study?
Well knucklehead has been studying this for years and his conclusion is , the more the better. Vent the heck out of it.
NKLHD
knucklehead is offline
Old 05-14-2012, 12:13 AM   #30
jskjtm's Avatar
Trade: restoration
The more the merrier. Temperature equalization between the attic and the outside air temperature is what counts. Having ventilation intake/exhaust at various locations around the house enables ventilation to occur no matter which way the wind is blowing. I would keep gable vents in place and functional. Ridge/soffit ventilation is superior to gable venting only because it fully ventilates (draws) from the lowest point to the highest. A lot of roofers really have no understanding of the real dynamics involved. Hope this helps and info doesn't get to you too late to do you any good.
jskjtm is offline
The Following User Says Thank You to jskjtm For This Useful Post:
tntwilliams (05-23-2012)
Old 05-14-2012, 12:18 AM   #31
jskjtm's Avatar
Trade: restoration
Originally Posted by knucklehead View Post
Harvard study?
Good call knucklehead, I agree 100%. Push or pull, equalization (temperature) is what you are ultimately after with ventilation in the first place.
jskjtm is offline
Old 05-15-2012, 09:19 PM   #32
bluebird5's Avatar
Trade: Licensed G. C. carpenter, flooring, remodeling
Rewards Points: 694
what compelled someone to write on a 4 year old thread?
bluebird5 is offline
Old 05-15-2012, 10:25 PM   #33
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 630
Often, it's as simple as just failing to notice the dates on the posts. But in the larger picture, why does it matter as long as it's good input? Forums are good not only for immediate consultation; they can be invaluable as a reference.
Tinstaafl is offline
Old 05-15-2012, 11:21 PM   #34
Steeper the Better!
kage's Avatar
Trade: Roofing,Gutters,Soffits.
Rewards Points: 150
Originally Posted by jskjtm View Post
A lot of roofers really have no understanding of the real dynamics involved. .
how is this a sensible saying?? you got REAL roofers(who know the "dynamics") and wanna be's and part time guys that might not know..but to sit here and say roofers in general is crap..
WHATS A HOUSE WITHOUT A ROOF?!?
kage is offline
Old 05-18-2012, 03:39 PM   #35
copper magnet
seeyou's Avatar
Trade: custom metal fabrication
Rewards Points: 512
Ahh, isn't this a 4 y/o thread that you're writing on?
seeyou is offline
Old 05-18-2012, 06:49 PM   #36
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
I've heard stories that Tin has commented on threads he originally started in the 30s...
BamBamm5144 is offline
Old 05-18-2012, 07:16 PM   #37
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 630
Sometimes they need a little update...
Old 05-22-2012, 10:40 AM   #38
bender_dundat's Avatar
Trade: Restoration
Rewards Points: 75
Nice thought however erroneous it is. I think I've seen several of your roofs, the ones that had a power vent, some turbines and some ridge vent. The more the merrier.
bender_dundat is offline
The Following User Says Thank You to bender_dundat For This Useful Post:
FerrisHI (05-24-2012)
Old 05-23-2012, 10:56 AM   #39
Roofsafe's Avatar
Trade: Residential roofing
Rewards Points: 75
There's more to adequate ventilation than just cuttin the ridge and pokin some holes in the soffet, the roofer can do all that and do it right. Some "roofers" could care less about proper ventilation, regaurdless of when a roof is put on there is one step that goes on inside the home that regulates everything that happens inside the attic. That one thing is the "insulator", if you or someone in the know isn't there to stop them, they will always close off the space between the top plate and the roof deck, allowing "NO" air into the attic. That and not putting any baffles up is the number one issue in new homes not being properly ventilated.
The other side of the coin is the GC not wanting to spend money on any more than a couple gable vents or the roofer isn't educated in the importance of ventilation. Some roofers just put up a quick ridge vent and don't worry about the intake, the customer learns the hard way about intake, the roofer just keeps boppin along not knowing any better.
The code changes are made and licensed roofers in this area are notified of every change, the building contractors are responsible for the soffet vents and the roofer is responsible for the roof vents, box vents are easier so guess what gets put up most.
The rolled ridge is worthless and ridge vents with filters right along with them. My opinion, but I have seen a lot of evidence that my opinion is right on.
Gable vents, just like anything else don't work with any efficency if there is no air supply from the lower end of the roof, once the screen in the gable vents corrodes or fills with cobwebs it is no longer worth anything but asthetics.
I block them off because it just makes sense to make the soffet to ridge system work right.
Roofsafe is offline
The Following User Says Thank You to Roofsafe For This Useful Post:
Tom Struble (05-23-2012)
Old 05-24-2012, 10:07 AM   #40
Roofer
FerrisHI's Avatar
Trade: Roofing
Rewards Points: 77
Always love seeing the infamous Attic fan next to the ridge vent...where do you think that powered fan is pulling air from???
FerrisHI is offline
The Following 2 Users Say Thank You to FerrisHI For This Useful Post:
kage (05-26-2012), seeyou (05-24-2012)
Do I need a ridge vent? jritkes Roofing 17 01-12-2013 11:17 PM
ridge vent versus traditional vents signal15 Roofing 16 02-11-2011 05:16 PM
Ridge vent issues? apkole Roofing 4 05-08-2007 06:46 PM
New Ridge Vent Installed Correctly? itwerx2 Roofing 6 04-01-2007 04:38 PM
Which ridge vent to use Tommy V Roofing 16 03-06-2006 05:38 PM
