Roofing Felt
Old 06-08-2010, 08:39 PM   #1
Cjeff's Avatar
Trade: Renovations
Roofing Felt
I am wondering how many put felt on entire roof (or at least side you are working on) before you start shingling?
I find wind and walking on it will rip it off, especially on anything over a 4/12 pitch.
I do mainly renovations and shingle my own roofs and am wondering is there a trick I am missing?
Cjeff is offline
Old 06-08-2010, 08:51 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,126
Re: Roofing Felt
Top priority is usually getting the thing dried in, and felting's the fastest way to do that unless you're using zip panels.
Maybe you're not using enough fasteners?
Tinstaafl is offline
Old 06-08-2010, 08:53 PM   #3
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,275
Re: Roofing Felt
lay some scraps of ply on top of it if you need to walk up and down it. Sometimes when we are sheathing we have to do this too. Felt tends to breakdown quickly if you walk on it a lot when its hot.
Easy Gibson
Warren is offline
Old 06-08-2010, 08:58 PM   #4
Newb
roofny's Avatar
Trade: Roofing and Siding Contractor
Rewards Points: 99
Re: Roofing Felt
Try Deck Armor or another synthetic underlayment that is nailed (supposed to be cap nailed) on. It won't budge.
roofny is offline
Old 06-08-2010, 09:01 PM   #5
Cjeff's Avatar
Trade: Renovations
Re: Roofing Felt
Normally around here we use plain old standard roofing felt.
Usually use shingle nails as I was taught. Maybe cap nails would be better?
Cjeff is offline
Old 06-08-2010, 09:05 PM   #6
Geometrist
Warren's Avatar
Re: Roofing Felt
Cap nails hold better (thats what we use) but you can still have it tear on you.
Easy Gibson
Warren is offline
Old 06-08-2010, 09:08 PM   #7
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,262
Re: Roofing Felt
I do a section at a time and felt as I go. Not the way everyone does it but, it works for me.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 06-08-2010, 09:14 PM   #8
Cjeff's Avatar
Trade: Renovations
Re: Roofing Felt
I shingle nail every 4 feet top and bottom.
I usually end up rolling the roll in front of me. And have 4 rolls going up in a staggered pattern.
I shingle going up on the angle from bottom to top.
So this works but I think rolling out entire rolls and felting all before shingling would be faster.
Do one job (felting) then shingle.
Cjeff is offline
Old 06-08-2010, 09:16 PM   #9
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
Re: Roofing Felt
those synthetics are pretty nice,i know some don't like them but for quick drying in and walkability its a pretty nice product
Tom Struble is offline
Old 06-08-2010, 09:18 PM   #10
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 812
Re: Roofing Felt
what's this "felt" you speak of? LOL , I have switched over to Berger roof underlayment, LOVE the stuff!
dave_dj1 is offline
Old 06-08-2010, 09:22 PM   #11
Cjeff's Avatar
Trade: Renovations
Re: Roofing Felt
For me anything but felt would be a special order, Felt is all my yards carry.
Cjeff is offline
Old 06-08-2010, 09:35 PM   #12
Capra aegagrus
Tinstaafl's Avatar
Re: Roofing Felt
No wonder it tears loose on you!
I'd call that marginal fastening even if I knew I was going to have it shingled over within the next hour.
Old 06-08-2010, 09:45 PM   #13
Standfor's Avatar
Re: Roofing Felt
Jeff, sound like you doing it right, (as long as you keep your lines strait I doubt if doing the whole roof will save you time. I also put about one or two rows of felt at the most. Getting it ripped is one thing, but more important is not falling off the roof caring the bundles from the ridge down.
(My supplier delivers them right to the ridge)
Standfor is offline
Old 06-08-2010, 10:20 PM   #14
red_cedar's Avatar
Rewards Points: 1,250
Re: Roofing Felt
Felt it as you go if drying in isnt an issue.
Rollout some of the first roll, then start the second roll and third and so on, putting shingles down on the partial rolled out rolls. minimal fasteners would be needed if you stayed on the shingles. Only works with stair stepping.
When I did new work and was paid by the piece thats how i did it. Minimal time rolling out paper.
What I mentioned sounds like what you do. anyway.
Its almost like cleaning up scraps on the ground, if you do it as you go the time per task is blended in so it takes less time.
red_cedar is offline
Old 06-09-2010, 12:18 AM   #15
Cjeff's Avatar
Trade: Renovations
Re: Roofing Felt
How often would you fasten it? With roofing nails or???
I like the idea of shingling 1 strip wide up the entire roof, then moving over and going up another strip (or two). I thought I may give that procedure a try. For that all the felt needs to be down first.
Cjeff is offline
Old 06-09-2010, 04:52 AM   #16
GC
NICKPAUS's Avatar
Rewards Points: 150
Re: Roofing Felt
Button cap staples every 16". Felt roof all at once. If it is in the desert different story-felt as you shingle as heat will burn you. Bostich button cap stapler ( look into it rookies). Here in So-Cal hot is 90 nothing compared to what you guy's see.
NICKPAUS is offline
Old 06-09-2010, 06:27 AM   #17
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
Send a message via AIM to ApgarNJ
Re: Roofing Felt
like others have said, switch to a synthetic roof underlayment and you'll be safer. I think felt paper rips, scary how many guys use 15 lb felt. that's cheese.
ApgarNJ is offline
Old 06-09-2010, 08:23 AM   #18
Tom M's Avatar
Rewards Points: 4,664
Re: Roofing Felt
Felt is fine! I always paper out the whole side and strike lines prior to running shingles its faster than starting and stopping.
Heres a tip for you. Overlap the paper half sheet if your going over ice shield, overlap four inches instead of the two inch line on the top of in the paper and you will lock these sheets together without tear out. No cap nails either, Im sure they're nice insurance but staples have been used for years...........
Tom M is offline
Old 06-09-2010, 09:01 AM   #19
AustinDB's Avatar
Rewards Points: 518
Re: Roofing Felt
no one mentioned using a 30lb vs a 15lb? the last roll of 15lb at the supply house was like paper-they're getting cheaper and cheaper.
I haven't used the bostich hammer stapler in years-got tired of it getting jammed up and slowing progress, but it was a nice tool to have.
AustinDB is offline
Old 06-09-2010, 10:30 AM   #20
Capra aegagrus
Tinstaafl's Avatar
Re: Roofing Felt
I'll use roofers on something like a little shed roof. For bigger/higher, I like cap nails, every 16-24" depending on pitch, weather conditions and whether it might have to sit without shingles for a while.
That does work well. You're doing much less non-productive walking, and especially if you have a grunt to feed you, you can roll!
Leveling with roofing felt and leveling compound DIA-jp Flooring 29 01-22-2013 09:19 PM
Rosin paper or roofing felt? Mike Finley Flooring 35 01-06-2009 03:06 PM
Roofing Felt for Garage Floor Tile Underlayment res0zvle@gmail. Flooring 4 10-26-2007 09:21 AM
Production Manager - Roofing (Seeattle WA) raynproof Help Wanted or Looking For Work 0 10-12-2007 05:31 PM
roofing felt bwashington Roofing 2 08-10-2006 10:52 AM
