Roofing Felt
Old 08-10-2006, 12:39 AM   #1
bwashington's Avatar
Trade: Healthcare Architect
Roofing Felt
I have found specification for 15-lb and 30-lb felt. I am using the felt as a seperation the exterior wall framing system and the building structural roof deck. The felt and flashing will be nailed to vertical cement board underlayment behind 7/8" plaster. Both will bridge a gap and the felt will overlap the first part of a 2-part clonter flashing system.
I'm concern about the flexibility of 15-lb felt. Is roofing felt available in 10-lb?
bwashington is offline
Old 08-10-2006, 06:29 AM   #2
Bah Humbug!
Grumpy's Avatar
Re: Roofing Felt
Show us your spec/diagram. While I do think I understand what you are describing I am not 100% sure. From what you described I don't think felt will do what you intend it to do.
I only use 30# on shingle roofing.
Are you a home owner or contractor?
Grumpy is offline
Old 08-10-2006, 10:52 AM   #3
reveivl's Avatar
Trade: Renovations
Re: Roofing Felt
Yeah a pic would help. Never heard of 10#. Next grade lower is 30 min tar paper as far as I know. Doesn't sound like the right application to me, but if that is what is speced...
reveivl is offline
OSHA says I should have had fall protection americangutters Health & Safety 86 04-14-2011 03:26 AM
Rosin paper or roofing felt? Mike Finley Flooring 35 01-06-2009 03:06 PM
Owens corning a solid strip of tar nolo Roofing 26 01-29-2008 01:25 AM
Approval/denial of roofing materials - questions jmasters Roofing 29 11-16-2007 08:09 PM
stringing felt Steve Unkie Roofing 13 10-27-2006 03:14 PM
