Roofing Failure Need Help
Old 02-28-2018, 08:48 AM   #1
Dmor4549's Avatar
Rewards Points: 6
Our church had torch down (5 yr warranty one ) and 2 years later there's splits and cracks . What could have caused it . One of the splits looks like not enough heat was applied because you can see the labels in the bottom which usually gets melted to adhere to the base membrane. We had a well known roofer do the work but maybe the worker doing the torching got lazy towards the end. All areas failing happened in the higher end of the roof lower slope perfect nothing failed but the higher end failed. Just need some of reason why could have failed.
Roofing failure need help-img_20180227_142118_1519829172837.jpg   Roofing failure need help-img_20180227_142127_1519829191765.jpg
Dmor4549 is offline
Old 02-28-2018, 09:00 AM   #2
Bull Trout's Avatar
Rewards Points: 1,006
Re: Roofing Failure Need Help
two years into a 5 year warranty, what did the roofer say?
Bull Trout is offline
Old 02-28-2018, 09:13 AM   #3
Dmor4549's Avatar
Rewards Points: 6
He said what I expected , he will make it water tight because it's raining Thursday and Friday. But he said he will contact manufacturer of materials and have them come out and take a look at it. He also said one cut could have been vandalism because cut looked to sharp of a line like it was made was the a utility knife. I'm just trying to figure out ideas why it failed , my feeling is not enough heat applied to it but I need input from roofer who have done torchdown and why it fails etc...
Dmor4549 is offline
Old 02-28-2018, 03:30 PM   #4
0xff's Avatar
Trade: Roofing
Rewards Points: 12
That looks structural--or just a faulty roll.
0xff is offline
Old 02-28-2018, 03:33 PM   #5
Dmor4549's Avatar
Rewards Points: 6
I guess my question is what happens if the roll is not heated enough.
Dmor4549 is offline
Old 02-28-2018, 03:35 PM   #6
0xff's Avatar
Trade: Roofing
Rewards Points: 12
No, based on the picture it seems that it is adhered properly.
And if you don't apply enough of heat, it wouldn't crack just like that but you'd rather see wrinkles/bubbly membrane which it isn't.
Did they torch down over metal by any chance?
0xff is offline
Old 02-28-2018, 03:41 PM   #7
Dmor4549's Avatar
Rewards Points: 6
No over old roof. But the big cracks when we pulled it apart the labeling under was never melted which told me not enough heat. The other spots I agree adhered proper but may have faulted .
Dmor4549 is offline
Old 02-28-2018, 04:21 PM   #8
Dmor4549's Avatar
Rewards Points: 6
More pictures of the roof
Roofing failure need help-img_20180228_164614_1519856219994.jpg   Roofing failure need help-img_20180228_170459_1519856402713.jpg   Roofing failure need help-img_20180228_170510_1519856424808.jpg   Roofing failure need help-img_20180228_170514_1519856453101.jpg
Dmor4549 is offline
Old 03-05-2018, 02:59 PM   #9
Insrepair's Avatar
Trade: Ins Repair
Rewards Points: 18
What kind of underpayment? It sorta appears the roof may have been wet when applied?
Insrepair is offline
Old 03-08-2018, 01:54 PM   #10
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 972
5 year warranty on the coating? Is that what u are saying? The new roofer coated the old roof? Or he rolled rolled roofing over old rolled roofing? Im so confused
madrina is offline
If you're not on Facebook, you should be. Sir Mixalot Marketing & Sales 1851 09-27-2016 11:09 PM
Certainteed Announces Industry-First Photovoltaic Training for Roofing Contractors Grumpy Roofing 16 09-05-2010 07:55 AM
