Roofing Coiler Nailer Problems Porter Cables
Im fed up with these guns, I currenly have 3 nailers, 2 are dead, the shaft just wouldnt return its normal postion, i'll push it up, it will shoot 1 nail and woudnt return. 2 in the same condition
3rd is starting to do the same problem ocasionally. What gives? What is the common problem behind these guns? What parts should I change. Im in the middle of a roof job, and the gun dies. Very fed up with porter cable. I
Roofing and Architectural
Trade: Roofing and Architectural Metals
Re: Roofing Coiler Nailer Problems Porter Cables
they are crap guns, period. Only reason you bought them is because they were cheaper right??
When it comes to ones livelyhood cheaper is rarely better. Only two guns worth a damn IMO are Max and Hitatchi |
well, i didnt purchase them, dad them, that was before i was running things, and learn not to buy POS from depot. anyways....
i ordered a overhaul kit, for 1 of the guns. i hope this should solve it. what are the common problems for these guns? |
I don't have a roofer, but all of mine
are PC...no problems for me. I have a buddy who had nothing but grief with his...he cranks the pressure up too high, and only oils them occasionally though. How do your guys treat tools?
Trade: Carpentry / Fencing / Decks
The plunger in the back cap is getting stuck. Try tapping on the back with a hammer or remove the back plate a slam it plunger side down on a hard surface to get it unstuck. Those guns do suck, the older PC were of a better standard.
Curt |
GC
My PC is almost 10 years old it does that every couple roofs a little oil fixes it. If the workers would just oil it daily I think it would be fine.
Trade: Residential roofing
I've had three PC's over the years, the 175's are the best, hit hard on a little air and work great. Alas, their old and the barrel is shot out of them, I bought a 175A and it lasted six months, the "O" ring is not an "O" ring, its a plastic ring and doesn't last very long, The older 175's wear out and they are done, period.
On yours it sounds like the feeder pawl is in need of an "O" ring, thats the one that wears out most in the 175's. |
I just got three of the same guns. Im not having that problem, but, iam having a problem with the depth adjuster. sometimes the things will blast through the shingle and the next nail will stick up 1/8''. so im constantly hammering and double shooting. the other guys are right we bought them cuz they were cheap and now we're paying!
Trade: roofing
the only real problem is that you did not by a real roofing gun. Make sure you go to the mens department when you by roofing tools. "Hitachi".
#10 | |
Craftsman
Trade: Residential Remodeling Contractor
Re: Roofing Coiler Nailer Problems Porter CablesQuote:
Yes this is the #1 cause of gun failure... But make damn sure your gun is not OIL-LESS ie... Many of the newer finish guns. I am not real sure if they make a oil-less framer ![]() I know that you cant put enough oil in a framer/roofer guns...only issue with exessive oiling in alot of discharge on your work and oil will break down the tar that is in composite roofing, other than that blowiong out the tool of crud and doing a monthly tool inspection, Nothing is worse than having to roll-up for the day when the tools dont work ![]() |
I have an "old" Hitachi that I have used , abused and loaned out that I still use as a backup, just bought a new Hitachi to replace the PC's.
Nothing but Max here for years. I think Hitachi is a close second. Max just came out with a new model, it looks like a cheap POS. I've used and abused my 450's for years, indestructible and parts are inexpensive to rebuild.
| Torch Down Roofing | steveoboist | Roofing | 14 | 09-06-2008 12:26 AM |
| Whats the best roofing nailer? | Michaeljp86 | Roofing | 36 | 05-07-2008 09:22 AM |
| Production Manager - Roofing (Seeattle WA) | raynproof | Help Wanted or Looking For Work | 0 | 10-12-2007 05:31 PM |
| Good brand of roofing coil nailer? | Bret | Roofing | 18 | 06-21-2007 09:31 PM |
| WTB roofing nailer parts(bostich RN45) | roofwiz74 | Contractor Swap | 5 | 01-11-2007 08:27 AM |
