Roofing Cement In A Tube....
Old 01-25-2009, 02:25 PM   #1
Project Manager/Carpenter
TBFGhost's Avatar
Trade: Carpentry/Reno
Roofing Cement in a tube....
What do you use...I am not a roofer, not too much experiance up there, but a friend call me over to his mothers house to repair a leak...just needs some roofing cement. What is some good stuff out there? I know there are four thousand brands and types of caulk out there so I assume like caulk, some roofing cements work better then others.
TBFGhost is offline
Old 01-25-2009, 02:38 PM   #2
Just a Roofer's Avatar
Trade: roofing
Re: Roofing Cement In A Tube....
What's it being used for? I like geocel 2600? i think it's called myself.
Just a Roofer is offline
Old 01-25-2009, 03:23 PM   #3
Tom Struble's Avatar
Trade: siding
roof shouldnt ''need'' roof cement
Tom Struble is offline
Old 01-25-2009, 03:29 PM   #4
Trade: roofing
Chimney flashings, top nailed shingles on ridge cap, vents, fans, etc. are examples of some kind of sealant that should be used.
Old 01-25-2009, 03:47 PM   #5
Trade: siding
to keep it from leaking? really hmmm
Old 01-25-2009, 05:24 PM   #6
Trade: roofing
To cover any exposed nails that are sometimes needed, & to seal counterflashings on brick chimneys, brick walls, etc. I have yet to see a residential roof without some type of sealant used.
Old 01-25-2009, 05:27 PM   #7
Trade: siding
thanks for the info
Old 01-25-2009, 05:29 PM   #8
Al Smith
A W Smith's Avatar
black jack
http://www.gardner-gibson.com/linedetails.aspx?id=15
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-25-2009, 05:45 PM   #9
PL
http://www.stickwithpl.com/Products....ashing-Sealant
neolitic is offline
Old 01-25-2009, 05:53 PM   #10
Al Smith
A W Smith's Avatar
A subcontractor that worked for me 12 years ago used a quart sized mechanics grease gun that he would recharge in a bucket of roof cement,
Al Smith
Old 01-25-2009, 11:04 PM   #11
Trailer park boy
shanekw1's Avatar
Through the roof
http://www.sashcosealants.com/Home_I..._The_Roof.aspx
shanekw1 is offline
Old 01-26-2009, 12:12 AM   #12
Trade: roofing
You could also take troublesome toms advise & insist no caulk is needed even though his profession is a siding that is known for overkill on caulk to hide thier messed up cuts & such.
Old 01-26-2009, 12:24 AM   #13
Trade: siding
just didnt realize it was needed to keep your roof from leaking is all.
and your right you can put all the caulk you want on my crappy trim and its still goin to leak
Old 01-26-2009, 02:30 AM   #14
Trade: roofing
I wasn't referring to any siding along the roof, although now that you mention it, why do you siding guys insist on putting a 3" coil trim along walls on a roof? How do you expect a roofer to tear a roof & get to the tins along the wall?
Old 01-26-2009, 02:52 AM   #15
Roofing and Architectural
Renegade's Avatar
Trade: Roofing and Architectural Metals
Justaroofer, come over here and I'll show you dozens of roofs with no caulk on them. I agree sometimes it's necessary but we always do our jobs planning on NOT having to use any caulk.
Ghost, where is the leak at? If it is in the shingles, you should use an asphalt product i.e. blackjack etc. If it's in a flashing, geocel or np1 are great products.
Renegade is offline
Old 01-26-2009, 06:20 AM   #16
Trade: roofing
Sorry to hear you live in Idaho, i can just picture all the dozens of roofs in the state with no caulk. Now back to reality, there is definitely a need for caulk on some aspects of the job, and it's not to put a bandaid on a future problem or anything after the hack is long gone either. By the way, i have had very few callbacks on my jobs & have done probably a few thousand.
Not a big deal for anyone around here, so long story short, caulk is used where needed. Do you like to leave exposed nails on vents, ridge, etc.?
Old 01-26-2009, 08:10 AM   #17
Bah Humbug!
Grumpy's Avatar
I was just going to say that. As for the argument, roof cement and caulk are two different beasts.
Any "repair" you make with roof cement or caulk is not a reliable repair. It might work, and if so it won't last long. Ever go to a job and see 10 colors of caulk on some flashing and it's STILL leaking? Yeah time for a new flashing job. Why postpone the inevitable, just do it right the first time.
Grumpy is offline
Old 01-26-2009, 10:08 AM   #18
2ndGen's Avatar
Trade: Thoroughbred Roofer
For roofing repair?
Tar in a 10oz caulking tube works best for me.
Way faster than loading a caulkgun by hand.
Very neat and convenient...for me?
Worth the $3. or $4. bucks.
"I've been up on the roof. I know what those guys go through.
My whole life has been about making that profession respectable
Ken Hendricks
www.SolutionsRoofing.com
2ndGen is online now
Old 01-26-2009, 10:15 AM   #19
2ndGen's Avatar
Agreed...a well layed out roof won't really need to be caulked anywhere (except in certain cases of protrusions).
Caulk (silicone type) and shingles don't go well together.
Give me good old fashion flashing cement anyday.
I've gone up on roofs with vent pipes that I sealed a decade and a half ago that still are holding up.
I either use Bulldog or Karnak.
Both are excellent.
Both get the job done.
Both can be counted on.
Ken Hendricks
Old 01-26-2009, 10:17 AM   #20
2ndGen's Avatar
Hi JAR,
When you say "caulk", do you mean silicone type?
Yes, exposed nails should be covered, but with flashing cement
(when they can't be shingled over or when they have to be exposed).
Ken Hendricks
Pex tube leak under cement floor jonbjornstad Plumbing 22 12-23-2008 09:44 PM
Torch Down Roofing steveoboist Roofing 14 09-06-2008 12:26 AM
Production Manager - Roofing (Seeattle WA) raynproof Help Wanted or Looking For Work 0 10-12-2007 05:31 PM
Reuse Cement tile roofing??? Jordcon General Discussion 0 08-14-2007 10:41 PM
Removing Roofing Cement? sandyman720 Roofing 3 07-28-2007 11:28 PM
