Roof Venting
Old 04-13-2006, 09:20 AM   #1
Geo's Avatar
Trade: painting
Roof Venting
Hi
newbie here and have some roofing questions
I ahve a split level home with a gable roof. I will be re-sheathing the roof as it looks in pretty bad condition( has a coupel of sags in it too), most of which i believe is from improper venting. The house was built in '65 and is in PA....Soffits are solid wood and have non vented aluminum over them. Is it best to add a ridge vent and redo the soffits, when i redo the sofits is it best to rip out the wood or should i just get a hole cutter and cut holes right down the line.
Thanks for any info, this isnt my profession but like any contractor I would rather do it my self
Geo is offline
Old 04-13-2006, 09:41 AM   #2
Bah Humbug!
Grumpy's Avatar
Re: Roof Venting
A ridge vent in combination with equal or greater soffit ventilation is about the best when you have a nice long ridge line. If you have any gable vents then you need to cover them up. I find it easier to run a circular saw the full length of the wood soffit then install a vented panel every 5' or so.
Grumpy is offline
Old 04-13-2006, 09:42 AM   #3
Bah Humbug!
Grumpy's Avatar
Re: Roof Venting
I actually prefer to know my limitations and let the pros do what they do best. After tackling a few of my own projects and knowing a pro would have done it better and in half the time and I would have more time to focus on making money... I have now decided to hire out my projects.
Grumpy is offline
Old 04-13-2006, 06:13 PM   #4
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Re: Roof Venting
Having a house of that age, you may want to check the attic and see if venting the soffit will even breath. Most houses that age have a bird's mouth cut in the rafter and attached to the wall. This leaves very little space more ventilation. Most of the time this area is filled with insulation for heat and to have less ice build up. In PA I suppose you don't have much for ice build up.
MJW is online now
Old 04-13-2006, 09:35 PM   #5
747's Avatar
Re: Roof Venting
To answer the soffitt question. My house had soffits built out of plywood. The plywood was completely removed than aluminum soffits with the slits in them were installed. My house was built in 63
747 is offline
Old 04-13-2006, 10:14 PM   #6
Geo's Avatar
Trade: painting
Re: Roof Venting
since i ripping off the roof i will have access to remove any insulation and correct the problem
Geo is offline
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
