Bah Humbug!
Roof Sheating, Span Ratings, Boca 96
I'm bidding a project with plywood replacement. 7 buildings about 20 squares each. This is phase II of the project. Another roofer was a disaster on Phase I, so they are trying to replace him.
THis old roofer used 3/8" sheathing on the roof. I bid for 1/2" CDX. They want me to adjust my bid for 3/8". I spoke with the building inspector who said he doesn't care what the thickness is, he cares what the span rating of the wood to be used is. I am looking at the Boca 96 code, but I'm confused here. Can someone explain this to me? I think I know what I am looking at, but not sure. I believe the roof is 24" OC 2"x4" rafters. Some rafters are 26' long. |
#2 | |
Unregistered
Guest
Posts: n/a
Re: Roof Sheating, Span Ratings, Boca 96Quote:
Bah Humbug!
I pretty much insisted I use 1/2. I don't want quality to suffer for the sake of a few bucks.
General Contractor
You've got the right idea Grumpy. I would decline the job if they want you to use 3/8". If you get the job you are covered by them requiring you to use the 3/8" but it's bad publicity for your company when a year down the road the roof fails.
Custom Builder
What's up with the 3/8's crap......Back in my days nobody would put 3/8 on a roof, now I'm running into it all the time. Don't the homeowners realize thier sacrifice?
Bob |
Chief Toilet Mover
Trade: Bathroom Remodeling
I understand Hatchet's response but if it is built to code and passes inspection you are off the hook.
So this inspector is referring to the fact that you could use different types of products as the roof sheathing so he is concerned with the individual products specs more than just a general 12 inch on center, 16 inch on center or 24 inch on center. Sounds like he is on the ball to me, but what the hell do I know. What other materials are available for roof sheathing that are up to code in your area, partical boards? In regard to the guest, those plywood thicknesses have more to do with saving money then some kind of archaic code. A 1/2 inch thick piece of plywood would also measure 16/32. 15/32 is 1/32 thinner and cheaper over millions and millions of sheets of plywood. All the plywood I see is now 1/32 thinner, except for tonge and groove which has remained true to the old thicknesses. |
Unregistered
Guest
Posts: n/a
As far as being off the hook i can agree to a point. i know quite a few builders in the area and have done some building of my own. as far as code goes you may be off the hook. but at the same time the city and state are immune to prosicution so even if say you use 3/8 and it is found out years down the line that this is unacceptable who pays? City is off the hook. so are you. insurance companies wont cover it. so the homeowner is stuck flippping the tab. We have this issue in Minnesota with mold vapor barrier inside wall outside wall any crack is filled. windows taped. nowhere for walls to breathe we all followed city code. everbody is off the hook but the homeowner is stuck big time. especially with homes that were constructed with wood foundations. 12 year old $200,000.00 homes have to be torn down and rebuilt. at homeowners expense. bad business for us all.
I have been reading a few of your guys other posts and have noticed you like the grace ice and water shield and have noticed you even went as far as to say cover the entire roof deck before roofing. I have had some experience in this as well it is a good concept. One problem i have found is in Minnesota not all houses are ventalated or insulated properly. and most times homeowners dont want to go through the extra expense of adding insulation or cutting in soffit vents. roof vents are not much of a expence so we can do this. What happens is the roof deck dry rots from excess condensation. instead of forming under the underlayment it forms on the inside of the attic. in which case 15 pound felt will allow condensation to form but absorb it into the felt then dry out. this is what felt paper is made to do.The ridge vent i have had some problems with cottonwood plugging it up after two years so have reverted back to the turtle style vents as well. Grace is the best Ice and water product i have seen and is expensive but still would not recomend covering entire roof. Next thing you know codes will require us to put air exchangers in the attic as well as in the living spaces. http://www.pfsrf.org/prf/prffaqs.html#4 This is a link i found which may help as far as span ratings go. |
Bah Humbug!
Mike no way I am off the hook. I have a ten year warranty. I back up that warranty. In order to back up that warranty I have to make sure the roof meets MY standards. OSB is also to code but I won't use anything less than CDX.
All wood sizes are nominal. a 2"x4" is not really 2"x4" The same goes for plywood. It's just a nominal size. BTW this is not new construction. Unregistered, please consider registering I am enjoying reading your posts. I won't install a roof without proper ventilation, or the home owner has to sign a waiver acknowledging that this is against the manufacturers recomendations and will void the warranty. |
Chief Toilet Mover
I understand you Grumpy. Makes sense.
| Low Pitch Roof solutions | Fixer | Roofing | 4 | 02-18-2007 11:09 AM |
| Help tying in this roof to addition | jaymay75 | Framing | 0 | 06-18-2006 10:54 PM |
| Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 21 | 01-16-2006 02:36 PM |
| Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 02:46 AM |
