Roof Sagging Wall Pushed Out
Old 10-14-2006, 06:31 PM   #1
christy's Avatar
Trade: roofing
hi everyone!
I am in the process of buying a house. Inspection revealed the roof was sagging and had pushed the wall out a little bit. I got a structural engineer to take a look at. He told me that rafters are slipping out around birdsmouths leading to sagging of the roof and outward movent of the wall. according to him use of small sized rafter caused this
He suggested to put a knee wall under the rafters and replace current thick shingles with one layer shingles. He said doing this would slow the outward push. The roof and the wall on the other side are ok. There is a partial brick wall on the other side.
What do you guys think ? are there any other options.
christy is offline
Old 10-14-2006, 06:44 PM   #2
Frankawitz's Avatar
Re: Roof Sagging Wall Pushed Out
In my house we had this problem, the living and dinning room walls were pushing out and the rafters were 2x6's, I removed the ceiling joists and we put in a 23' 2x6 LVL Beam and carried all of the roof and raised the ridge of the roof bring the walls in plumb, after we removed the partions and opened the living room and dinning room to 18'x22' with 12' cathedral ceiling.
Frankawitz is offline
Old 10-14-2006, 06:46 PM   #3
Faulkner Building Co.
Fauker_9's Avatar
Trade: Building/Remodeling
What kind of house is this? Ceiling joists or cathedrial? Any pics?
Fauker_9 is offline
Old 10-14-2006, 07:31 PM   #4
christy's Avatar
Trade: roofing
it has ceiling joists
christy is offline
Old 10-14-2006, 08:18 PM   #5
christy's Avatar
Trade: roofing
house was built in 1920s
christy is offline
Old 10-14-2006, 09:53 PM   #6
joasis's Avatar
This question is posted on the DIY chatroom. I am sorry Christy, but this forum is for professional contractors only. Many of our members regularly post on the DIY site, so you will get the advice you are seeking. Please feel free to ask all of your questions on the DIY board. Thanks!
This thread is now closed.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 09:10 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
