Roof Question Today At Work? - Roofing - Contractor Talk
Old 04-18-2014, 04:40 PM   #1
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
PLEASE forgive me, I KNOW that this has been addressed before, and will be more! To start with, I have done many roof jobs from past employment/own company/side jobs, over 30 + years, with no issue!
Today, my Project Manager where I work, ( fyi, I am classed as a "lead/carpenter tech". title with no say, just the BS involved!) came to me about a sub doing a roof for our company. Now for the question??
When doing a roof up the eaves, do you paper, then drip edge, then shingle, with the edging shingles, OR drip edge, paper, then shingle?
And as well, Do you roof apron, I/W then shingle, or I/W then roof apron, then shingle?
Not telling how I do it yet, but we have a bet at work on it! He is from the S.C. area, I was born and raised in the Pittsburgh area!
Ps I do maybe the wrong thing, let me know, paper/drip/shingle and I/W roof apron/ roof cement on top of apron/ shingles. Thanks, dave
Dave in Pa is offline
Old 04-18-2014, 04:53 PM   #2
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
Re: Roof Question Today At Work?
I go over the drip at the eave two rows min. of I&W.
under drip at the rake.
A vertical row on eave isn't a bad idea if a high wind area,,
jaydee is offline
Old 04-18-2014, 05:25 PM   #3
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,382
As far as I&W.... Manufacturer states for it to be applied BEFORE drip edge. Reason being an ice dam can be formed creeping under the drip edge, so there needs to be protection under the drip edge.
As far as felt paper.... Paper first, then drip edge (if any) along the rakes. Felt serves more as a vapor barrier than anything else. If wind driven rain were to be forced under the shingles, it could occur at the rakes so having paper overlap the drip edge could force it under the paper. With paper under the drip edge, the sheathing is still protected.
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
Old 04-18-2014, 05:36 PM   #4
Allcity1's Avatar
Trade: Roofing and siding
Rewards Points: 60
This is our way
Ice and water up eave at least 3' past house wall
Drip edge or gutter apron over ice and water
Felt or synthetic over ice and water and over drip
We have put ice and water both under and over the drip in bad ice damn areas
Allcity1 is offline
Old 04-18-2014, 08:43 PM   #5
hdavis's Avatar
Rewards Points: 1,909
Per manufacturer's instructions:
http://www.gaf.com/Residential_Roofi...ish_French.pdf
http://www.gaf.com/Residential_Roofi...structions.pdf
hdavis is online now
Old 04-19-2014, 03:19 PM   #6
slowsol's Avatar
Rewards Points: 2,234
Ice guard and felt under drip.
Ground pins go down.
Floor before base.
Cabinets before floor (sometimes).
Fiber tape on seams only with setting type compound.
-John
slowsol is offline
Old 04-19-2014, 03:27 PM   #7
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
around here the I&W wraps the eave fascia 3''very rare to see an eave drip/apron..you would think there would be problems but there's not
Tom Struble is offline
Old 04-19-2014, 04:30 PM   #8
Tom M's Avatar
Rewards Points: 7,138
Imo drips are over rated.
I would stick my ice over the drip, & my drip over the paper on rakes. That's me.
Bottom drip caps are supposed reduce overhang & cracking, as well as provide easy gutter access.
Tom M is offline
Old 04-19-2014, 04:36 PM   #9
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
2 rows of ice and water, then titanium underlayment. Drip goes on as you shingle.
jlsconstruction is offline
Old 04-19-2014, 08:03 PM   #10
red_cedar's Avatar
Rewards Points: 1,250
That's how I prefer to do it, 'wrapping the eve fascia' (its how I did my home) then the drip edge or gutter apron metal over it.
If limited money involved ( customer house ) then leave existing gutter apron and seal ice and water shield to flashing.
red_cedar is offline
Old 04-24-2014, 08:34 AM   #11
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Rewards Points: 1,772
We have been applying I&W per code (over the drip edge) for years. We just had the worst winter in 40 years and had no problems.
MJW is offline
Old 04-24-2014, 10:24 AM   #12
stacker of sticks
Rewards Points: 590
Show me this code?
Old 04-24-2014, 12:03 PM   #13
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
1/2 sheet for the first row under the eve, then full width over the drip. Rake metal goes on top of felt/underlayment.
1985gt is offline
Old 04-24-2014, 01:26 PM   #14
SouthonBeach's Avatar
Rewards Points: 1,009
Here in Fl we I&W the whole roof normally. So most of the time it's I&W then drip. Run a line of tar to seal the drip or peel & stick starter.
SouthonBeach is offline
Old 04-24-2014, 01:38 PM   #15
LeeFowler's Avatar
Rewards Points: 886
The whole roof? Ugh I guess you're not worried about breathability of the roof decking?
LeeFowler is offline
The Following User Says Thank You to LeeFowler For This Useful Post:
hdavis (04-25-2014)
Old 04-24-2014, 02:33 PM   #16
stacker of sticks
Rewards Points: 590
Originally Posted by LeeFowler
The whole roof? Ugh I guess yours not worried about breathability of the roof decking?
or the cost to replace the next roof
The Following User Says Thank You to jlsconstruction For This Useful Post:
hdavis (04-25-2014)
Old 04-24-2014, 11:18 PM   #17
MJW's Avatar
Originally Posted by jlsconstruction View Post
Show me this code?
MN code. We MUST supply photos for inspection.
MJW is offline
Old 04-24-2014, 11:20 PM   #18
MJW's Avatar
The roof breathes through the ventilation. OSB or plywood decking does not breathe anyways, aside from the seams.
MJW is offline
Old 04-24-2014, 11:53 PM   #19
LeeFowler's Avatar
Rewards Points: 886
I could be wrong and I often am but I don't think that statement is correct.
Old 04-25-2014, 12:04 AM   #20
hdavis's Avatar
They both breathe, you can check it in permeability tables.
flat roof wide open and building flooded madrina Roofing 43 05-29-2013 08:11 AM
Carpenter 10+ Yr. Exp. Looking for Work Northern Illinois Boda Help Wanted or Looking For Work 0 03-07-2013 09:41 PM
Joe Fusco's roof framing calculator bookmdanno Roofing 2 07-18-2012 02:41 PM
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 09:50 AM
