home improvement contract
Trade: home improvement contractor
A Roof Cutters Secrets
I just started reading this book and i just learned a new trick that i though i should share about chalk lines
when snapping lines with a helper tie two chalk lines together so when one guy reals in to chalk his line it pulls out the other freshly chalked line from the helpers chalk line back and forth right up the roof. i never heard of this one and thought it was pretty cool |
| The Following User Says Thank You to mci2980 For This Useful Post: | bluebird5 (12-12-2010) |
unlicensed hack
Trade: wood butcher
Re: A Roof Cutters Secrets
mci, I like that, I have heard that before, but like so many tips & tricks, I forget them unless I start using them. That one I may have to put into practice! Thanks.
This might be a good idea for another topic...... Construction Tips & Tricks.... Nathan?
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread. |
I remember seeing that trick a few years ago, and promptly forgot it since we don't do comp roofs anymore. A trick I will share if you guys ever do much metal roofing is do not use a chalk line unless you want to wipe it off immediately...cause one dew or a rain hit it, it is there...same as on concrete if you plan on acid staining...chalk like chalk can be used to dye concrete also.
Commercial Roofing
Trade: Roofing Contractor
blue chalk washes off.
http://www.roseroofing.net/ Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality! Free roof inspections within 12 miles of our locale. |
Trade: General Contractor, Roofing, siding, windows
I use a chalk line on hip ridges and that's it. no need for one.
#6 | |
Remodeling Contractor
Re: A Roof Cutters SecretsQuote:
"Man is a tool-using animal. Without tools he is nothing, with tools he is all." Thomas Carlyle (1795-1881) |
BTW, talking about books. We just did a reroof for a guy who writes books for places like Menards and Home Depot. He kept a close eye when I was shingling and in the end he said it was a very good job. He had a good view because the roof was only about 4 feet off the ground on the back of the house.
#8 | |
unlicensed hack
Trade: wood butcher
#9 | |
Trade: Granite & Marble Sales & Installation
Yeah, MJW, was it a home in Munchkinland? Please explain.
Commercial Roofing
I have done roofs that started at ground level.
It was a home built into a hill. If you haven't seen one you must live in the flatlands of iowa or something. Very efficient homes, but not alot of them.
#12 | |
unlicensed hack
Trade: wood butcher
LMFAO First of all.... Iowa.... with a capital I please. We don't get enough respect the way it is !!!! Second of all, I was just messin' with ya. I figured it was prolly something like that. We DO have houses built into the ground. I was involved with one about 20 years ago when I worked for another contractor out of high school. I can think of about 10 that I know of around here.
| Low Pitch Roof solutions | Fixer | Roofing | 4 | 02-18-2007 11:09 AM |
| Help tying in this roof to addition | jaymay75 | Framing | 0 | 06-18-2006 10:54 PM |
| Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 21 | 01-16-2006 02:36 PM |
| Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 02:46 AM |
