Broom engineer
Trade: Remodeling and property management
Roof / Ceiling Question...
I have to do a small roof repair, no big deal...(a leak around a soil stack has led to rotten plywood and a leaking ceiling) however the house is a ranch with exposed beams. Above the beams are what appear to be 2 layers of homosote in 24" strips then the plywood sheathing,felt and shingles. The homosote is the only insulation as well as the ceiling The house was built in the 50's and is located in suburban Philadelphia.
Can anyone tell me what this homosote like material is? Is it still available etc? Any tips for this type of roofing / ceiling repair? Thanks in advance! |
Expert Roofer
Re: Roof / Ceiling Question...
usually the sheathing was adhered to the top of the insulation,it`s still made,google it,you can fake it w/plywood and isocyanurate if you have to
Commercial Roofing
Trade: Roofing Contractor
Is homosote that asphalt empregnated perlite type stuff?
http://www.roseroofing.net/ Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality! Free roof inspections within 12 miles of our locale. |
Re: Roof / Ceiling Question... |
Commercial Roofing
So it is decking material?
Lets Experiment
Trade: Contractor
Homasote is a gray board that is made out of paper. It comes in 4'x8' sheets and is 1/2" thick. You'll find it in almost any school being used as bulletin boards. you can push pins into it with ease. Paints easy, Also has a 'R'
Factor Better than Drywall, but dont get it wet, Falls apart. |
3rd gen,it's in the blood
Trade: roofing
,what's that other stuff used mainly in commercial roofing? tectom or something like that.looks like ramen noodles and takes special fastners.
You have ONE advantage over me.....you can kiss my butt and I can't!! |
Ah!!! The good old sea weed roof decking material.
Gypsum decks also required special fastening. I used to use an NTB fastening system. Ed Last edited by Ed the Roofer; 09-06-2007 at 01:26 AM. |
Expert Roofer
homasote is like iso w/adhered osb/ply top board,tectum is the white fireproof spaghetti board which is only used over firewall junctures
#10 | |
Re: Roof / Ceiling Question...Quote:
Ed |
Expert Roofer
well that would go w/ the fireproofing purpose,but shingles etc don`t fasten very well to it even w/ the split nails---side note mirophone for computer solo is 7.99 at radio shack
| Tight Space Stucco Question - Undershot between roof sections | CGofMP | Construction | 3 | 03-24-2009 09:10 AM |
| metal cold roof question ..... | Vermonster | Roofing | 30 | 09-06-2007 01:30 AM |
| Low Pitch Roof solutions | Fixer | Roofing | 4 | 02-18-2007 11:09 AM |
| Structurally Unstable Roof Pricing Question? | APC | Construction | 14 | 02-01-2007 09:14 AM |
| Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 02:46 AM |
