Roof ?? Before I Insulate
Old 12-09-2005, 07:22 PM   #1
Suck it up, or shut up
rservices's Avatar
I just bought a 110 yr old home, the attic is unfinished(half of of the secound story). needless to say has no insulation. So basicly 1/4 of the home is freezing.(Wisconsin)
The roof supports are 2/8.
There is a floor.
Is there any factors I should concider before stapling insulation.
I do plan on finishing this space, hopefully in a few months.
thanks john
rservices is offline
Old 12-09-2005, 08:34 PM   #2
Custom Builder
Glasshousebltr's Avatar
Re: Roof ?? Before I Insulate
OK Grump, lets hear your ventilation pitch.
Bob
Bob
Glasshousebltr is offline
Old 12-09-2005, 09:38 PM   #3
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
Take the floor up and insulate the lower ceiling.
http://www.roseroofing.net/
Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality!
Free roof inspections within 12 miles of our locale.
AaronB. is offline
Old 12-12-2005, 01:41 PM   #4
Bah Humbug!
Grumpy's Avatar
The speach: Attic ventilation is a science unique to each building. No canned answers will ever apply. There are no "one size fits all" solutions.
You need at least 3/4" of ait space under your roof deck. For this reason do not staple your insulation directly to the roof deck. You want positive air flow directly from your overhangs to your exhaust vent(s).
This can be accomplished by installing rafter baffles from the overhang or knee wall area, all the way to the ceiling area. This will create a vented pocket in every rafter and will properly ventilate your roof.
Rafter baffles are very inexpensive, something like $1 for a 3' piece. They are sold at most home depots and other big box hardware stores.
If you are not going to be using the attic as a finished living space then Aarons suggestion is best... Or you could just lay the insulation right over the floor if you never plan to walk on it.
Grumpy is offline
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
