Ridgevent Vs Attic Fan
Old 06-02-2008, 09:45 PM   #1
72chevy4x4's Avatar
here's a question for you guys, somewhat related to a recent question but for an ongoing job I'm on. Assuming proper soffit venting, would continuous ridgevent or an attic fan (likely) provide a lower attic temperature? This particular attic has two small gable vents (about 2sqft each) plus the soffit venting and one electric attic fan, mounted about 15" from the ridge.
I would guess with a good breeze, the existing setup would suffice, but on the days with no real breeze, the attic would be hotter with the fan b/c of hot air pockets at the points furthest from the fan.
72chevy4x4 is offline
Old 06-02-2008, 10:09 PM   #2
pfelber's Avatar
Trade: Roofing Contractor
Re: Ridgevent Vs Attic Fan
I would think the attic fan would do a better job of circulating the hot air out on those non-breezy days.
pfelber is offline
Old 06-02-2008, 10:36 PM   #3
APPLIED RIGHT
johnk's Avatar
Trade: roofing
IMO I would use ridgevent,then I would block the gable vents.
"A Roof is only as good as it is Applied"
johnk is offline
Old 06-02-2008, 11:59 PM   #4
brutis's Avatar
Trade: siding soffit hardie Tampa Fl
there are calculators for venting roofs, i believe it is diferant for diferant climates, don't know about delaware but here in fl. we vent the **** out of it,
The vents in the soffit are sapose to be in vents meaning the air go's up through and out the ridge vents or gable vents or attic fans or what have you
brutis is offline
Frost inside the attic? SOSSW Roofing 22 04-03-2009 08:26 AM
insulating attic stairs Mitch M Insulation 5 07-12-2008 09:51 PM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
using attic to heat your water? rhinoguy Plumbing 8 02-25-2007 08:04 PM
Helping in friend's attic mess Terrence Carpentry 18 11-04-2006 01:36 PM
