Ridgevent On A Standing Seam Roof.
Old 09-01-2017, 09:10 PM   #1
Trintcole's Avatar
Trade: General
Rewards Points: 14
My house originally had shingles with a ridge vent system and perforated soffits. I had a standing seam roof installed with peel and seal ice/water shield under layment. They totally encapsulated the roof with the peel and seal. They installed the ridge caps and did not cut out the peel and seal where the ridge vent used to be. Now the roof is totally sealed but my soffits are still perforated.
Is a ridgevent required for a metal roof?
I live in Florida panhandle where humidity can be 100% for long periods of time.
Would humidity be trapped in my attic?
Trintcole is offline
Old 09-01-2017, 09:21 PM   #2
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 10,568
Re: Ridgevent On A Standing Seam Roof.
What kind of i&w?
Easy enough to cut it open from inside the attic.
A&E Exteriors is online now
Old 09-01-2017, 09:34 PM   #3
Trintcole's Avatar
Trade: General
Rewards Points: 14
Its gaf.
I was thinking the same thing about cutting it out. The installer said that they always leave it closed.
I can't get a definitive answer as to whether a ridge vent is required or not. They inspectors don't know, the metal distributor says maybe. According to HUD code all hous require an attic venting system.
The z bar closure / ridge cap is somewhat sealed on top as well.
If the roof being sealed is a humidity or heat issue I will have them put a ridge vent system in place.
Old 09-01-2017, 09:44 PM   #4
Originally Posted by Trintcole View Post
Its gaf.
It will at the very least make your house cooler.
My major concern is that the granulated iceguard they used is going to abrade the backside due to expansion and contraction of your panels and cause them to rust out from the backside due to condensation on raw steel.
You are definitely trapping moisture in and that is never good
Old 09-01-2017, 09:49 PM   #5
Trintcole's Avatar
Trade: General
Rewards Points: 14
The under layment is for metal. It's only sticky on the side that goes on the decking.
Thanks for your replies.
Old 09-01-2017, 09:52 PM   #6
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
do you have soffit venting?
Tom Struble is offline
Old 09-01-2017, 09:58 PM   #7
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 966
How steep is your roof?
Also, yes, I would say you need the venting at the ridge no matter the pitch.
Andy.
P.S., I can not see the logic in the expense of the entire roof being covered in the peel and stick.
ScipioAfricanus is offline
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
NJGC (09-01-2017)
Old 09-01-2017, 10:00 PM   #8
All I&W is only sticky on the udlnderside.
All GAF i&w I have ever worked with has a granular surface which scratches the back of your roof panels
The Following User Says Thank You to A&E Exteriors For This Useful Post:
NJGC (09-01-2017)
Old 09-01-2017, 10:01 PM   #9
Andy.
I believe it is required in Florida
ScipioAfricanus (09-01-2017)
Old 09-01-2017, 10:22 PM   #10
Trintcole's Avatar
Trade: General
Rewards Points: 14
The gaf product used is specifically for metal. Its smooth on the outside.
I think my pitch is 3x12. Its a hip roof.
My soffits are vented. The are the vinyl perforated type. Thats why I could see humidity rising into them, but having no way out.
Peel and seal on the whole roof is common in Florida.
Old 09-01-2017, 10:33 PM   #11
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,177
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Tinstaafl is online now
Bracing for satellite dish to a standing seam metal roof Lakesidex General Discussion 14 01-07-2015 06:20 PM
Residential Flat roof Nac Roofing 8 04-23-2013 10:51 PM
Elastomeric Roof Coating Harrisburg, PA 17112 Roof Clean Pa Roofing 1 08-24-2012 08:54 AM
Old standing seam roof s.kelly Roofing 7 03-17-2010 07:12 AM
