Which Ridge Vent To Use
Old 02-28-2006, 09:31 PM   #1
Revival Homes Inc
Tommy V's Avatar
Hi, Im looking for opinions on ridge vents for a Minnesota house, 4/12 pitch, with the potential for snow build up. Im a genral contractor, and have done some roofing, but never tried ridge vent, and there are many choices. Any opinions on the differant brands?
Tommy V is offline
Old 02-28-2006, 10:07 PM   #2
River Rat Dad's Avatar
Trade: Roofing, siding, framing
Rewards Points: 250
Re: Which Ridge Vent To Use
I am currently a fan of Shingle Vent II
Used Coravent back in the day when it was the only option for a vent that you caped over. But i think better products have passed them by
River Rat Dad is offline
Old 02-28-2006, 10:11 PM   #3
Grumpy's Avatar
Rewards Points: 2,000
I too like the shingle vent II, however there are some very similair vents on the market. Cobra II, and even rollvent have a rigid plastic baffled ridge vent. The baffle is the key IMO, howevr I don't mind using the tamko ridge vent or the Roll vent when necessary (there's only a few bucks cost difference).
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline
Old 02-28-2006, 10:17 PM   #4
Shingle Monkey's Avatar
Trade: He who shingles roofs
Rewards Points: 75
Shingle vent II
Shingle Monkey is offline
Old 02-28-2006, 11:14 PM   #5
minnesotaroofin's Avatar
Rewards Points: 150
Snow Country is good -- I personally would recomend staying with traditional venting on a 4/12. Turtle vents are tried and true. if it aint broke why fix it?
minnesotaroofin is offline
Old 03-01-2006, 05:56 AM   #6
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
I like the original CObra vent. IT looks good when Im done and I can say "whatevah" to the roofers that say it has to look like crap (ucz they cannot understand how to install it right)
http://www.roseroofing.net/
Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality!
Free roof inspections within 12 miles of our locale.
AaronB. is offline
Old 03-01-2006, 07:01 AM   #7
SAGE
sage's Avatar
Trade: Remodeler and Finish Carpenter
Rewards Points: 250
Shingle Vent II as well.
-Lead from the front, or dont lead at all-
sage is offline
Old 03-01-2006, 04:22 PM   #8
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Rewards Points: 1,772
I feel Omni Roll is the only one to use. It is the only product I have used yet that keeps bats and bugs out. I have used all the ones mentioned and Omni vents the best also.
MJW is offline
Old 03-01-2006, 06:07 PM   #9
Alan Hughes's Avatar
Rewards Points: 75
I'm not familiar with Omni vent. I'll have to check that out.
shinglevent II is what I like.
I try to get $5 a ft to cutout and install, shinglevent included. How about you guys?
Alan Hughes is offline
Old 03-02-2006, 11:22 AM   #10
Rewards Points: 250
Another thought.... most of the above products claim a net free airflow of 18" per running foot. It is importent to provide at least as much intake from some sort of soffit system
Old 03-02-2006, 11:26 AM   #11
Grumpy's Avatar
Yes any ridge vent will not work without equal or greater intake ventilation. In addition do not mix ventilation systems. I was at a house yesterday training my new salesman and I told him we will not be installing a ridge vent because of the gable vents. I said instead we would install a few mushroom vents just to enhance the system.
He said "but the neighbor's have gable vents and ridge vents." I said "And if the neighbor's roofer's jumped off a bridge, would we also jump off a bridge? It's not right, and don't take my word for it. Look it up on the websites or int he brochures."
-Grumpy
Grumpy is offline
Old 03-02-2006, 05:46 PM   #12
Commercial Roofing
AaronB.'s Avatar
Well, isnt that the same premise? Short circuiting the ventialation system with mushroom vents? Same as if it were ridge vent? Should you really be making sure the gable vents are sufficiently sized? Unless they are acting as an intake, then it wouldnt matter either way, if youre putting ANY vents in the roof.
AaronB. is offline
Old 03-03-2006, 12:01 AM   #13
dougger222's Avatar
Rewards Points: 1,116
Omni roll for me if ridge vent is a must.
I've used them all and although the ten foot sections left unridged are the fastest to install they look the worst when finished.
Cobra roll is ok as are the plastic four footers.
I recommend net free galv. metal roof louvers that are flush on the sides on all tear offs and 98% of new stuff is roof louvers.
Strongly discourage ridge vent on homes with a pitch under a 6/12. Several years ago my father was given called back to a huge apartment building he worked on after started to leak. He couldn't figure why such a straight forward roof would leak until he peaked his head in the attic, four foot snow drifts. When the snow of the roof and the attic melted he was paid to rip off the ridge vent and install roof louvers.
A framer I know added roof louvers to his lake home he found out he wasn't getting enough ventilation out of his ridge vent.
dougger222 is offline
Old 03-03-2006, 10:36 AM   #14
Grumpy's Avatar
The problem is you can not always increase the size of the gable vents.
Aaron, it's actually not the same premise. I discussed this with some of the ventilation engineers at AirVent and they stated that if you have soffit intake then gable vents act much like mushroom vents act, as static ventilators where air rises in the soffit and out the gable vents.
He also said that if there are no soffit vents then you do not want to install the mushroom vents because then you WILL be short circuiting the system. When no soffit vents are in place, the gable vents act alike a wind tunnell and air tavels horizontally instead of veritcally.
So to summarize, if there is soffit intake AND gable vents, it is ok to install mushroom as additional exhaust. If there is not soffit intake you should not install mushrooms.
-Grumpy
Grumpy is offline
Old 03-03-2006, 02:41 PM   #15
Idosidejobs
JustRightCo's Avatar
Trade: ROOFING,SIDING,WINDOWS
Rewards Points: 75
Shingle vent II
JustRightCo is offline
Old 03-04-2006, 01:03 PM   #16
bestmetalroof
bestmetalroof's Avatar
Trade: Roofing and Siding
The cor-a-vent V600 beats the pants off everything else--Including Shinglevent II.
-Best
If you do it right, you only have to do it once!
bestmetalroof is offline
Old 03-06-2006, 04:38 PM   #17
RooferJim's Avatar
Trade: roofing
GAF Cobra is by far the best. and yes I have tried them all.
RooferJim
J.Bennette Roofing inc.
RooferJim is offline
Do I need a ridge vent? jritkes Roofing 17 01-12-2013 10:17 PM
ridge vent versus traditional vents signal15 Roofing 16 02-11-2011 04:16 PM
Ridge vent issues? apkole Roofing 4 05-08-2007 05:46 PM
Whats the purpose of a ridge vent? Magnettica Roofing 22 04-22-2007 04:16 PM
New Ridge Vent Installed Correctly? itwerx2 Roofing 6 04-01-2007 03:38 PM
