Ridge Vent Industry Question
Old 09-26-2008, 06:57 PM   #1
USER8493893's Avatar
I just did a roof, single ranch, and they decided they wanted ridge vent after i was all done(fun)! so i installed it. i then drove around and started noticing that every other house ran it differently. some houses ran it right to the end , some run it to about 3 ft from the end and ran cap to the end of thevent and left the vent exposed. ialso saw someone run it 3 ft from the end and run the cap over the end of the vent and continue to the end. which is the correct way to install that plastic vent?
USER8493893 is offline
Old 09-26-2008, 07:23 PM   #3
Handle It!
MALCO.New.York's Avatar
Re: Ridge Vent Industry Question
NEVER to the end.
Ultimate Wisdom---------
MALCO.New.York is offline
Old 09-26-2008, 07:28 PM   #4
Lou the roofer's Avatar
Trade: Roofing
i usually run it about 1.5-2 feet from the end.
Lou the roofer is offline
Old 09-26-2008, 09:33 PM   #5
Kgmz's Avatar
Actually with most brands you run the vent to the end, and cap it or fold it over to seal the end. But you do not cut the slot in the roof to the end, you stop the cut about a foot back from the gable wall.
Other wise it looks stupid with that step up and down at the ends or that slope some guys make by running the ridge cap over the end, especially if it is one of the thicker ridge vents.
Kgmz is offline
Old 09-26-2008, 09:49 PM   #6
APPLIED RIGHT
johnk's Avatar
Trade: roofing
What he said,looks way better
"A Roof is only as good as it is Applied"
johnk is offline
Old 09-26-2008, 09:57 PM   #7
APPLIED RIGHT
johnk's Avatar
Trade: roofing
johnk is offline
Old 09-26-2008, 09:57 PM   #8
Handle It!
I do not disagree with running the vent to the ends. Just not cutting.
Old 09-26-2008, 11:46 PM   #9
Ed the Roofer's Avatar
Trade: Roofing Contractor
Thats how I train our guys to do it too.
Ed
Ed the Roofer is offline
Old 09-27-2008, 09:52 AM   #10
RooferJim's Avatar
Trade: roofing
Always run your ridge vent continous. end to end. This is for esthetic reasons as well as manfactures instructions. It is the mark of a hack job and an uncaring unsymetricle roof to short change the lines of your roof. makes an otherwise neat job look like crap. "a pet peeve of mine".
RooferJim
www.jbennetteroofing.com
RooferJim is offline
Old 09-27-2008, 04:09 PM   #11
Originally Posted by SLSTech View Post
If in doubt - read the directions
never! directions are over rated!
Old 09-27-2008, 05:25 PM   #12
mattp's Avatar
Trade: roofing
I always run mine to the end but will put about 3-4 pieces of ridge cap under the vent on the ends. So it's not realy venting the last foot but looks a hell of alot better. By the way directions on amoni-roll say leave 12-16" from end.
mattp is offline
Old 09-27-2008, 09:59 PM   #13
tinner666's Avatar
Always to the end. End is uncut and shingle tops overlap. Silly to put any cap under the vent.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 09-27-2008, 10:08 PM   #14
Roofsafe's Avatar
Trade: Residential roofing
You can use ridge vent for more than ridges, if you don't have enough ridge to get the amount of air flow you need, and you don't want to ugly up the roof with box vents, use more ridge vents. Passive ventilation that works and gets all the air flow required for code is easily attainable.
Might require a little more work but I have found that the customer is willing to pay extra for something that will cost nothing to have in operation and save them money while it is operating 24/7. Ridge vents is the easiest to modify to attain that goal.http://www.contractortalk.com/pictur...&pictureid=167
Roofsafe is offline
Old 09-27-2008, 10:15 PM   #15
tinner666's Avatar
Hers' the link. I forgot to add it to my site. Just stuck the page up.
http://www.albertsroofing.com/Ridge%20Vent%20Detail.htm
Old 09-27-2008, 10:43 PM   #16
Starving Tile Artist
wizendwizard's Avatar
Trade: Carpentry, Flooring & (UGLY) Tile installs.
Send a message via Yahoo to wizendwizard
Cobra has advice on this on their website. Your air outflow should not be more than your air intake. It really depends on square footage of your roof.
Balanced Ventilation
Requirements
Balanced ventilation requires 1 square foot of ventilation
for every 300 square feet of attic floor space.
1.
Calculate the total square footage of the attic floor area
(round up to the next highest number). This number
will determine the minimum total linear feet of Cobra
Exhaust Vent that is needed.
2.
Find the appropriate amount of Cobra Exhaust Vent
and minimum intake ventilation that corresponds to
the total attic square footage.
Total Recommended Length Minimum Intake
Attic Square of Cobra Exhaust Vent Ventilation (Net Free
Footage (Feet)
* Area in Sq. In.)*
1600 23/28 389/395
1900 27/33 457/466
2200 32/38 541/536
2500 36/43 609/607
2800 40/48 676/677
3100 45/53 761/748
3400 49/58 829/818
First figure pertains to hand nail, second figure
pertains to nail gun
NOTE: In no case should the amount of ridge exhaust
ventilation exceed the amount of soffit ventilation.
With this being presented, the length that you install depends on personal taste and asthetics, also what is defined in your contract.
"If you start the grout process over, you too could use sparkly grout!"
There is no such thing as an illegal immigrant, they are either illegal or immigrants.
I'm Retired, or a student, don't really know anymore.
wizendwizard is offline
Old 09-27-2008, 10:59 PM   #17
Requirements
1.
2.
Footage (Feet)
* Area in Sq. In.)*
1600 23/28 389/395
1900 27/33 457/466
2200 32/38 541/536
2500 36/43 609/607
2800 40/48 676/677
3100 45/53 761/748
3400 49/58 829/818
Those who only aspire to meet Minimum Specifications are doomed to eventually be labeled disingenuous as far as the longevity and quality of performance.
It has been stated that; Those who only perform to Minimum Code, (or Minimum Specifications), are those that barely recieved a passing grade.
Congratulations!!!
That Grade is a D-Minus.
Strive to offer more and your reputation will preceed your proposal.
Ed
Old 09-27-2008, 11:02 PM   #18
Congratulations!!!
Ed
Example being my most recently install of 48' on a 17 sq roof, where the customer originally requested minimum code allowance?
Choose your admonations carefully!
Old 09-27-2008, 11:06 PM   #19
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
2 story home, mile of the beach, nothing breaking the weather. Vents were taking in some water,[ceiling stain ] each winter. Funny We did fine without these a loota years!
Driftwood is offline
Old 09-27-2008, 11:14 PM   #20
You were not the target of the critiquing.
I only quoted your post, due to the Minimum criterial recommendations suggested in the ventilation advice posted from that site.
48 feet of Exhaust ventilation certainly achieved a credible and significant improvement on the home owners request.
Per chance, did you have the opportunity to upgrade his Intake Ventilation at the same time, or as a work in progress change order to upgrade his specifications?
Ed
Question RE: finish Hardware TraeHova Carpentry 5 09-07-2008 11:35 AM
Basement Window Question gregt848 Windows, Siding and Doors 9 07-26-2006 06:29 PM
Which ridge vent to use Tommy V Roofing 16 03-06-2006 05:38 PM
Can I add a ridge vent as a DIY project? rgoldtsv Roofing 7 02-22-2005 06:57 PM
Drain Vent Question straitlineguy Plumbing 2 11-24-2004 08:23 AM
