Ridge Vent
Got a couple of guestions concerning my new roof.
My hose has one main ridge plus two shorter ridges on each end perpindicular to the main. The roofer ran ridge vent all the way across the main ridge only. Should the shorter ridges have been vented too, and should the main vent be ran all the way from one end to the end. Most, if not all, the houses I have looked at have the ridge cut back a little from the ends. I'm thinking the shorter ridges should also have been vented even though they are a little below the main. Also, this is the type ridge bought in a roll. Should it have some kind of cap at the ends? Btw, these shorter ridges are somewhere around 18 to 23 feet long. Thanks for your thoughts on this. |
Re: Ridge Vent
All ridges should have been vented, we like to hold back about 6'' from the end. The roll stuff is ok, but i prefer more rigid, comes in 3' sections. Do you have proper soffet vents?G
i prefer this http://www.gaf.com/Content/Documents/21113.pdf
Trade: General Contractor, Roofing, siding, windows
Re: Ridge Vent
Running ridge vent all the way to the ends is not necessary. It's usually an aesthetics thing. Some guys think it looks better if it runs the whole length of the ridge. Myself I think it looks silly because I know it is useless.
As for the other ridges....without a picture, I'm not sure why they weren't done. |
Re: Ridge Vent
I am not sure why all the ridges weren't vented. I suspect it was time saving thing on his part. He said "hot air goes to the highest part, etc.."
I will be installing eave vents when I get the facia on. This house has very short lengths of overhang to install the eave vents. I had more overhang built into the the gables, but that doea little to help me on the venting problem witht he eaves. I have thought of running some vents across the gabled ends just above the top plates. The house next door has the stiffer venting on the stiffer venting on the ridge that comes in 3' or whatever sections, but I did not likew the way it looked ( too much profile). The lack of areas in the eave that can be vented has to do with the flat roofs on the front and rear of house. The rest is mostly gabled areas. |
shingleguru
Re: Ridge Vent
Generally I will stop ridge vents 2' from roof edges. simply for the asthetics; any other ridges on a roof that are greater than ten feet in legnth will be vented. I agree with the above posting that stated "the heat goes to the highest point" . considering Alabama summers are similuar to Texas summers, I suggest any venting that could be adressed should be installed.
Pro-Storm Repair
Re: Ridge Vent
HEy bowman
I 2nd the motion 6" form each enad is the standard and unless the other 2 ridges fall over a " non" heat area Ie a garage etc.. they should have been vented with the slight exception of dog house's / dormers both GAf & certianteed how info on the standrad for ridge vent and soffett vent verses ridge vent ratio I recomend taking a look at that before installing your soffett vents I have a bunch links but cant post them hmmm HOpe these help if ya need anything else just ask |
Trade: roofing
Re: Ridge Vent
We always run our ridge all the way to the end. IMO it looks complete and not like *****. As far as the other ridges sounds like they need vented but without out seeing it hard to say. Pics?
Trade: siding
Re: Ridge Vent
i agree whether it works or not i rather see the vent go the full length
it looks goofy to me just poping up |
Roofer
Re: Ridge Vent
If you run the numbers on exhaust vent, they seldom work out to needing continues ridge, if ever, thus I see that issue as being a cosmetic matter and always explain that to the home owner and go by what they prefer.
They want rake to rake, that's what we do, if not, we don't.
| The Following User Says Thank You to Slyfox For This Useful Post: | Tom Struble (05-02-2009) |
Lack Of All Trades
Trade: Professional handyman services
Re: Ridge Vent
The shorter ridges don't necessarily have to be vented. Heat rises, and the upper ridge vents should be sufficient. However, the lower, short ridges could have been vented; I learned you can never have too much ventilation in a roof.
Good Luck. |
Re: Ridge Vent
Hot air rises, but ventilation works better as a system. The other roofs should have their own venting more than likely.
Too much venting in a roof can be a very bad thing. The air can come in and right back out. It can actually be short circuiting itself as a system. |
Re: Ridge Vent
If the attic space of the lower gables are open to the attic space of the taller ridge then it is recommended to not install a ridge vent on the lower gables. The reason is that the ridge vent on the lower sections would possibly become intake vents servicing the taller ridge vents, "short circuiting" the ventilation system and drawing moisture into the attic. If the attic areas are separate, then it would be best to install the ridge vent on the lower gables. It seems like your roofer did you right...
| The Following User Says Thank You to Zatol For This Useful Post: | mattp (05-02-2009) |
#13 | |
Trade: Roofing, Gutters, Siding, Paint GC
Re: Ridge VentQuote:
Thats the answer right there |
#14 | |
One of them, I think, only has a cutout between it and the high part. I might be wrong on that, but it seems when I had some insulation blown up there some years back it had a place that the guy had to go through to get to that part. Maybe 2.5X 2.5'. |
#15 | |
Trade: Public Insurance Adjuster
Pinnacle Limited
Public Insurance Adjusters (800) 918-7840 |
Re: Ridge Vent
Ok Pinnacle, I am still learning alot about ventilation, but if the ridge vent draws from the gable ends, how does that keep the roof cool( Perhaps it is a given that there are eave vents). I have had a couple of peole tellme that ridge vents and gable vents alone would be unproductive, is that true?
| Ridge vent question | belu0501 | Roofing | 0 | 09-30-2008 09:11 PM |
| ridge vent industry question | USER8493893 | Roofing | 24 | 09-28-2008 01:52 PM |
| use of ridge vent | 72chevy4x4 | Roofing | 14 | 07-22-2008 08:38 AM |
| seal gable vents after ridge vent installed? | tacoma5050 | Roofing | 26 | 01-18-2008 10:50 PM |
| Ridge vent issues? | apkole | Roofing | 4 | 05-08-2007 06:46 PM |
