Residential Flat Roof
Old 02-15-2013, 04:17 PM   #1
Nac's Avatar
Trade: Concrete, masonry & excavation
Rewards Points: 324
I have a residential flat roof. It is modern style house with a flat roof about 15 sq. and 160lf of parapet. It has the original mod. Roof. I what to do a rip out and reroof with 2" iso and 60. mil pvc. My problem seems to be every roofer gives me different recommendation one wants to use epdm, 2 others tpo and one pvc. The one roofer is a certified JM roofer how is their 60 mil pvc? And what is the best way to cover the parapet with copping or bring up the pvc over the parapet and just and upside down angle flashing. Any help would be appricated.
Facebook
Nac is offline
Old 02-15-2013, 05:27 PM   #2
rustyjames's Avatar
Rewards Points: 1,558
Re: Residential Flat Roof
I'm no roofer but you should really think about adding more than 2" of the ISO, if you don't have the insulation thickness covered from below. Now would be the time to do it.
rustyjames is offline
The Following User Says Thank You to rustyjames For This Useful Post:
madrina (04-27-2018)
Old 02-15-2013, 06:49 PM   #3
Roofer
FerrisHI's Avatar
Trade: Roofing
Rewards Points: 77
Coping is definitely a better system will also cost more...White epdm or one of the other 2 would definitely be the route i would go on this...
FerrisHI is offline
Old 02-16-2013, 09:53 AM   #4
LCG's Avatar
Trade: Roofing/Siding/Seamless
Rewards Points: 272
I am not even going to get into which brand or type of roofing you should use. It is like beating your head against the wall. The thing with a roofer is you can prove to the point of redundancy and still not change his mind.
A few questions; Please answer!
Does the roof leak now?
Is the existing roof still in decent shape or is it curling and losing granules? You may not have to remove the existing. You might be able to fully adhere a fleece back to the existing BUR.
How many layers are on the existing roof?
What is the existing roof deck? Wood, metal, concrete?
If your choose to install a white EPDM your might as well go with PVC. They cost the same and you will have heat welded seams rather than sticky glue.
TPO will be cheapest way to go! I will not elaborate. You get what you pay for!
PVC is top end but only like recommending IB Roof Systems, Fibertite, and Sarnafill. The rest are not proven and none have 30yr results.
As far as the parapet. Easy... Roll your membrane up the parapet, over the top and down the exterior side a minimumm of 2" and install metal top cap.
I am assuming you are wanting to buy over the counter single ply. I don't know how JM PVC performs. Nobody else does either! It hasn't been around for 30 years so only time will tell. I am sure it will do OK?
LCG is offline
The Following User Says Thank You to LCG For This Useful Post:
Old 02-16-2013, 02:41 PM   #5
Nac's Avatar
Rewards Points: 324
Yes a small leak
It is the original roof about 22 years old it is dried out and cracked looking
The original roof 1 layer
Wood
My estimate for IB(45 mil & 1" iso)is about $5000 more than than JM (60 mil pvc & 2" iso)
Facebook
Nac is offline
Old 02-16-2013, 03:09 PM   #6
LCG's Avatar
Rewards Points: 272
I would assume the JM has a wicking scrim and will need to be sealed anywhere the seams are not factory cut. It has a lot to do with the chemical make-up of the actual sheet as well. Most PVC have a lot of plasticizer content and who actually produces the sheet.
I can't imagine the cost should be 5k different especially with a one inch difference in ISO. I have run into some pvc guys that try to under bid me by using EPs and a cheap cover board.
Honestly for 5k I think I would use the IB. I guess the only concern I would have is if the JM guy is certified. IB has such a proven track record and certified installers, it's hard to argue it. I would expect a TPO to be 5K less but a quality PVC costs money.
I guess it come down to the customer and budget.
I think I would skip the tear off and install a 4oz seperator sheet and install a 60mil IB mechanically attached over the existing roof. You could use 1-2" rigid ISO as a seperator sheet installed over the existing roof and spare yourself the expense of tear off. Unless the decking is damaged there is now reason to do a full tear off. It is a huge east of money!
Also. IB doesn't jack your warranty for not tearing off. You can still get the full warranty with an overlay.
Check out our Facebook page. Atlas Wyoming.com Facebook. And we have a picture of a little pizza place we did last December. It was an overlay with a 4oz seperator sheet.
Sorry if this post is a bit garbled but I am typing on my phone and trying hang trim at the same time. I'll try to spend a little more time on this after dinner. I can write you a spec if you want. I will take me like 15 minutes. Then you can see exactly what I'm talking about. Also it will help your contractors bid accordingly rather than the way they wish to do it. There are many different ways to skin this cat. Getting them all on the same page ensures an even playing field!
LCG is offline
Old 04-21-2013, 06:06 PM   #7
LCG's Avatar
Rewards Points: 272
What system did you end up using?
LCG is offline
Old 04-22-2013, 03:51 PM   #8
DFW Roofing's Avatar
Trade: Roofing
Rewards Points: 187
Many municipalities follow the energy code which requires far more than two inches of ISO above the roof deck (the code actually calls for a specific R value not inches)
DFW Roofing is offline
Old 04-23-2013, 09:51 PM   #9
mrcharles's Avatar
Trade: GC, Remodeling
Rewards Points: 1,652
They can't make you add R value to do maintenance replacement... If you were adding an addition then they can make you add R value
mrcharles is offline
Old 04-27-2018, 11:03 AM   #10
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 1,036
Exactly
madrina is offline
Old 04-27-2018, 11:04 AM   #11
madrina's Avatar
And 4.3 inches of iso
madrina is offline
Old 04-27-2018, 11:14 AM   #12
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 10,392
zombies...
SmallTownGuy is online now
The Following 3 Users Say Thank You to SmallTownGuy For This Useful Post:
A&E Exteriors (04-28-2018), Bull Trout (04-27-2018), Mr Latone (04-28-2018)
Old 04-27-2018, 11:14 AM   #13
Trade: Roofing
Rewards Points: 187
Not sure what you are calling "maintenance replacement"
It is my understanding if it is a overlay the Energy code does not apply - tear off and it does.
Municipalities can make their own rules and exceptions, things certainly can vary place to place.
Bert Roofing Inc
10021 Cayuga Dr
Dallas TX 75228
214-321-9341
Old 04-27-2018, 02:51 PM   #14
madrina's Avatar
Correct.
And I don't know what a maintenance replacement is either. I'm pretty sure that is a made up term.
madrina is offline
Old 04-27-2018, 02:54 PM   #15
madrina's Avatar
4.3 in is the thickness of the required r value
madrina is offline
Old 04-28-2018, 08:46 AM   #16
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,570
Likely there is insulation in the ceiling joists already, so the roof insulation is supplemental. And OP is mia so who knows.
Above all, a good roof
Mr Latone is offline
Joe Fusco's roof framing calculator bookmdanno Roofing 2 07-18-2012 02:41 PM
Flat roof material wadswob Roofing 23 06-18-2012 10:59 AM
Large residential roof Building1985 Roofing 34 06-24-2010 06:58 PM
Finding roof josts on flat roof? Chris G Roofing 5 04-21-2009 05:51 PM
