Removing Roofing Cement?
Old 07-26-2007, 11:57 AM   #1
Can't Post
sandyman720's Avatar
Trade: Construction
I had counter flashing that was installed into the mortar joint of brick and then glopped with roofing cement. What is the best way to remove this cement?
sandyman720 is offline
Old 07-26-2007, 02:59 PM   #2
Bah Humbug!
Grumpy's Avatar
Re: Removing Roofing Cement?
We usually chip it off with our hatchets and pry-bars, then when installing the new flashing we make sure to go the next brick up to cover what can't be cleaned.
Grumpy is offline
Old 07-28-2007, 01:25 AM   #3
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
If it is fresh roof cement, I would scrape nearly all of it off with a trowel of some sort, making sure not to stain the brick, and use a heavy duty citrus cleaner to get the residue off the metal.
http://www.roseroofing.net/
Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality!
Free roof inspections within 12 miles of our locale.
AaronB. is offline
Old 07-28-2007, 11:28 PM   #4
Expert Roofer
theroofinggod's Avatar
Trade: ROOFING/HOME IMPROVEMENTS-WINDOWS/SIDING/GUTTERING/COPPER WORK,ETC
Send a message via MSN to theroofinggod Send a message via Yahoo to theroofinggod
spray it w/ co2,and then tap it w/ a hammer,or do it when it`s already cold,citrus leaves some residue
theroofinggod is offline
Owens corning a solid strip of tar nolo Roofing 26 01-29-2008 01:25 AM
Approval/denial of roofing materials - questions jmasters Roofing 29 11-16-2007 08:09 PM
Reuse Cement tile roofing??? Jordcon General Discussion 0 08-14-2007 10:41 PM
drywall mud over cement? mudgirl Construction 7 07-20-2007 08:27 PM
Need help with removing metal fence post from cement red carpet Landscaping 3 11-28-2005 05:55 PM
