Re Roofing Curved Hockey Rink Roof - Page 2 - Roofing - Contractor Talk
Old 12-15-2015, 08:25 AM   #21
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
Re: Re Roofing Curved Hockey Rink Roof
$1,250 is not out of line it could need decking, added insulation ect.
Properly done metal is another option, we have one on our old shop a barrel roof like that, it was 20 or so years old before it developed problems, it's even the old nailed type.
1985gt is offline
Old 12-15-2015, 08:25 AM   #22
Donohue Const's Avatar
Rewards Points: 1,066
They make a continuous rib panel that I use on round roof barns
Works great for going around curves
Can get sheet close to 50' in length, I you can handle them that big
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
The Following User Says Thank You to Donohue Const For This Useful Post:
TimelessQuality (12-15-2015)
Old 12-15-2015, 11:34 AM   #23
Kylewillert's Avatar
Rewards Points: 2
I looked into coating but was not sure if it would work being that the tin job is so nasty. If I were to fix the tin is that an option. I will also look into the tin you spoke about. When working with a job that price I would like to see all my options
Kylewillert is offline
Old 12-15-2015, 11:40 AM   #24
PatChap's Avatar
Trade: Roofing, eaves
Rewards Points: 132
Why is the tin leaking? If its leaking because the panels aren't overlapped enough, you could try removing some screws and sliding panels underneath the upper and over the lower panel.
You could try one or ten spots and see if its a viable option.
PatChap is offline
Old 12-15-2015, 06:51 PM   #25
Aka clvr83
dDubya's Avatar
Trade: Roofing
Rewards Points: 256
True. I realize that I assumed the best scenario, when really I should know better than that in this business!
dDubya is offline
The Following User Says Thank You to dDubya For This Useful Post:
1985gt (12-16-2015)
Estimating with Excel for the Small Contractor YouTube cargin2 Business 123 01-13-2018 03:45 PM
i need roofing crews 5starroofing Help Wanted or Looking For Work 2 06-05-2012 12:21 PM
