Question About Insulation Under Torch-down Roof
Old 02-12-2004, 10:37 PM   #1
jack's Avatar
does anyone know if its necessary to install insulatIon under torch down if the roof goes over standard joist construction with R-13 fiber glass insulation
IS THIS A MANUFACTURES REQUIRMENT? Thank you.
jack is offline
Old 02-12-2004, 10:45 PM   #2
Bah Humbug!
Grumpy's Avatar
Re: Question About Insulation Under Torch-down Roof
Depends ont he manufacturer. We have installed Firestone APP on the roof deck many times. We use a double layer of base sheet always. It's my experience insulation is NOT a requirement in some applications but most manufacturers have their requirements on their websites. I know in some cases it is a requirements so let me rephase my answer:
It depends on the manufacturer and the application.
Grumpy is offline
Old 02-14-2004, 11:12 AM   #3
jmorgan's Avatar
Trade: Roofing
Our where I live, no one can get insurance to allow torch down anymore. You might check with you building dept. for ceiling insulation requirements. Out in my area it is R-38.
Jim
jmorgan is offline
Old 02-14-2004, 05:32 PM   #4
Bah Humbug!
Grumpy's Avatar
Not sure on the R value of typical roof insulations. We usually use 1 1/2" ISO board.
Grumpy is offline
Old 08-12-2004, 01:25 AM   #5
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Smile
I have been reading about the torch-down roofs as a replacement. What roof is going to be the best replacment for a tar and gravel roof at a dry cleaners- lots of equipment up on the roof, last the longest, not leak, be cost-effective and cut down on the heat in the cleaners? Pro-teck also looked interesting. Thanks! Susan
Old 08-12-2004, 12:00 PM   #6
Bah Humbug!
Grumpy's Avatar
Susan one word... SPF. I am not capable of installing it but it's about the best material when dealing with alot of penetrations. It also has insulation properties and lasts a very long time.
Grumpy is offline
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 09:10 AM
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 01:30 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
