Pulling Staples
Old 04-17-2007, 12:55 PM   #1
reveivl's Avatar
Trade: Renovations
Pulling Staples
Got a re-roof coming up, the ho says the old three-tabs were put down with staples.
My ?: Is it more work to strip the shingles with staples than with nails? How much more? Tks, Rich.
reveivl is offline
Old 04-17-2007, 04:28 PM   #2
JohnnyRoofs's Avatar
Trade: Roofing Contractor
Re: Pulling Staples
Staples on OSB on a walkable pitch is the dream tear off. Like rolling carpet. Ya know Imus just got in trouble for calling people ho's.
JohnnyRoofs is offline
Old 04-17-2007, 05:02 PM   #3
Commercial Roofing
AaronB.'s Avatar
Re: Pulling Staples
Then use a hook blade to pull the leftover staples...works like a charm.
http://www.roseroofing.net/
Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality!
Free roof inspections within 12 miles of our locale.
AaronB. is offline
Old 04-17-2007, 07:53 PM   #4
reveivl's Avatar
Trade: Renovations
Re: Pulling Staples
This roof is a shiplap deck so I guess it won't be like rolling carpet...hopefully the 'Red Ripper' will get them all, I was just wondering about whether it would take more time than nails.
Thanks for the input guys, and this ho IS actually 'nappy haired' but he's also as white as they come.
reveivl is offline
Old 04-18-2007, 12:04 AM   #5
3rd gen,it's in the blood
roofwiz74's Avatar
Trade: roofing
Re: Pulling Staples
if it's in 1x's they will lift one side.I take a pair of dikes or a junk pair of snips to them.If I'm roofing the same day I'll just pop some stapels in them.
You have ONE advantage over me.....you can kiss my butt and I can't!!
roofwiz74 is offline
Old 04-19-2007, 08:25 PM   #6
dougger222's Avatar
Re: Pulling Staples
On most houses I'd preffer to tear off nailed shingles rather than staples but there are so many variables it's a toss up. Pitch forkes under the paper to get as many nails/staples as possible and use the hammer to pull the staples (hook blades on staples in trusses means you just tossed 50 cents in the garage). If my guys are using anything besides a hammer on staples they go down to clean up. The toothed shovels seem to really work best for pulling nails after the pitch forks are run through. On some houses it seems that no matter how you tear it off every nail stays in the roof.
The worse job to tear off yet was a 100 yo fortress built with 26in walls that had two layers of shakes and a layer of nailed three tabs on top of that. The amount of nails in the 4-6in tall 2-3in gapped 1in decking was amazing. It took more time to pull the nails than the three layers of shingles.
Any solid 1 in decking and your going to be pulling out nails or staples a lot harder than osb or plywood.
I agree on a nice warm sunny day with fairly decent shingles that have sealed together with staples and junky osb and there are virtually no staples left on the roof and you can make as big as pieces as you care to carry. There have days were a helper and I have tore off 25sq's and pulled all fasteners before lunch.
Nothing is worse that shingles stuck down to Winterguard.
dougger222 is offline
New at Pulling Permits WTBt00ls Business 1 07-25-2007 02:36 PM
Pretty cool story about a forum pulling together for a member Nathan Off Topic (Non Trade) 4 07-12-2007 10:01 PM
Staples for log siding ? Bella D Windows, Siding and Doors 2 06-20-2007 08:09 AM
Tape or Staples Joewho Painting & Finish Work 12 03-08-2007 05:02 AM
Pulling old vinyl??? johnjamesalaska Flooring 5 01-05-2006 01:59 AM
