The Proper Way To Flash A Stucco Dormer?
Old 03-24-2013, 02:16 PM   #1
mastersplinter's Avatar
Rewards Points: 303
Hello, A customer had a new roof put on a year ago.It is leaking pretty badly There are 4 dormers on the back of the house done with stucco. What is the correct way to flash a new roof where the roof meets the stucco? Any pictures would be appreciated
I would think to cut a reglet with a grinder and tuck flashinginto this would be the correct way to do it.
The roofer bent the flashing with a 3/4 '' flare out from the stucco at the top of the flashing and pumped a few tubes of caulk in there. What would you do in this situation.
mastersplinter is offline
Old 03-24-2013, 02:48 PM   #2
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
Re: The Proper Way To Flash A Stucco Dormer?
If you are talking about roof to wall connections, and it has a comp shingle roof, you will need Z bar backing, step flashing, counter flashing and stucco repair.
Fix it right because once you touch it, you own it. Excuses will only make you look bad. If you are not willing to do it proper, walk away.
I recently repaired my own house where it was plagued with 40 years of bad repairs.
A reglet was cut into the stucco but the roof to wall flashing, step flashing and counter flashing was all wrong.
Made my newly finished family room job look like crap when it rained, leaked and bubbled up my new drywall, skim coat and perfect paint job.
I had no idea, someone would build a room addition onto an existing stucco wall and just cut a reglet. smear it with 208 and call it done.
btw, pictures would be a great help. Good luck.
skyhook is offline
The Following User Says Thank You to skyhook For This Useful Post:
Tom Struble (03-24-2013)
Old 03-25-2013, 12:08 PM   #3
aptpupil's Avatar
Rewards Points: 1,894
Looked at a job the other day for a guy who had a bay window that was added as part of a kitchen renovation. They didn't even bother to cut in a reglet, just put up a piece of flashing and caulked it. Problem with this is that the water that gets past the stucco (it always does) now drips down the felt paper and into the head jamb of the bay window.
If I'm reading the OP right, it sounds like the fix for these situations is the same. Break away the stucco and get flashing under the paper/housewrap so that water on that plain will go onto the new roof instead of into the house.
aptpupil is offline
Old 06-14-2018, 05:38 PM   #4
Kowboy
Kowboy's Avatar
Trade: Countertops
Rewards Points: 7,982
What say the collective wisdom here, please?
The proper way to flash a stucco dormer?-unnamed-2-.jpg   The proper way to flash a stucco dormer?-unnamed.jpg
Kowboy is offline
Old 06-15-2018, 12:48 PM   #5
Designer/Contractor
Rio's Avatar
Rewards Points: 2,066
We use step flashing from the shingles to the reglet (Z flashing).
Rio is offline
Old 06-15-2018, 11:13 PM   #6
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 11,382
I need more info
A&E Exteriors is online now
Old 06-17-2018, 05:10 AM   #7
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,570
What it boils down to is trying to do something that is always successful.
A strip of light gauge metal applied to the face of a wall (any type of wall) and sealed with caulk at the top edge works sometimes, but not always. One never knows when it will not work, but it is often enough that it is not "best practice"
The stucco or other siding material is effectively the counter-flashing so if a metal strip is applied (counter-flashing) it's best to be an integral part of the wall and should drain as effectively as the wall. Sticking it on the wall surface with caulk doesn't qualify as an integral part of the wall. Through convention, it has been decided that setting the metal strip in a ground out slot with caulking is preferable to just applying it to the surface. A "Z" type of flashing also drains as effectively as the wall, but may not be possible in a retro-fit
Some roof systems are designed with termination bars on walls where the roof terminates. These are a lot stiffer than some light gauge metal counter-flashing, and are accepted practice. The light gauge metal actually mimics that practice, so it's not that unusual to see.
Kowboy, the wall in your picture looks like it may be cement wall board with a textured finish (the outside corner looks that way). Cutting and installing a reglet flashing in a 5/16" wallboard isn't really possible without cutting all the way through. Short of having the flashing completely behind the wallboard (preferable, but may not be possible without removing wallboard), the face applied metal and caulk may be appropriate.
Above all, a good roof
Mr Latone is offline
The Following User Says Thank You to Mr Latone For This Useful Post:
Kowboy (06-20-2018)
Dormer Shed Roof, Barrel Roof, CutIn Dormer, Eyebrow Dormer sbebuilders Framing 33 04-18-2013 05:29 PM
Synthetic Stucco Repair....Grrr lukachuki Masonry 15 12-23-2012 09:48 AM
Stucco with mold Ohio painter Painting & Finish Work 5 08-10-2012 08:22 PM
Stucco on wallpaper... The best solution for residential buildings. aulona Wallpaper 10 07-23-2012 02:30 PM
New stucco meeting up with old MichaelNY Masonry 3 11-13-2008 06:25 AM
