PROPER Ventilation????
Old 03-05-2006, 07:35 PM   #1
Starboyz66ftp's Avatar
Trade: Roofer/Sider
i have heard so many opinions on proper attic/roof venting, i don't know what right anymore, combination wise, soffit and ridge only, soffit and box vent only, soffit and gable with no roof vent??? what are proper combos???
Starboyz66ftp is offline
Old 03-05-2006, 07:55 PM   #2
Teetorbilt's Avatar
Re: PROPER Ventilation????
Star, you just opened a can of worms without telling us where you are. I have ridge, soffit and gable end vents which is very unpopular with the roofing crowd. I later learned that the gable end vents are to relieve the pressure during hurricaines, I've been through 3 in the last 2 yrs. and the system must be working. The roof is still there.
Albert Einstein
Teetorbilt is offline
Old 03-06-2006, 12:31 AM   #3
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
You need one square foot of net free vent space of exhaust as well as one square foot of net free vent space of intake for every 300 square feet of attic floor space, passive ventilation only.
http://www.roseroofing.net/
Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality!
Free roof inspections within 12 miles of our locale.
AaronB. is offline
Old 03-08-2006, 07:19 AM   #4
River Rat Dad's Avatar
Trade: Roofing, siding, framing
AaronB's suggestion comes out to a ratio of 1:150. I would agree that more is better, AS LONG AS AT LEAST HALF IS INTAKE FROM THE EVES.
Some roof designs make balanced venting nearly impossible to achieve.
I think that in most cases a 1:300 ratio is OK as long as there is a vapor barrier under the insulation and half the venting is at the eve.
River Rat Dad is offline
Old 03-08-2006, 10:07 AM   #5
Bah Humbug!
Grumpy's Avatar
Ventilation is a science unique to the architecture of each building. While the forumulas for determining the volume of necessary ventilation are the same for each attic, the type of ventilation varies. Mushroom vents work great on some roofs while ridge vents are better on others. It all just depends on the architecture of the roof lines.
Grumpy is offline
Old 03-11-2006, 01:01 PM   #6
I have nothing more to add...except not to let Grumpy have the last post...
Old 03-11-2006, 04:25 PM   #7
Commercial Roofing
AaronB.'s Avatar
Actually, the 1:300 ratio formula also calls for 1 foot in and one foot out...a balanced system.
AaronB. is offline
Debating Attic Ventilation Pros and Cons Ed the Roofer Roofing 14 08-22-2007 03:21 PM
Do I still need to calculate ventilation? nolo Roofing 10 08-11-2007 12:02 PM
proper subfloor for tile kmd Ceramic & Stone Tile 17 03-03-2007 08:37 PM
Ventilation techniques darcar Construction 5 11-28-2006 04:32 PM
Proper Mountain Excavation Outfit theyachtman Excavation & Site Work 6 07-02-2006 01:54 PM
