Problem: How Do I Bulid Staging On A Metal Roof. Hmmmmm
Old 01-28-2008, 07:48 PM   #1
Lynch Masonry
Jack3185's Avatar
Trade: Masonry
Send a message via AIM to Jack3185
I cant think of any way of building staging on top of a metal roof, Other than building a structure to go over the peak and down the roof, and building on top of it. Any Ideas would be appreciated!
Jack3185 is offline
Old 01-28-2008, 08:03 PM   #2
Re: Problem: How Do I Bulid Staging On A Metal Roof. Hmmmmm
That's what I'd do too.
Be a little patient, don't keep posting
all over the place every 5 minutes.
You'll tick everybody off!
While you're waiting,
go back and edit your profile
to add your location.
It'll help everyone
if you're gonna hang around.
neolitic is offline
Old 01-28-2008, 09:30 PM   #3
Al Smith
A W Smith's Avatar
maybe you can rent one of these?
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-29-2008, 08:04 AM   #4
Bah Humbug!
Grumpy's Avatar
Down the street there is a masonry company doing some brick restoration on a rather tall church. Around the steeple, a good 20 stories I'd guess, they have had to erect scaffolding on the roof. What they did was hire a roofing company to removing the roofing tiles, lay down some rubber (EPDM) and then set their scaffolding on that.
All the removed tiles have been stacked and staged on the ground for later re-installation. You may consider doing the same. However you probably won't be able to re-use the metal. Ask a roofer who does metal roofing in your area what he suggest and mark his costs into your estimate. Also make sure the customer knows, which might seperate you from the competitors who will just nail into it and caulk the holes when done.
Grumpy is offline
Metal roof Affordable Home Roofing 24 04-25-2007 08:56 AM
truss spacing for metal roof ATS Construction 8 04-20-2007 10:17 PM
Metal roof cutting options Tonkadad Roofing 4 04-12-2007 08:22 AM
painting a metal roof mattp Painting & Finish Work 16 10-20-2006 07:29 AM
metal railing finish failed problem? a68cudas Painting & Finish Work 9 06-06-2006 03:37 AM
