View Poll Results: How do you guys deal with unknown wood replacement when pricing your proposals?
Give an open price on the proposal saying x ammount of wood will cost x dollars? 18 90.00%
Call the owner out to look at the roof after you have ti all torn off? 2 10.00%
Skip wood replacement and just starting nailing the shingles? 0 0%
Other 0 0%
Voters: 20. You may not vote on this poll
Pricing Wood Replacement
Old 10-16-2003, 07:53 PM   #1
Bah Humbug!
Grumpy's Avatar
Do you give an open price on the proposal saying x ammount of wood will cost x dollars?
Do you call the owner out to look at the roof after you have ti all torn off?
Do you skip wood replacement and just starting nailing the shingles?
Grumpy is offline
Old 01-10-2004, 04:26 PM   #2
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Re: Pricing Wood Replacement
I Just Tell The Customer That We Have To Wait Untill We Get The Roof Stripped Off Before Knowing How Much Wood Is To Be Replaced.i Then Tell Them Before We Start The Job That It Will Be 650.00 To Replace Each Sheet Of Rotted Wood Over Our Original Bid.that Way The Customer Isnt In For Any Surprises.
Old 01-11-2004, 11:57 PM   #3
Bah Humbug!
Grumpy's Avatar
$650 or $65? We charge $45 for a sheet of 1/2" 4 ply CDX or $2.5 per linear ft of 1" roof board.
Grumpy is offline
Old 01-12-2004, 12:28 AM   #4
Unregistered
Guest
Posts: n/a
youre in the wrong roofing area.we get 650.00 per sheet 1/2 inch anything!
Old 01-12-2004, 01:45 PM   #5
Bah Humbug!
Grumpy's Avatar
Well congratulations. There is no way in the Chicago residential roofing industry is anyone going to get over $120 for a sheet of wood. I know what my compitition charges and I know that the very highest end is $120.
Grumpy is offline
Old 01-12-2004, 05:46 PM   #6
pgriz's Avatar
Trade: Roofer
Grumpy, I think it's the same unregistered poster who thinks warranties are for the idiots. Given the level of expertise and knowledge shown by this poster, I don't think either you or I will find him (her? it?) much competition if we run across them in real life. You are dealing with reality, and the other is just blowing smoke.
pgriz is offline
Old 01-12-2004, 06:45 PM   #7
Bah Humbug!
Grumpy's Avatar
If he is charging 650 he is going to end up in jail for price gouging.
Grumpy is offline
Old 02-28-2007, 05:42 PM   #8
mattp's Avatar
Trade: roofing
At 650 a sheet I would sub out the roof and just come in to replace the wood. I charge about 30 for 1/2" CDX and labor
mattp is offline
Old 02-28-2007, 06:46 PM   #9
Thom
thom's Avatar
Considering a sheet of plywood is well under $10 and it takes about 15 minutes to remove a sheet (or partial) clean the rafters, cut and install the new piece, $30 is profitable, $100 bucks is gold, $650 and I don't believe you.
thom is offline
Old 02-28-2007, 06:54 PM   #10
Ed the Roofer's Avatar
Trade: Roofing Contractor
Since you pulled out an old thread Matt, I will respond in todays context.
The highest price I have ever seen listed on a competitors proposal was $ 4.00 per square foot, not identifying if it was OSB, 3-ply cdx, or 4-ply cdx, which was on an HD proposal from about 7 years ago on a job I acquired.
My current pricing is at $ 2.00 per square foot, for the better cdx choice, whether for R & R or for skip sheathing overlay.
Also, the unit price for a 1" x 6" starts at $ 3.50 per lineal foot, R & R, with the price per board lineal foot increasing proportionately with the larger sized boards. Although, per APA standards for reducing expansion and contraction, no larger than a 1" x 6" should be installed when butted together to create a solid deck surface.
Coincidently, does anyone here realize that the specification for overlaying cdx on top of the original skip sheathing, is to install it in the vertical direction, rather than the horizontal direction. I'm not saying I accept their ideology for that method, but that is what the specs regarding this circumstance dictate. Does this make anyone else here want to scream B.S. to that!!!
Ed
Ed the Roofer is offline
Old 03-01-2007, 04:01 PM   #11
mattp's Avatar
Trade: roofing
Ed,
How do you install horizontal or vertical? I've always installed it horizontal what is the reasoning for installing it vertical?
mattp is offline
Old 03-01-2007, 05:04 PM   #12
MattP,
Although the plywood specs on that one say to install the sheathing vertical, I have never, ever, seen anyone do it that way including our company.
The document I recieved was from Certainteed, which referenced some APA specification.
Their theory, if I remember correctly, was that it would diminish the amount of expansion of the joints by not being parallel to the direction of the previously installed skip sheathing.
When we install sheathing on top of the existing board decking, we snap chalk lines exactly center on the existing rafters, so that the nails penetrate through the existing 1" x ?"'s. Possibly, where I see most companies just nailing so that they hit the previous 1" bys, it may make some sense, but I really don't see how.
Ed
Old 03-04-2007, 09:44 PM   #13
Engineer/GC
EcoWise inc.'s Avatar
Trade: General Contractor/Engineer
We used to charge $45/ sheet, but we lost money. The plywood isn't much, but is holds up other progress. We are changing to $65/sheet.
Another roofer gave me the BEST idea I have heard.
When one section of the roof is stripped, the wood needing replacement is numbered in bright orange landscaper's spray paint, large numbers about 12 - 18 inches tall. We take a quick digital pic showing all the numbered sheets still on the deck. A Polaroid would work well too.
We replace the sheets & take another quick digital pic to verify the correct sheets were replaced & the numbers are gone.
We tell the homeowners about this policy ahead of time & they usually don't understand, but after they see the pics, they are very happy, it is totally obvious the work we did.
Retired Mechanical Engineer, GC, Member ASTM committees on Building Materials & Sustainable building,
Green Builder Certified,
RRP Lead Certified.
EcoWise inc. is offline
Old 03-04-2007, 10:39 PM   #14
Bah Humbug!
Grumpy's Avatar
I had to do that once on a government funded job. It was wirtten into the spec.
Grumpy is offline
New kind of Pressure Treated wood karma_carpentry Carpentry 23 08-21-2008 09:06 AM
Pressure Treated Wood rjordan392 Carpentry 4 05-28-2007 02:23 PM
deckboards replacement only - pricing help, West MI insub Decks & Fencing 7 04-22-2007 04:34 PM
Pricing for Dallas area??? TexSeal Painting & Finish Work 2 02-22-2007 01:15 PM
Wood people I need your help Floorwizard Flooring 11 05-18-2006 09:07 AM
