Powered Attic Vents - Roofing - Contractor Talk
Powered Attic Vents
Old 12-04-2015, 06:45 PM   #1
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 11,838
Powered Attic Vents
Finishing up a job and the house is a double envelope home. Weird design but cool. Homeowner is thinking putting in 2 large automatic power vents that react to temperature and humidity.
Any suggestions or expience?
A&E Exteriors is online now
Old 12-04-2015, 08:39 PM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,162
Re: Powered Attic Vents
Does the house have any other intake or roof venting?
overanalyze is offline
Old 12-04-2015, 08:43 PM   #3
Has some 8x16" soffit vents. Had 6 big pot vents 12x12.
Design says these houses don't need winter ventilation, crazy design. There is a crawlspace under the basement and a gap in the trusses with insulation above and below, with an internal "eave" that allows air to circulate around the house creating a thermal buffer.
Old 12-04-2015, 08:53 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 3,228
I built a house like this in 1978ish in Tahoe. Double north wall with a 16" space, two story house with a two story solarium that acted as the collector. Crawl space was super insulated and air circulated around the house. Wood stove for heat.
House worked great. Be careful about introducing too much air flow/movement that will disrupt the thermal effect of the air.
I had four low velocity fans in the top of my north wall that pulled the warm air from the solarium down through the double wall.
Had no problems with the place other than it was easy to get it too warm.
The house was destroyed by the Angora Fire at Tahoe.
griz is online now
A&E Exteriors (12-04-2015)
Old 12-04-2015, 09:08 PM   #5
That is exactly why the homeowners dad, an energy efficiency contractor buddy of mine want the power vents that automatically react to humidity and temperature
Old 12-04-2015, 09:09 PM   #6
And that sucks about the fire.
When the HO first looked at the house it was 95 outside and 75 inside....no AC
The Following User Says Thank You to A&E Exteriors For This Useful Post:
griz (12-04-2015)
Old 12-04-2015, 09:19 PM   #7
Fire up the BBQ
griz's Avatar
I'm just saying be careful with the high velocity.
Brain is fuzzy but it seems like I was advised not to use high velocity fans.
May have been to do with the winter climate & your situation is different.
Good Luck, curious to hear how it works out.
griz is online now
Old 12-04-2015, 09:25 PM   #8
Copy that, pretty wintery in Michigan...lol. I will pass that info along
Wasps Getting Thru Attic Vents IowaBucks Roofing 7 03-15-2015 07:30 PM
Com Bus groud to 120V powered box Question Richard_N_S Low Voltage 0 06-14-2012 11:58 AM
Attic vents Worm Drive HVAC 7 04-28-2009 09:48 PM
Any experience with solar powered attic exhaust fans? vestaviascott HVAC 1 04-23-2009 06:59 AM
Frost inside the attic? SOSSW Roofing 22 04-03-2009 07:26 AM
