Plywood Buckle
Old 05-30-2012, 06:59 PM   #1
Newb
roofny's Avatar
Trade: Roofing and Siding Contractor
Rewards Points: 99
Plywood Buckle
Shown are 3 photos from an estimate/inspection I was at. The structure is less than 10 years old. The rear roof plane is buckling plywood all over - to the point where it lifted drip edge 2" off the roof.
The facts:
-4:12 pitch
-Full Ice and Water, OC Duration shingle
-No leaks.
-Soffit ventilation (not perf soffit, vented through ribs only) and baffles in rafters.
-OC rolled ridge vent, cut to show 1" on each side of LVL ridge beam.
-All nails showing rust in attic.
-Plywood stapled, 16" O.C.
-Sufficient attic insulation.
-Heating system in attic.
I am thinking it's a combination of a lot of things but would truly like to hear some others thoughts.
roofny is offline
Old 05-30-2012, 07:05 PM   #2
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,411
Re: Plywood Buckle
Staples and plywood are a bad combination. 3 ply plywood is the worst. Having the heating system up there certainly adds to the problems, especially with moisture.
Warren is online now
Old 05-30-2012, 07:48 PM   #3
jstanton's Avatar
Trade: carpentry
Rewards Points: 212
Re: Plywood Buckle
We fixed a similar problem 3 years ago. The addition had no heat except a fire place. Probably 60% of the nails missed the rafters.
They also only had 1 row of baffles and it was cathedral for 6 ft. We added the baffles and nailed the plywood. I went back about 6 months ago for a chimney issue and it looked great. The chimney issue was a waterproofing the old brick. The addition was about 7 years old when we stripped it.
The big problem was the 4ft seams. The missed the first 2 or 4 nails and the seams were rolling up. (which matches your pics) I would guess missing fasteners and staples are a bad idea.
Joe
jstanton is offline
Old 05-30-2012, 07:57 PM   #4
jstanton's Avatar
Trade: carpentry
Rewards Points: 212
Re: Plywood Buckle
Oh and a bunch of seams didn't break on the rafters by the end of the run. It was a while ago the pics brought some thins back.
jstanton is offline
Old 05-31-2012, 06:56 PM   #5
Newb
roofny's Avatar
Rewards Points: 99
Re: Plywood Buckle
This does seem simmilar. I didn't think it was any 1 thing in particular, yet all (staples, needs more vent, heating system).
roofny is offline
Old 06-01-2012, 09:45 AM   #6
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
Re: Plywood Buckle
we have all seen the piles of warped plywood at the yard so why do people think a few nails will hold it flat?
about 16 2" screws along with the gun nails and the above probebly wouldnt have happened
Red Adobe is offline
Old 06-01-2012, 09:56 AM   #7
fourcornerhome's Avatar
Trade: home improvement contractor
Rewards Points: 520
Re: Plywood Buckle
You don't need screws to fasten plywood, but this would never happen if the plywood was installed and nailed correctly.
fourcornerhome is offline
Old 06-01-2012, 08:58 PM   #8
Roofer
FerrisHI's Avatar
Trade: Roofing
Rewards Points: 77
Re: Plywood Buckle
We put plywood on the time with just nail guns all the time with no problem...screwing down plywood seems unneeded...JMO
FerrisHI is offline
Old 06-04-2012, 08:37 PM   #9
C.I.R.C.'s Avatar
Trade: General contractor
Re: Plywood Buckle
YOU SAID THAT ALL THE NAILS WAS RUSTED ON THE UNDERSIDE OF THE SHEATHING AND THAT THE HVAC SYSTEM WAS IN THE ATTIC. I WOULD PROBABLY SAY THAT IN THE WINTER WHEN THE ATTIC SHOULD BE COLD. ( and as u probably already know that the attic needs to stay the same temp as the outside air or as close as it can be in the winter) U PROBABLY HAVE A LEAK IN THE HEAT RUNS OR IN THE TRUNK LINE. WHEN COLD AND HOT MEET IT WILL CAUSE ALOT OF MOISTURE AND CONDENSATION CAUSING THE PLYWOOD TO BECOME DAMP AND WARP. EVEN THOUGH IT SOUNDS LIKE U HAVE PLENTY OF VENTILATION. I WOULD CHECK THE HEAT RUNS AND MAKE SURE THEY ARE INSULATED WELL ALONG WITH THE TRUNK LINE.
C.I.R.C. is offline
Old 06-05-2012, 01:26 PM   #10
TimNJ's Avatar
Rewards Points: 2,452
Re: Plywood Buckle
Plywood, D/F or yellow pine? Yellow pine will curl up if you spit on it.
May also be no gaps left for expansion/contraction.
TimNJ is offline
Old 06-05-2012, 08:52 PM   #11
Newb
roofny's Avatar
Rewards Points: 99
Re: Plywood Buckle
Hmmm, I don't know. How can you tell which it is?
roofny is offline
Old 06-06-2012, 06:21 AM   #12
TimNJ's Avatar
Re: Plywood Buckle
Look for the stamp on one of the sheets. The color tone of the wood, and most three ply is yellow pine, most 5 ply is doug fir.
TimNJ is offline
The war of plywood VS particle board Jimmy Cabinet Kitchens & Baths 47 09-18-2012 07:52 AM
Painting exterior plywood wall sheathing hiphi45 Painting & Finish Work 4 12-23-2011 01:11 PM
Plywood vs particle board CarrPainting Roofing 27 07-14-2010 11:14 AM
Humidity and Plywood Swelling Splinter Finish Carpentry 19 07-08-2009 09:41 PM
Plywood over particle board PA woodbutcher Flooring 5 03-11-2009 06:09 AM
