Permit Inspection
Old 06-18-2018, 10:58 AM   #1
mygeggie's Avatar
Trade: roofing
Rewards Points: 14
Permit Inspection
After we did a tearoff/reroof, City tells us that an inspection was required PRIOR to applying any felt or I&W shield. They wanted to look at all of the plywood decking.
We didn't see this on the permit.
They now want us to tear off our new roof so they can inspect all of the decking.
Anyone run into this?
What did you do???
Thanks.
mygeggie is offline
Old 06-18-2018, 11:56 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,300
Re: Permit Inspection
New to the trade?
Always know how deep the water is before you jump in....
griz is online now
TNTSERVICES (06-18-2018)
Old 06-18-2018, 12:01 PM   #3
mygeggie's Avatar
Trade: roofing
Rewards Points: 14
nope.........51 years
mygeggie is offline
Old 06-18-2018, 12:22 PM   #4
SPG's Avatar
Trade: Don't take trades, cash only.
Rewards Points: 422
No cover is SOP for new construction around here, but on a reroof? ...and they want you to tear it off? Yikes.
SPG is offline
Old 06-18-2018, 12:25 PM   #5
Fire up the BBQ
griz's Avatar
Does the permit actually call out a deck inspection on a re-roof?
griz is online now
greg24k (06-18-2018)
Old 06-18-2018, 12:46 PM   #6
General Contractor
greg24k's Avatar
Rewards Points: 7,422
Is there an attic? they can inspect plywood from bellow...I doubt they will be climbing on top to inspect the roof.
Around here you have to call for sheeting inspection on new construction, some towns want you to hold off on the roof until the inspection, some towns let you put the roof and they check from bellow during framing inspection.
As existing re-roofing job goes, they never inspected the deck, you call them for a final inspection when they come out they only do a drive by.
Now you no longer need a permit for a re-roofing job on existing single-family homes, only on attached dwellings.
This is the perfect example to find out what inspections they require prior starting any job if you never did work in that town.
Good luck I hope they ease up and let you slide this time.
greg24k is offline
Old 06-18-2018, 03:18 PM   #7
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 3,884
Round these parts its normal to inspect the roof deck, they look for ring shank nails and the "H" clips, but if you missed that inspection you can fill out a "Contractors Affidavit" stating that its built to code.
On a reroof in these parts most times you have to add nails for the deck to be code compliant, roof inspectors may come to the job twice in one day once for the deck and then the dry in.
Still "Shakin" the tree boss
sunkist is offline
Old 06-18-2018, 05:34 PM   #8
rrk's Avatar
Rewards Points: 2,094
I know an inspector here who used to demand to have the roofer remove a 4 ft square of new roofing so he could check the plywood, paper and shingle nailing. He would choose the spot of removal. If he was so interested he could have just stopped by when the roof was stripped.
The way they got him to stop was not let him use their ladders to get to the roof.
If your inspector is still adamant about checking offer him the same situation, pick a spot and you remove the shingles.
rrk is offline
Rio (06-18-2018)
Old 06-18-2018, 06:19 PM   #9
Donohue Const's Avatar
Rewards Points: 980
that's how our inspector is
I couldn't get a hold of him, rain was coming so I papered a garage we built
when he showed up the next day, he wanted it all off so he could inspect our nail. we didn't have any missed nails that you could see from underneath so he said we must not of put enough in.
so basically if we would of done a ****ty job and missed a bunch of trusses when nailing, then he would of know that we were using the right amount of nails!!
I said I wasn't tearing it all off. he let us cut open small 4x4 area on each side so he could check the nails.
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
Old 06-18-2018, 06:25 PM   #10
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,187
Tell him to f##k off!!!! Thatís usually pretty effective for me!!!!
Jay hole is online now
The Following User Says Thank You to Jay hole For This Useful Post:
greg24k (06-19-2018)
Old 06-18-2018, 09:19 PM   #11
TimNJ's Avatar
Rewards Points: 2,806
Ask him is he has proof of liability insurance.
Otherwise he isn't allowed on your roof.
TimNJ is offline
The Following User Says Thank You to TimNJ For This Useful Post:
rrk (06-19-2018)
Old 06-19-2018, 04:37 AM   #12
General Contractor
greg24k's Avatar
I remember in the early 80s when inspectors wouldn't get a nice Christmas gift they attempted to climb roofs to bust chops until a few builders kicked the ladder from under them, and I guess the word gets around quick since then I haven't seen anyone climb a roof... Except I was doing a basement remodeling and one inspector came with his own step ladder to check things out above the drop ceiling.
greg24k is offline
Do you ever pull a permit for a home owner? Cricket General Discussion 25 08-20-2017 01:23 PM
city building permit red_cedar Construction 33 03-23-2015 02:59 PM
Heat Exchanger Inspection Methods Symposium MechAcc HVAC 3 08-15-2009 01:10 PM
How long do you get permit records? deckman22 Decks & Fencing 9 08-05-2009 12:06 AM
Soliciting work from issued permit lists Constructive1 Marketing & Sales 8 03-31-2009 07:53 AM
