Painting A Terra Cotta Tile Roof?
Old 12-13-2006, 01:31 PM   #1
xoroniox's Avatar
Trade: cabinet installer
It is a 6year old terra cotta clay tile roof looks weathered, grey/dirty. What are the pros/cons to painting the roof vs pressure washing? Thanks
xoroniox is offline
Old 12-13-2006, 03:06 PM   #2
Squrtgun's Avatar
Trade: Pressure Washing
Re: Painting A Terra Cotta Tile Roof?
Before slapping paint on a tile roof,why not contact someone who can clean them?Often times a no pressure cleaning method is alll that is neeeded to give a roof that refreshed look.
Squrtgun is offline
Old 12-14-2006, 07:58 PM   #3
Ed the Roofer's Avatar
Trade: Roofing Contractor
If in fact you are speaking of a true clay tile, and re-coloring is required, then contact the manufacturer for advice. Ludowici comes to mind, which I believe is a subsidiary company of Certainteed.
If it is the more commonly installed tile material, concrete tile, then a concrete/cement "Stain" would be preferable. Once again, if you can determine the manufacturer, then contact them.
Also, if you do find out who the manufacturer is, check and see what their warranty coverage, if any, is for coloration defects. They may be responsible for the re-coating of the materials for you.
Even if it is just a fungi type growth, you should still contact the manufacturer or a concrete/cement or clay manufacturer to see what types of cleaning agents may be used without adding to further color aesthetic concerns.
Ed
Ed the Roofer is offline
Metal Roof Painting Smoothy Roofing 7 10-27-2010 09:26 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
painting a metal roof mattp Painting & Finish Work 16 10-20-2006 07:29 AM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
