Paint Over Asphalt Shingles? - Page 2 - Roofing - Contractor Talk
Old 08-20-2011, 05:59 PM   #21
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,578
Re: Paint Over Asphalt Shingles?
Originally Posted by Stephen H View Post
........but it wasn't all that long ago that almost all shingles were "organic"
best wishes,
stephen
Exactly correct.
Not quite as tasty as the veggies from the organic farm stand down the street.
BTW the demise of the "organic" shingle was compromised asphalt blends and inferior quality paper mat due primarily to cost consideration. So goes the way of the world.
Mr Latone is offline
Old 08-20-2011, 09:46 PM   #22
JWRoofing's Avatar
Trade: State Certified General & Roofing Contractor
Rewards Points: 25
In my area, it is actually a code violation to paint over shingles. I have seen dozens of roofs fail shortly after the shingles were painted with elastomeric. Water was trapped under the shingle and caused the nails to rust. So personally I would avoid doing it if you are in a high rain or humidity area.
JW
____________________
Doral Roofing - Miami Roofing
JWRoofing is offline
Old 08-21-2011, 12:08 AM   #23
DRIFT-O-MATIC's Avatar
Rewards Points: 25
[QUOTE=JWRoofing;1267025]In my area, it is actually a code violation to paint over shingles. I have seen dozens of roofs fail shortly after the shingles were painted with elastomeric. Water was trapped under the shingle and caused the nails to rust. So personally I would avoid doing it if you are in a high rain or humidity area.
JW
JW, is the problem of the water being trapped, because the edges of each shingle is sealed down against the underlying shingle, or is it because moisture can't permeate through the asphalt shingle itself? I didn't know that moisture could penetrate through the shingles. I always thought it was escaping out through the seams and lap joints.
DRIFT-O-MATIC is offline
EPA Lead Based Paint Certification Training THIS MONTH--Indianapolis ChrWright General Discussion 14 11-16-2011 05:36 PM
opinions/help shingles are falling off roof kuby Roofing 2 11-02-2010 09:40 PM
Aura Paint Review (Matte Finish) DeanV Painting & Finish Work 43 05-06-2010 08:45 PM
Fiberglass Shingle Vs Asphalt Shingles? gucci Roofing 9 07-12-2008 10:46 AM
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
