Owens-Corning Architect 30's
Old 08-21-2007, 06:41 PM   #1
VA Remodeler's Avatar
Trade: Remodeling and Repair
Bought a few bundles of O-C Architect 30 roof shingles last night and noticed that they are the new larger size instead of the standard 12 X 36 inch shingles.
Is this the way they all are now or are the standard size ones still available?
No one could answer my question last night at the box store.
Any info would be appreciated.
VA Remodeler is offline
Old 08-21-2007, 09:21 PM   #2
nolo's Avatar
Trade: google
Re: Owens-Corning Architect 30's
They are metric. You will have a 5 5/8" exposure instead of a 5" exposure. The shingles measure around 39 1/4" long. If your area sells metric, you won't be able to get them in standard. I like metric better. There are less shingles to lay. Just snap your lines at 5 1/2 in increments instead of 5 5/8 in. It will save you some aggravation.
nolo is offline
Old 08-22-2007, 12:55 AM   #3
747's Avatar
Just for the record. Its my understanding all the roofers here think OC Sucks.
747 is offline
Old 08-22-2007, 07:55 AM   #4
Appreciate the info.
nolo,
Good tip on the 5 1/2 increments.
747,
Interested in knowing more about O-C quality.
I have a story about them that is pretty much positive, altho it was many years ago.
Old 08-22-2007, 12:12 PM   #5
nolo's Avatar
Trade: google
nolo,
747,
I have a story about them that is pretty much positive, although it was many years ago.
Everyone has their own opinion on which brands they like. You will never find a clear cut leader that everyone agrees are the best. Some think GAF, certainteed, etc.. You can do a ton of research and you still will not find an answer. I think if you go with GAF, Certainteed, OC, or even Tamko you will be just fine. The nail line sucks on OC though, unless you can get a batch with the new surenail technology. It doesn't have much tolerance. If you are hand nailing this will not be a problem.
nolo is offline
Old 08-22-2007, 05:44 PM   #6
747's Avatar
nolo,
747,
I don't know why but i can honestly say the guys here don't like oc. I would say they like....Tamko Heritage....Gaf......Finally Elk guys up in like minnesota like elk.
Example Grumpy and ed the roofer Tamko heritage i would say is there most prefered shingle..
747 is offline
Old 08-22-2007, 06:55 PM   #7
Ed the Roofer's Avatar
Trade: Roofing Contractor
After Tamko, I also like the Certainteed Independance as an upgrade option and the Landmarks are in the same category as the Tamko Heritage line, at least price wise.
For a unique cottswald cottage like effect, I like the Elk Capstone, but they are time consuming to install correctly.
CT specs seem to be a little more continuous from one bundle to the next. There was a slight misalignment with the sawtooth portion of the laminate on the Tamkos a couple of years ago on several jubs where it jumped out at me, but was not apparent from the ground.
Ed
Ed the Roofer is offline
Old 08-22-2007, 07:03 PM   #8
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
I have seen problems with all of them, but Cetainteed has the least. Almost zero problems with Landmarks. Had most problems with GAF. I have only used the OC multi-layer once and they seemed to be much better than GAF, and close to Certainteed and Elk. I have no idea on the long term with OC.
Guys using Elk and GAF should buy them up while they are cheap right now. They are changing all the shingles over to new bags and everything. Will be GAF/ELK.
MJW is offline
Old 08-23-2007, 01:29 AM   #9
Expert Roofer
theroofinggod's Avatar
Trade: ROOFING/HOME IMPROVEMENTS-WINDOWS/SIDING/GUTTERING/COPPER WORK,ETC
Send a message via MSN to theroofinggod Send a message via Yahoo to theroofinggod
I don`t like O.C. due to excessive loose granules and w/their super sealant,a lot of the time it`s very hard to separate the shingles in the bundles--I like GAF,TAMKO,and CERTAINTEED,ELK had problems here w/the prestique line years ago(80`s),and I haven`t used them since that time,I do have friends in other areas that will use nothing else----standard and metric sizing is usually area specific-NY most is standard size shingles
theroofinggod is offline
Owens Corning Basement System opinions shingler Construction 15 06-01-2009 12:27 PM
Owens corning a solid strip of tar nolo Roofing 26 01-29-2008 01:25 AM
Owens Corning shingle Recall RooferJim Roofing 2 06-26-2007 11:48 PM
New Owens Corning Alpine Pro-Fit Veneer pmbarber Masonry 8 05-20-2006 01:42 PM
Owens Corning Architectural Shingle Recall cliffykat Roofing 0 06-05-2005 11:24 AM
