New Ridge Vent Installed Correctly?
Old 03-21-2007, 07:38 PM   #1
itwerx2's Avatar
Trade: material distribution
Greetings- I went up into the attic space to see what the new ridge vent looked like from the inside. I cannot see any opening or even light coming in up along the ridge. Is this the way it should be ? Should I be able to see the vent itself or at least some light coming in? (Also FWIW, , the new soffit vents are still full of insulation. Also the shingles and opening over the ridge vent outside are very uneven and sloppy.) Comments appreciated. Thanks.
itwerx2 is offline
Old 03-21-2007, 08:06 PM   #2
Ed the Roofer's Avatar
Trade: Roofing Contractor
Rewards Points: 2,054
Re: New Ridge Vent Installed Correctly?
The manufacturer of each ridge vent product will have their own specifications on how wide the slot along the top of the ridge must be cut, and that varies if their is a ridge beam in place versus truss construction.
Typically, it is about 2 1/2 to 3 inches wide, measuring horizontally across from one side of the cut to the opposite cut side.
The opening should be 100 % unobstructed, although realistically, a slight jagged cut on the top course of shingle would be likely to occur.
The clogged soffit ventilation completely thwarts any intake funcionability that the intake vents were designed to allow.
You need to know how many square inches of NFVA exhaust per foot that the brand of ridge vent installed provides and the NFVA of the soffit fresh air intake should be at least equal. The product manufacturers literature and/or website should provide you with the correct specifications.
Don't get all hyper if the deviation is just a small amount out of specified parameters.
The ideal scenario is 60 % intake NFA to 40 % exhaust NFA, or at least a 50 % equal split between the two systems.
Some ridge vent products may not seemingly allow light to be visible, while other products may seem as if too much light is coming through. Neither is an indication of the proper functioning of the ventilation product. That is soley determined on the amount of free air space provided for the vent to function at its maximum designed capacity.
Ed
Ed the Roofer is offline
Old 03-27-2007, 01:07 AM   #3
3rd gen,it's in the blood
roofwiz74's Avatar
Trade: roofing
Rewards Points: 250
I had something to say,but.....
You have ONE advantage over me.....you can kiss my butt and I can't!!
roofwiz74 is offline
Old 03-27-2007, 01:39 AM   #4
747's Avatar
Rewards Points: 1,000
Nobody can answer the ridgevent question without actual eye inspection. But the soffitts vents need to be free from ANY INSULATION OBSTRUCTION. They need to breath. So get the insulation out of the soffit vents.
747 is offline
Old 04-01-2007, 11:05 AM   #5
PA woodbutcher's Avatar
Originally Posted by itwerx2 View Post
(Also FWIW, , the new soffit vents are still full of insulation. .
No baffles?
PA woodbutcher is offline
Old 04-01-2007, 12:23 PM   #6
Even if baffles, also known as rafter vents, are installed, the loose accumulation of insulation over the intake vents must be hand removed prior to closing up the area.
Ed
Old 04-01-2007, 04:38 PM   #7
...jammin
slickshift's Avatar
Trade: Rock Disciple
Rewards Points: 2,000
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Signature Quote
slickshift is offline
Do I need a ridge vent? jritkes Roofing 17 01-12-2013 11:17 PM
ridge vent versus traditional vents signal15 Roofing 16 02-11-2011 05:16 PM
Ridge vent issues? apkole Roofing 4 05-08-2007 06:46 PM
Whats the purpose of a ridge vent? Magnettica Roofing 22 04-22-2007 05:16 PM
Which ridge vent to use Tommy V Roofing 16 03-06-2006 05:38 PM
