Trade: sun rooms and room additions
Need A "flat" Roof Guru...
Ok, this is my own home. I've asked two commercial roofing companies to come look at my roof and neither showed. Not many flat roof companies close to us.
Top photo shows most of the three level roof, both lower sections look better than the center. Photos of corner show the wavy areas of concern. This roof is about 15 years old. Roof does not leak and looks pretty decent. My questions are about the small gaps around the copper flashing at the edges of the roof, and the two areas that the tar seems to be bubbled up a little and not even like the rest of the roof. I'll post some additional pictures in the next post. I'm not opposed to a new roof if needed, but I'm in no hurry if a little prevention will keep this one going. Do not intend to wait until it leaks to replace it, want it done before it's raining inside. Any suggestions on small things I can do, or do I need a pro? Thanks, Bill |
Re: Need A "flat" Roof Guru...
Two top pictures show the small gaps at the copper flashing.
Last photo shows where lower roof meets upper roof, there is some alligatoring of the asphalt/tar in those areas. |
Just from the photos it does not look like you need to do a new roof right now. I would address the openings with flashing grade cement, any larger gaps you may add mesh as well. There are also full roof coatings that are available, do some research, a full coat job will add a couple of years under ideal conditions. Good luck G
| The Following User Says Thank You to genecarp For This Useful Post: | Bill Z (09-27-2009) |
Trade: Siding, Metal Roofs, and Beer Drinking PRO
Ive had a few so..... looks ok but Id stay off it. If its just what your showing in the pics your concerned on then heres what id do (from a ladder)
sweep the rock back n hose or powerwash the tar good Get a bucket of non fibred tar and leave in sun for the afternoon use a weedburner and heat said tar and the curb apply tar , mesh,and smooth (without burning yourself) after it cools a day then pull rock back up fixing leaks in the field is where the problem is......first being walking up there to try and find it and only gets worse from there esp on an older roof. I USED to have a flat roof , it had 3 layers i know of and i could fix 1 leak and make another just walking up there. 3 years of that and it's ptched and metal now |
Builder/Remodeler
Where are you in Indiana Bill?
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here |
Commercial Roofing
Trade: Roofing Contractor
Roof cement wont work, mesj wont work, coating this roof wont work, non-fibered tar wont work, don't use the weedburner if you dont know how, stay off the blisters, and dont listen to remodelers about your roofing... most of those that do roofing end up calling a pro to do it right.
http://www.roseroofing.net/ Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality! Free roof inspections within 12 miles of our locale. |
I like Green things
Yeah, That picture seems familiar.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
#8 | |
Re: Need A "flat" Roof Guru...Quote:
http://www.canamcoating.com/roof_coatings.htm
Builder/Remodeler
Re: Need A "flat" Roof Guru...Unless the remodeler has contacts with professionals who repair and replace flat roofs...
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here Last edited by ChrWright; 09-28-2009 at 09:13 AM. |
Handle It!
The gaps can be repaired, not permanently, but remedied QUITE well with NP1 or GEOCEL 2300.
The application process is PARAMOUNT to the longevity of the fix. You can use a bitumen primer to help in the adhesion (this is NOT a standard practice, but it has served well for me in the past) ![]() http://www.amsisupply.com/graphics/s...-np1-large.gif ![]() http://www.geocelusa.com/core/prdb/p...ll_image_7.jpg
Something to One may be Nothing to another! Ultimate Wisdom--------- http://www.youtube.com/watch?v=OW-cnizLDEE Last edited by MALCO.New.York; 09-28-2009 at 08:06 AM. |
Bah Humbug!
I believe that this roofis beyond its' useful life and needs to be repalced. Can it be nursed? Sure but nirsing a tar and gravel roof in poor condition is most often a frustrating exercise in futility.
There's just so many problems and so many patches... it's time. If you called me out to estimate that and wanted a repair all you'd get is a price to do it right, a new roof. I am not opposed to do repairs. We do alot of repair work, it's lucrative fixing other peoples' mistakes. However I'm also not a theif and to repair that roof and take your money would be thievery. It might not be leaking now but does it make sense to replace a roof or replace a roof and ceiling? |
#12 | |
Roofer
My professional, 30 yr educated guestimation, based on what I see in those photo's is to say you could repair the roof, would it last weeks, months or years, I can not say with out physically being on the roof to inspect it myself. I can say, I have repaired flat roofs that looked worse and extended the life span by years.
Commercial Roofing
Where would someone adhere the mesh to cover the cracks at the outside edge of that flashing? Down onto the face?
I say remove the cover stripping . clean and prime the meatl, and re-strip it in.
#14 | |
Bah Humbug!
I've seen just far too many failed repair attempts on roofs like that, plus my own track record of repairing gravel surfaced roofs is a poor one to be honest. While on a smooth surfaced membrane I'd give myself an 8% success rate of diagnosing the problem, on a roof like shown in the photo I'd drop that diagnosis rate to 50% or below. Plus when you've got a roof with so many problems, it's hard to guess which ones are causing the actual symptoms/leaks (in this case it's not leaking yet). Unless you repair everything that's wrong with the roof... but then if you are going to go to that length, why not just replace it? In addition to failed repair attempts on any roof. When I see globs of roof cement all over the roof I have little faith in its' repair potential. Either the roof cement was installed when the roof was new (which from those photos I doubt) which means that the roof is a poorly installed one IMO, or what ever the dope happy handy man put up there did not work and he either did it wrong or mis-diagnosed the problem. Water travels and seeing a leak inside doesn't mean it's coming from where the leak is seen (but any roofer already knows this). However how many times do we focus, or the customer focuses on the area because it was repaired there once before. I dunno, I just think with so so many red flags, I am ultra cautious when it comes to my work, I say replace it. It's a win-win situation for myself and the customer IMO. |
#15 | |
Wow, this thread has gotten alot of attention, and has gotten a bit off track at the same time, first off lets remember, this guys roof is NOT LEAKING. As far as "if you touch it , you own it" only if you are an idiot new to the game, I have, many times over the years been brought in to fix flat roofs. Sometimes they are large and expensive to replace, if i identify problem areas i will offer the customer the option. The Ho assumes the risk, i give no gaurantee for the obvious reasons, 60 to 70 % of the time i will repair the problem enough to buy the HO a little more time. As soon as a thread loses the focus of the original post, it becomes nothing more than confusing mess. G
Bah Humbug!
In the customer's mind it's always the last guy to touch it's fault. "it didn't leak before." and I agree "only if you are an idiot" which is why I wouldn't touch it... because I've been there done that and not looking to be married to a 20 year old failing roof. Yes it hasn't failed yet, but it's right around the corner based on those pics.
I offer no guarantee on repairs either, however that doesn't stop the customr from calling you, guilt tripping you, threatening you. It's a hassel that I do not need. Sure I need work just like the other guy but I need less problems more than I need more work. If I'm gona do it, I'm gonna do it right and replace it. If they can not afford it, I can't afford to let them make their problems mine. Win some, lose some, but why would I intentionally go into a project knowing there is a high risk of problems on the back end? |
Trade: roofing
What a great thread.. Even if nothing is solved, you definitely get a feel for how contractors would approach this job.
Lots of assumptions here being made off of photos without actually stepping on the roof as some have said. You can tell who has been around the block though .Personally, I am with Grumpy based on the photos. |
#18 |
Roof Gurus,
Thanks for all the responses. I tend to agree with both points of view, the roof is on the way to failure and I want to catch it before that happens. Considering the state of the economy, I may be better off to bite the bullet now and get the roof done before prices rise due to increases in materials as the economy heats up. I did have a guy out 5 years ago, who said it didn't need replaced, just a few tweaks that I preformed. Until I looked for the papers he gave me, I was thinking that was 2-3 years ago, but it was five. It is time now. I'm sure this roof is at least 15 years old. I've been very pleased with it since I bought the house 10 years ago. I clean the roof 2-3 times per year of fallen limbs, leaves, etc. Clean out the downspouts and all is well. To take the conversation a little sideways, now that we know it should be replaced, another built up or some of the new fangled stuff? Is there a tax credit for changing to white? If so, max $1500 or 30% of everything? Might as well get the low-down from you roof gurus while I have your attention! Thanks, Bill Added a couple more photos. I'll probably replace the skylights while I'm at it. |
#19 |
Roofer
That's why I have been pushing my Preventative Maintenance program the past 6/7 years, really have gotten into it the past two years. To many roofs being replaced to soon simply because so many roofers out there do not know how to revive a roof and give it years of extended life or simply do not care to because there is more money in re-roofing them. (That comment is not directed toward any one person, speaking of roofers in general) You for sure have done more than the average home owner, but, keeping it cleaned is only one of several steps a roof system needs to make it to and in many cases even exceed it's expected life span. Under my care that roof would be replaced when it's 25 plus years old, not when it's less than 20. I personally have steered away from built up roofs over the past 10 years or so because the single ply systems have really evolved quality wise and normally involve less labor and equipment use than in a bur. ABC Supply has links to several manufacturers sites so you can read up on both installation specifications and expected life spans.
| The Following User Says Thank You to Slyfox For This Useful Post: | genecarp (09-28-2009) |
#20 | |
Handle It!
Big, relatively easy, consistent, a -whole-nother-dedicated-crew, kinda gig, that is VERY profitable. With the Built-In up-sell factor! Smarts!
| Roof Estimating And Drawing Program | Ed the Roofer | Roofing | 32 | 03-07-2011 10:50 AM |
| Roof Cleaning Pictures Wanted !! | Roof Cleaning | Pressure Washing | 5 | 09-07-2010 09:24 AM |
| Metal roof question | Burby | Roofing | 11 | 01-22-2009 01:16 PM |
| Low Pitch Roof solutions | Fixer | Roofing | 4 | 02-18-2007 11:09 AM |
| Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 02:46 AM |
