Nail Pops Through Shingles?
Old 08-26-2011, 11:20 AM   #1
ASIinc.'s Avatar
Trade: Deck/Remodeling Contractor
Rewards Points: 75
I was up on my roof today hanging gutter when I notices a nail popped up through the shingle, looked around and noticed they are everywhere! Its like someone went in my attic and stared hammering the roofing nails back up. atleast 50 or so have popped through and I can see a bunch more getting ready to. I put the roof down no more that five years ago. Certainteed architectural, 1.5" nails. I know nails a few nails will sometimes pop but the whole freakin roof. Whats causing this.
ASIinc. is offline
Old 08-26-2011, 01:06 PM   #2
apkole's Avatar
Trade: Residential roofing contractor
Rewards Points: 186
Re: Nail Pops Through Shingles?
Were the nails hand driven or nail gun? What is your roof decking . . . OSB , plywood or dimensional?
Infrequent nail pops usually caused by failure to set nail into wood and failure to seat nail flush to shingle surface.
Improper function of nail gun or inadequate air line pressure are causes of nails not seated. Operator error is another possibility.
I looked at a similar situation a few weeks ago. Nails peeking through shingles all over the roof. Investigation revealed nails not driven flush and nails driven crooked, all with roofing nailer.
apkole is offline
The Following User Says Thank You to apkole For This Useful Post:
roofermann (02-14-2015)
Old 08-26-2011, 03:51 PM   #3
jamesfl's Avatar
Trade: roofing
Rewards Points: 75
hows the roof ventilated?
jamesfl is offline
Old 08-27-2011, 08:20 AM   #4
ASIinc.'s Avatar
Rewards Points: 75
all nails were gunned down, maybe a couple werent seated properly but a handful at most. I hung all the shingles myself, if one of my guys nailed it I might have second thoughts. The only ventilation is a ridge vent. The roof only sees a few hours of sun a day. deck is 1/2 cdx. Some of the nail heads are up 1/4- 3/8 completely above the shingle above it.
ASIinc. is offline
Old 08-27-2011, 08:37 AM   #5
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Rewards Points: 1,772
IMO, it's a combination of the longer nails, the plywood, and maybe some ventilation problems.
Plywood is terrible for any kind of moisture, or even if it simply dries out too fast. Nails just won't stay in it for crap.
The nails are a little long, especially if you are using a thinner shingle like TL, even though they are laminates. They work side to side and back an forth until they start easing out.
How is the soffit ventilated? If there isn't enough NFA coming through the soffit to "feed" the ridge vent....sometimes there is a problem. The air gets sucked in one end of the house and goes right back out the ridge vent, not pulling much of the moist hot air out of the attic.
How is the insulation? Any poly on the walls and ceiling?
MJW is offline
Old 08-27-2011, 11:17 PM   #6
RandyB1986's Avatar
Trade: Roofing, Siding and Custom Carpentry
Rewards Points: 396
Was it installed in cold or hot weather?
RandyB1986 is offline
Old 08-30-2011, 06:19 PM   #7
ASIinc.'s Avatar
Rewards Points: 75
Actually the nails were 1.25" just pulled a couple out. I have 2' overhangs so plenty of vent in soffits. And there is one gable vent. I put the roof down in the fall I believe. maybe 60 degrees. The original 3tab didnt have any nail pops that I remember and that was with no ridge vent.
Whats the best way to repair. I was thinking flashing cement with tar paper of something on top then more cement(under the shingle)?
ASIinc. is offline
Old 08-30-2011, 09:25 PM   #8
RandyB1986's Avatar
Rewards Points: 396
Gun nails or hand drives? I looked at a house recently that is 3 tabs and hand nailed and it had nail pops everywhere......I am sorry, but I just don't have an answer. I have been at this a long time, and been told different causes....and honestly, none of them made me a believer!
As for repair, if there is a bunch you are going to have a new roof in your future, sooner rather than later. You can repair them by replacing shingles, if that is not an option then use Eterna bond or similar product and cut small 3" squares, after repairing nail pop put E bond over it, then maybe some sealant to hold shingle down.....but the hole is still going to remain unless you fill them with sealant and sprinkle granulars over the adhesive.
Old 08-30-2011, 09:34 PM   #9
jmiller's Avatar
Trade: Roofing
Rewards Points: 1,002
Loosen shingle(s), remove nail, re-nail and seal.
My least favorite repair.
jmiller is offline
Old 08-30-2011, 10:55 PM   #10
MJW's Avatar
Good man! Once you start "believing", you stop thinking.
To the OP,
I still say it's the plywood. Maybe it was a bad grade of plywood you were not aware of.
Seal up the gable vent also. The ridge vent will work much better pulling air through the soffits.
MJW is offline
Old 08-31-2011, 05:32 PM   #11
ASIinc.'s Avatar
Rewards Points: 75
Well it looks like im gonna be spending my next few weekends up on the roof. hopefully I dont get to many more, cant afford a new roof every few years. thanks for everyones help
ASIinc. is offline
Old 08-31-2011, 11:48 PM   #12
JWRoofing's Avatar
Trade: State Certified General & Roofing Contractor
Rewards Points: 25
ASIinc,
I have never seen anything like what you are describing. If the raised nails are coming out easily, you might want to consider replacing them with a good ring shank nail with a dab of bull over the head.
JW
___________________
Miami Lakes roof coating
Safety Training Florida
JWRoofing is offline
Old 11-14-2011, 08:47 PM   #13
Commercial Roofing
tekwrytr's Avatar
Trade: Commercial Roof Repair and Re-Roofing
Rewards Points: 75
Popped nails used to be common when most shingles were driven by hand. Especially on wood shingles and shakes. The reason is oil--to make the nails easier and faster to drive. Typical procedure was to use baby oil as "suntan lotion" and put a few squirts into a box of nails. The ruse of "suntan lotion" was the explanation if someone caught you greasing your nails. "Oh, my ... it must have been that handful of nails I grabbed right after I used my suntan lotion that did it."
Rockers still use oiled nails. So do a LOT of hand nailers. If you were too enthusiastic while lubricating your nailgun, that could be the cause. Or if you have an inline oil reservoir that keeps a bit of oil in the air line, that could be the cause.
Commercial EPDM Rubber Roof Repair - Maintenance - Re-Roofing Exclusively. Serving the Twin Cities, MN Metro area since 2001.
http://www.tekwrytrs.com/roofing/
tekwrytr is offline
Old 11-14-2011, 11:49 PM   #14
Roofer Ben
bkb0000's Avatar
Trade: Roofing
Rewards Points: 70
anything's possible, obviously.. but i seriously doubt oiled nailed will cause the nails to push up through asphalt shingles. the oil would loosen the nail in the hole, not PUSH it up through a pretty tough substance.
i've seen plenty of nails/staples popping through shingles, here in the pacific northwest... in every case where i've bothered to investigate why, i've concluded it was from wet/damp felt during install. the felt swells and "bubbles" up off the deck... if you don't slash the felt to flatten it out (GASP!), the shingle will sit off the deck, and so will the nail head. then, after 3-5 years or so, the heads, with shanks firmly locked into the substrate, start to melt up through the shingles. seems to happen worse with staples, as they're thinner and cut through easier.. but nails to it to.
best fix is to pull the affected nails, pull both shingles, and re-nail (in different spots). but you could just as easily get away with beating them down and sandwiching karnak between the shingles- that's how most roofers seem to handle it. since the nails haven't actually moved since the day they were installed, you shouldn't have any more problems, once the affected nails are dealt with.
contrary to popular myth, slashing the felt is of absolutely zero detriment to the roof, now or ever. if it was, you'd need to tape the seams and would have to glue the shingles down, rather than nail them.
Last edited by bkb0000; 11-14-2011 at 11:54 PM. Reason: effect does not affect make
bkb0000 is offline
Old 11-17-2011, 07:09 AM   #15
roof-lover's Avatar
Trade: Roofing contractor
Rewards Points: 302
[QUOTE=bkb0000;1329383]
contrary to popular myth, slashing the felt is of absolutely zero detriment to the roof, now or ever. QUOTE]
correct! and your reasoning for slashing the felt.
cutting through a wrinkle is imperitive!
also wanted to comment that i have seen multiple nail pops present themselves much later after an install. We had installed ice and water sheild over the whole roof.
roof-lover is offline
Old 11-17-2011, 12:01 PM   #16
CompleteW&D's Avatar
Trade: Windows, Doors, Siding, Enclosures
Rewards Points: 2,936
Like others have said, nail pops don't seem to have a rhyme or reason why they happen. Hand nailed, gun nailed, plywood, osb, great ventilation, poor ventilation.... I've seen nail pops on all of them.
The only suggestion I would offer that hasn't been given yet.... I would highly recommend Geocel 2300 Tri Polymer sealant to re seal your shingles. Most guys think regular roofing tar is fine, but it gets brittle eventually and will fail. The 2300 will stick to ANYTHING, stays flexible and is impervious to water. Plus, it's fully approved for use on shingles by all of the roofing manufacturers.
A little more expensive than tar (or roof cement if being politically correct), but a whole lot better for sealing the shingles and any nail holes.
- John Williams
Complete Window and Door
Originally Posted by TNTSERVICES View Post
As accomplishments go, getting me to talk is an easy one.
CompleteW&D is offline
The Following User Says Thank You to CompleteW&D For This Useful Post:
smalpierre (01-08-2012)
Old 01-05-2012, 10:03 PM   #17
johnny37406's Avatar
Trade: Roofing
The are quite alot of reasons for nailpops. Sometimes just walking on the roof causes them. How far apart are your rafters? As far as fixing them I would recommend not using roofing cement or any other caulk type of sealant incase this revisits you and you have to go back and fix these again. Reset the nail an inch higher and to the left or right. Place a small piece of ice and watershield over the hole thats underneath the exposure.
http://jhurst.blogspot.com
johnny37406 is offline
Old 01-08-2012, 11:05 PM   #18
The Dude
smalpierre's Avatar
Trade: home improvement
Rewards Points: 1,946
reset it an inch higher??? High nailing is the most common cause of problems around here. Dimensionals will delaminate and slip down the slope. Probably no a problem if it's only 1 nail in a shingle, but I don't do it.
I like the ice / water shield idea, but once you break the seal strip, you're supposed to reseal it. I use a blob of Geocel 2300 on the hole, and a thin line of it at the seal down.
"That somebitch looks like MANAGEMENT MATERIAL TO ME...I would have handed him another rod after he bent the first one." ~MAULEMALL
"I think he was grandmaster at a gay pride parade in san fran this week (not that there's anything wrong with that). " ~ J F
smalpierre is offline
Old 01-08-2012, 11:11 PM   #19
The Dude
smalpierre's Avatar
[QUOTE=roof-lover;1331037]
ice/water on the whole deck prevents the roof from breathing.
Cutting the felt isn't detrimental? How about installing it without wrinkles, it's not difficult.
Old 01-23-2015, 12:24 PM   #20
Roofer Ben
bkb0000's Avatar
Trade: Roofing
Rewards Points: 70
It doesn't get installed with wrinkles. It becomes wrinkled when it gets wet from dew or rain.
bkb0000 is offline
The Following 5 Users Say Thank You to bkb0000 For This Useful Post:
madrina (02-13-2015), RandyB1986 (01-25-2015), Rio (02-12-2015), roof-lover (02-11-2015), roofermann (01-24-2015)
Shingles Nailed Above Nail Line.. Help!! Unregistered Roofing 24 04-20-2011 09:14 PM
The Nail Pounding Contest Kent Whitten Carpentry 42 01-16-2011 01:41 AM
opinions/help shingles are falling off roof kuby Roofing 2 11-02-2010 10:40 PM
Help, old shingles stuck to ice shield??? 232323 Roofing 45 09-16-2009 04:27 PM
Anybody having trouble getting shingles? SES Constructio Roofing 2 08-23-2008 01:41 AM
