Minimum Pitch For Shingles
Old 03-01-2017, 02:29 PM   #21
elite-roofing's Avatar
Trade: roofing, remodel
Rewards Points: 74
Re: Minimum Pitch For Shingles
My suggestion is to use the roofing shingle manufacturers specifications. Anything less and you will wind up with no warranty and a lawsuit. Easy enough to pull specifications for each roofing shingle manufacturer from their web site. You need to remember that shingle weight will factor into maximum pitch as well.
Jesse
Elite Roofing
elite-roofing is offline
Old 03-05-2017, 09:49 AM   #22
DFW Roofing's Avatar
Trade: Roofing
Rewards Points: 183
The answer has been give above. Code is 2/12 min with special low slope application methods required below 4/12. Ice & Water is a substitute for a double layer of felt.
It has been my experience that house originally framed at 2/12 will have spots below 2/12 after a few decades of age and gravity.
Bert Roofing Inc
10021 Cayuga Dr
Dallas TX 75228
214-321-9341
DFW Roofing is offline
Old 03-07-2017, 06:27 PM   #23
jcampos001's Avatar
Trade: Roofing
Rewards Points: 2
Originally Posted by MattK View Post
Do not use I&W on the entire roof. A roof system needs to breathe to function properly. Covering the entire roof with Grace would block air flow even worse than the cheap granular option.
agreed Matt... I was always told a 3
jcampos001 is offline
Old 02-05-2018, 02:04 PM   #24
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 11,249
A little update on this. It's now a year later, and today the addition roof is getting framed.
As it happens, this morning I noticed that the rear ridge beam was run directly off our original ridge (cape cod, 12:12 roof). Well, our plan was to raise the ridge so we could get more slope on the rear roof. Oops...small oversight..it would still have been 2 1/2:12.
Thank goodness I caught it, just before they started cutting the rafters. Plans are onsite, but it was just overlooked somehow.
MarkJames is offline
Old 02-10-2018, 03:40 AM   #25
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 5,637
One, Use steel on the shed roof addition.
Two, Move the ridge back and up at the 12/12 pitch until the long side forms a 4/12 roof pitch
First floor top plates at nominal 0'-0" 26 feet apart, a 12" floor added under the addition roof, so 108" high(above legacy FF top plate & 8'stud wall) second floor top plate, the old peak at 12/12 X 13' run plus rafter width, is say 13'-6" or 162" , 13' run at 4/12 = 52" + rafter width, say 12" wooden I-Beams for insulation, thus the new ridge comes back into the addition & up about a foot?
You need a carpenter that has done these before or someone that can read basic roof framing texts.
This isn't rocket science boys.
Fouthgeneration is online now
Minimum Pitch for Metal Roofing jproffer Roofing 47 10-29-2016 05:46 AM
Minimum ceiling height for 7' garage door festerized Windows, Siding and Doors 14 06-19-2016 07:53 AM
Basement egress window: minimum height? jacselee Construction 26 05-28-2015 05:17 AM
Geoblaster gb400 minimum cfm's Northerner Sandblasting 6 03-04-2015 02:38 PM
Construction Master, Rake Wall so1storm Framing 0 07-22-2014 01:57 PM
