Minimum Pitch For Shingles - Roofing - Contractor Talk
Old 02-20-2017, 08:37 PM   #1
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,525
What minimum pitch do you advise for a new shingled roof? 4/12 or less?
We're trying to figure out an addition to extend the rear of a 34' wide cape cod that has a 12/12 pitch. (Front to back is 26') This is going to be full width, or maybe extending off just inside the back corners. I think some kind of shed dormer design would look good, but there's an issue with having a peek-a-boo peak extending above the original roofline and looking stupid.
MarkJames is online now
Old 02-20-2017, 08:40 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,850
Re: Minimum Pitch For Shingles
3/12 is what i have always heard
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
MarkJames (02-20-2017), We Fix Houses (02-20-2017)
Old 02-20-2017, 08:49 PM   #3
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 2,783
4
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 02-20-2017, 08:51 PM   #4
NJGC's Avatar
Location: Unfortunately I live in the communist republic of NJ.
Rewards Points: 82
4
Sent from my SAMSUNG-SM-G930A using Tapatalk
NJGC is offline
The Following User Says Thank You to NJGC For This Useful Post:
Old 02-20-2017, 08:55 PM   #5
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,000
I'm with Griz. 3/12, on a rare occasion 2/12 --- both double coverage paper.
What is double coverage paper ? 18" pc followed with 36" over that, then maintain 18" exposure.
Sometimes it's easier to just fold in half the starter paper strip.
Steve
We Fix Houses is offline
The Following User Says Thank You to We Fix Houses For This Useful Post:
Old 02-20-2017, 08:56 PM   #6
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,615
I think the manufacturers require a 4/12 for warranty. We have done a few that were as low as 2/12 and shingled. Use the Grace Ice guard and do the laps 12".
Easy Gibson
Warren is offline
The Following User Says Thank You to Warren For This Useful Post:
Old 02-20-2017, 08:57 PM   #7
Fire up the BBQ
griz's Avatar
4/12 is a general guideline from most manufacturers.
with a competent roofer a proper installation can be made on 3/12 with warranty intact.
griz is online now
Old 02-20-2017, 08:57 PM   #8
LRG WoodCrafting
Leo G's Avatar
Just use water and ice up the whole roof.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 02-20-2017, 09:31 PM   #9
Tom M's Avatar
Rewards Points: 7,140
The code allows 2:12. Shingled roofs between 2:12 - 4:12 need double coverage underlayment. I personally never felt comfortable less than a 3 and the 3's I have done I reduced the exposure to weather.
Ice shield is added protection but the main concern is blow offs from wind picking up the edges
Tom M is online now
Old 02-21-2017, 01:20 AM   #10
Bull Trout's Avatar
Rewards Points: 1,148
another vote for 4, but I think some companies warranty a 3
Bull Trout is online now
Old 02-21-2017, 09:42 AM   #11
GoodStuff's Avatar
Trade: Roofing & General Contractor
Rewards Points: 70
Owens Corning is 3/12, but I concur with the other replies in that anything less than a 4/12 pitch requires double underlayment. I use Ice and Water under any roof 4/12 or less. On a 3/12 pitch, I use a 4" exposure to eliminate the water running up the shingle to the nail holes. If possible, upgrade the shingles to dimensional.
Good Stuff Enterprises
www.bestkentuckyroofing.com
"We Worry... So you don't have to!"
GoodStuff is offline
Old 02-21-2017, 09:45 AM   #12
MikeFL's Avatar
Trade: Engineer
Rewards Points: 196
The lower your slope the greater the member size due to loading. You're in Arlington so you have snow loads.
As to minimum slope for a particular shingle, you need to read the manufacturer's instructions. If the code says 2:12 minimum but the shingle you select says 4:12, then you can't install that shingle on a 3:12, for example.
Michael Gookin, President
GPS LightLock Astronomical Timers
www.GPSLightLock.com
(239) 848-6675
MikeFL is offline
Old 02-21-2017, 08:41 PM   #13
MattK's Avatar
Trade: Framing, Roofing, Siding
Rewards Points: 1,096
Do not use I&W on the entire roof. A roof system needs to breathe to function properly. Covering the entire roof with Grace would block air flow even worse than the cheap granular option.
--MATT
Add your Facebook Business Site to "THE LIST"
http://www.contractortalk.com/f12/if...-should-79504/
Page 77 has the updated, complete list.
MattK is offline
Old 02-21-2017, 09:08 PM   #14
NJGC's Avatar
Rewards Points: 82
Please explain....
NJGC is offline
Old 02-22-2017, 04:37 PM   #15
MattK's Avatar
Originally Posted by NJGC View Post
Please explain....
This is primarily a matter of opinion. Some guys, myself included, feel I&W chokes off the ability for a roof system to pass air and moisture through. It brings the breathability down significantly and if the roof is not vented properly, this will expedite the plywood deteriorating.
I personally haven't stripped a roof fully I&W'd but the times I've tried to pull shingles off cooked Grace on the first 3', was a horror show and resulted in the plywood coming off the rafters as well, in de-laminated chunks I might add.
I'm not saying it would be a total disaster, I just personally wouldn't do it on any of my roofs. The Grace products and synthetic underlayments are still fairly new to the industry. Decades to come will tell us more about after effects and time passing.
--MATT
MattK is offline
The Following 2 Users Say Thank You to MattK For This Useful Post:
hdavis (02-22-2017), Tom M (02-22-2017)
Old 02-22-2017, 06:07 PM   #16
NJGC's Avatar
Rewards Points: 82
I tend to disagree osb or plywood does not need to "breathe" that's just silly.
NJGC is offline
MikeFL (02-23-2017)
Old 02-22-2017, 06:21 PM   #17
Tom M's Avatar
I am always papered in roofs and even double covered them with full ice shield.
It's redundant but without that bond break your screwing the owner with future headaches "cooking" the product to the roof like you say.
Tom M is online now
MikeFL (02-23-2017)
Old 02-22-2017, 07:31 PM   #18
MattK's Avatar
Like I said, it's definitely a matter of opinion and preference. All are entitled to continue the install practices that work best for them.
I always fall back on a proper install will trump everything else. There wasn't any Ice & Water 70 years ago and 3 tabs were paper thin, yet guys still found ways to keep snow and water out of attics.
--MATT
MattK is offline
Old 02-23-2017, 08:00 AM   #19
MikeFL's Avatar
Trade: Engineer
Rewards Points: 196
A layer of felt and then a layer of ice shield and then the shingles makes a great install. It's just not going to leak, ever.
(239) 848-6675
MikeFL is offline
Old 02-28-2017, 01:38 PM   #20
Coverall's Avatar
Trade: Roofing Contractor
Rewards Points: 24
We use full ice and watershield with 3/12 pitch if there is fully vented soffit and ridgevent. If you are tying in a shed roof into main roof odds are this roof is not going to have adequate ventilation going to main ridge. 4/12 is the way I'd build it. http://www.roofinglongisland.com
Coverall is offline
Minimum Pitch for Metal Roofing jproffer Roofing 47 10-29-2016 04:46 AM
Minimum ceiling height for 7' garage door festerized Windows, Siding and Doors 14 06-19-2016 06:53 AM
Basement egress window: minimum height? jacselee Construction 26 05-28-2015 04:17 AM
Geoblaster gb400 minimum cfm's Northerner Sandblasting 6 03-04-2015 01:38 PM
Construction Master, Rake Wall so1storm Framing 0 07-22-2014 12:57 PM
