Guest
Guest
Posts: n/a
![]() Metal Roofing And Snow Problem
I live where we often get a lot of snow and recently got a new metal roof (2 falls ago). When the snow on the north side builds to a few feet it all comes avalanching down into my front yard. I get piles of snow 6 feet high outside my kitchen and living room, and worse, my driveway. I have got to do something about this and my contractor won't even return my calls.
What are my options here? Put something textured, over the metal, to hold the snow? Re-roof the frikking thing? Shoot my contractor? ![]() Thanks for any help/advice you all can give me. Greg |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Metal roofing specialist
Re: Metal Roofing And Snow Problem
we use a product from http://www.snow-guards.com/
on their site they can help you "size" your snow guard requirements or call them they can help you determin which size, the spacing and locations for the snow guards. these polycarbinate pieces "glue" to your roof and when properly placed they will stop the snow from avalanching down on the ground. most of the snow will have to melt off. there are also many other snow guards avialable. but these are what we use and have found work the best for the best price. GOOD LUCK :Thumbs: Advertisement |
#3 | |
Commercial construction
Trade: Commercial construction
Re: Metal Roofing And Snow ProblemQuote:
Commercial Roofing
Trade: Roofing Contractor
I agree that it does not make sense. It also does not make sense if somebody suggests it is his fault.
http://www.roseroofing.net/ Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality! Free roof inspections within 12 miles of our locale. |
#5 | ||
Guest
Guest
Posts: n/a
#6 | |
Trade: underground
Rewards Points: 2,000
Greg, I just came back from a shopping center that has a sloped metal roof. Lots and lots of snow guards like those mentioned by DBS01 - looked like 'The Queen' style. Seems like a pretty simple fix to your concern. |
Guest
Guest
Posts: n/a
Thanks PipeGuy, for the understanding and support. Sounds like the snow guards are the way to go.
Thank you all. |
Trade: Roofer
Rewards Points: 150
Greg, there are four ways to handle snow on a metal roof:
Snow deflectors are angled metal pieces that deflect the snow from the dangerous areas (such as a doorway) to a less dangerous area. These are usually installed in an inverted V style. Snow fences hold the snow in place along the eave, and need to be engineered to hold a lot of weight. Necessary if you MUST prevent the snow from coming down from the roof. Granulated steel or similar material will have a non-slide surface, and will hold the snow in place, similar to asphalt. A good installer/dealer should be able to figure out the right combination for each house. I am not a big fan of glue-on stoppers as I have seen too many get ripped right off the panels. As well, some panels are not well attached, and while the glue holds well, the panel gets ripped off. My preference is to have the snow load supported by two or three 4-6 inch steel bolts fastened to the rafters (not sheathing). Of course, to do this, you have to pierce the roofing material, but you should have Ice-and-water shield below the panel, and an excellent caulk (solonastic 150 or equivalent) on the top. |
Rewards Points: 25
just tell the little lady. "Honey i had to buy the plow attachment for the new truck." nothing say's christmas like a new tool except 6' of snow
Trade: Roofing
Rewards Points: 150
Another source which is local for you (Lindon, UT). www.trasnowbrackets.com They have the engineering studies/charts for all of their products.
Jim |
Commercial Roofing
Pipe guy,
Snow guards are optional, period. If you wan them, them have them installed. To think it is the roofers fault (not necessarily the case here) is like saying......The ice cream guy didnt put sprinkles on my ice cream. Did you ask for them? No, but he should have known. What do you do again, pipe guy? Advertisement
Display Modes | Rate This Thread |
Go to Page... |
