Metal Roofing Question?
Old 05-22-2006, 12:30 PM   #1
fullhouse's Avatar
Trade: home improvement
I have a customer a just did large kitchen addition for. She now wants a custom overhang for over her side kitchen door. All I have to go buy is a picture from a Lowes flier from a paint add.
The overhang has a slight curve to it (like a quarter pipe or a ski jump) and is covered in metal roofing.
I have called all over for a metal roofing suppliers and none stock it or now much about it.
With the ribs does the curve have to be customed rolled or can screwing it down to curved rafters curve it without kinking it. Also, it is better to put the metal roofing down on plywood or furring strips. I am thinking furring strips so there wont be large areas of metal in contact with the plywood. Dont want it to rust from the under side.
Normally I wouldnt even take this job but this customer has had 2 new baths and a brand new kitchen addition done from me so I said I will do it.
Also it is a very small overhang. 4' wide and 2' off the house. Will metal that short have much give to it?
Does anyone know of any metal rooinf suppliers in Ct.
Thanks everyone.
fullhouse is offline
Old 05-22-2006, 05:01 PM   #2
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
Re: Metal Roofing Question?
Must be custom formed. It will kink if you try to screw it. Even the flat seam panels need to be formed.
http://www.roseroofing.net/
Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality!
Free roof inspections within 12 miles of our locale.
AaronB. is offline
Old 05-22-2006, 05:34 PM   #3
RooferJim's Avatar
Trade: roofing
metal roofing has to be installed using cleats "not nailed or screwd" so that it can expand without oil canning. hire a sheet metal man or a roofer who does metal work.
You really have to know what your doing
RooferJim
www.jbennetteroofing.com
RooferJim is offline
Old 11-02-2009, 07:25 PM   #4
aegisroofing's Avatar
Trade: Roofing
Please, do not screw down the panels. You should call a metal roofing contractor. The pans defiantly need to be custom formed and fastened with cleats. Also, the thinner the gauge of metal the more it will form to curves.
Best,
Todd Strickland
AeGis Roofing
Roof Repair or Replacement
aegisroofing is offline
Old 11-02-2009, 07:41 PM   #5
Framer53's Avatar
Trade: Framing
Thanks everyone.
Don't know of one in Ct, but I know one in Kentucky that will custom make and ship it to you!
www.Grantlogancopper.com
Framer53 is online now
Old 11-02-2009, 07:45 PM   #6
Patrick's Avatar
nevermind
This guys digging up old posts....
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 11-04-2009, 07:25 AM   #7
Tom Struble's Avatar
Trade: siding
Tom Struble is online now
Old 06-27-2011, 11:07 AM   #8
roofing123's Avatar
Trade: Roofing
I would check out the specs from your [removed] before you begin. A lot of roofs will need different things, such as the material to put below it as well as the length of space in between clamps. I would contact your roofing supplier first.
roofing123 is offline
Old 06-28-2011, 01:19 AM   #9
Estimating Software
toecutter's Avatar
Trade: Estimator/Software Developer
Send a message via Yahoo to toecutter Send a message via Skype™ to toecutter
Down here we have 2 types of curved roofs
1. The curving quality sheet is put through a roller that curves the sheet
2. For gentle curves you can usually just drop the standard quality sheet on the timber or steel top hat battens
top hat batten
Usually there is a site setup fee and cost per sheet to curve sheeting.
Best to seek info from the sheet manufacture after you determine the radius of the curve.
HTH
regards
mick
estimatingsoftwareservices.com
toecutter is offline
The Following User Says Thank You to toecutter For This Useful Post:
Tom Struble (07-01-2011)
Old 07-01-2011, 10:32 AM   #10
WilliamPerez's Avatar
Trade: Home Improvement
top hat batten
HTH
I agree with mick ...
WilliamPerez is offline
The Following User Says Thank You to WilliamPerez For This Useful Post:
toecutter (07-01-2011)
Approval/denial of roofing materials - questions jmasters Roofing 29 11-16-2007 08:09 PM
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 01:30 AM
Installing metal roofing over metal roofing bugdoc@linkny.com Roofing 3 04-04-2006 08:48 PM
A question please? ie: metal roofing crossthread Roofing 1 10-13-2005 08:38 PM
