Metal Roof Tied To A Shingle Roof?
Old 11-11-2005, 08:57 PM   #1
JackOfAllTrades's Avatar
Trade: Paint and Carpenter
I have never seen it done, myself, and a builder friend warned against it, but have you ever seen a metal roof tied to a shingle roof? I have a neighbor who wants a metal porch roof, but she does not have enough height on her outer walls to allow for any pitch from the eave to the end of the porch without tying in to the existing shingle roof. Any thoughts would be appreciated.
JackOfAllTrades is offline
Old 11-12-2005, 12:34 PM   #2
Bah Humbug!
Grumpy's Avatar
Re: Metal Roof Tied To A Shingle Roof?
I would say I have done it many times. I've done standing seam to slate, shingles to standing seam, shingles to flat seam.
Singles to flat seam is the easiest and requires very little thought IMO. The key is no matter what type of roof you are installing you need a perfectly flat tie in, in addition you want your metal to wrap under your shingles at least 18" but perferably more.
Also I always put ice shield under my metal roofs and especially under the tie-ins. I would also probably do a counter flash with ice shield over the tie-in so if any water backs up under the shingles and "rivers" it way through the roof, it won't come in as a leak at the metal roof. Instead it will flow right out ontop of the metal roof.
Grumpy is offline
Old 11-15-2005, 12:00 PM   #3
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
And prime the metal with an asphalt primer and allow to dry for a tenacious bond.
http://www.roseroofing.net/
Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality!
Free roof inspections within 12 miles of our locale.
AaronB. is offline
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 01:30 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
