Metal Roof Sweating - Help?
Old 01-03-2009, 04:44 PM   #1
Home Innovation's Avatar
Trade: builder/contractor
I'm a builder in Maine, yea, the other end of the world. Anyways, I have a customer that has a ranch style house. Half the house is cathedral, the other has a very small attic. So heres the deal. I pulled the insulation out the attic, it was against the metal roof and was saturated. So I replaced all the insulation, and added proper vents between the insulation and 1x6 horizontal boards that hold the metal roof. I also found that there was no ridge vent or soffit vents, so I added both to get some ventilation across the whole length of the roof. My first findings included saturated insulation, 1x6 slats, and typar.
For some info: there is sheetrock on the cathedral, 2x8 rafters, R30 fiberglass insulation, 1x6 boards, typar, then metal roof....
Ok, I know there is no need for insulation against the roof for an attic and it works perfectly fine w/ no insulation against the roof, BUT I need to experiment in the attic so I can fix the cathedral area, which I will have to do taking the metal roof off..
So I waited a few days w/ no insulation to dry the roof, then I put proper vents in 2 bays w/ dry insulation and waited 5 days to see if condensation would occur and it did, exept now it condensates between the proper vent and the insulation. The top side of the proper vent is dry as well as the typar and wood slats that holds the metal roof....I really hate metal roofs and this is not helping my oppinion on them. Can someone help me out w/ this??? BTW: the proper vents was the pink foam ones.
Home Innovation is offline
Old 01-03-2009, 08:35 PM   #2
mics_54's Avatar
Trade: contractor
Re: Metal Roof Sweating - Help?
Facts:
#1) poor insulation in the cieling can cause air in the attic to become warmer.
#2) a lack of vapor barrier in the cieling can add to the moisture in the air in the attic.
#3) The sun can heat the roof causing attic air to become warmer.
#4) Condensation only occurs when moisture laden air comes in contact with a cooler surface relative to the temperature of the air. (see references to a dew point curve)
#5) There are several ways to manage condensation. Separation of cold surfaces from warm moist air. Elimination or reduction of temperature differentials of the air and the surfaces. Elimination or reduction of moisture in the air.
In a typical attic the most common practice is to attempt to utilize all three methods of mitigation. Insulating the cielings, venting the attic, installing vapor barriers. Condensation is most apparent on impermiable surfaces like metal. Condensation can still occur on wood but it isn't as apparent usually because wood absorbs moisture.
mics_54 is offline
Old 01-03-2009, 09:17 PM   #3
mics_54's Avatar
Trade: contractor
Yet there are only two ways to saturate air and cause precipitation or condensation. One is to cool it to it's dew point thus reaching its 100% relative humidity. The other is to add water vapor to it. Precipitation will never occur outside of 100% relative humidity...if I understand the principles.
mics_54 is offline
Old 01-04-2009, 01:04 AM   #4
Roofing and Architectural
Renegade's Avatar
Trade: Roofing and Architectural Metals
Just a wild guess, it's a bare galvanized metal. There is one odd but easy solution.
Renegade is offline
Old 01-04-2009, 08:30 PM   #5
It is the standard residential (maybe americana) galvanized roofing (red in color). The thing that worries me is that its sweating between the proper vent and insulation now and not the metal. I do not know if there is any plastic or vapor barrier under the insulation of the cathedral. My guess would be "no". I just don't want to pull the metal off the roof, change the insulation and have it condensate again....I am trying an experiment in the attic by putting plastic sheating (6 mil) over the insulation (hot side) and see what happens. So there will be plastic, insulation, proper vent, 1x6 slats, typar and metal....any other suggestions that I could experiment on? Its around 12 degrees at night and only 20's during the day right now. Thank you.
Old 01-04-2009, 11:01 PM   #6
Tom Struble's Avatar
Trade: siding
i feel on a residential job the metal roof should be on solid
sheathing with a tar paper or synthetic underlayment then
layer of rosin paper then the panel.
You have warm moist air goin thru the skip sheathing and condensing on the panel.Maybe you could install foam sheathing in the rafter bays and
seal along the joints
Tom Struble is online now
Old 01-05-2009, 06:18 AM   #7
That is what we will be doing. The slats are now rotted from the condensation. So when we pull the metal off, we will be pulling the slats and plywooding the roof. We will tar paper it, then apply the metal back on. But like I said earlier, w/ the proper vents in there, its sweating between the proper vent and insulation now and NOT the metal roof...so I can't blame it on the metal now....
Old 01-06-2009, 04:22 PM   #8
dennis's Avatar
Trade: Roofing
In reverse order;
Metal roof
rosin paper
tarpaper #30 minimum
solid lumber preferred or 3/4 plywood
1.5" - 2" airspace
Insulation, skip the foam baffles
vapor barrier
my 2cents
dennis is offline
Old 01-07-2009, 11:55 AM   #9
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
Get rid of the moisture in the house if its not the roof causing the sweating.
Closed cell spray foam insulation will eliminate this problem.
http://www.roseroofing.net/
Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality!
Free roof inspections within 12 miles of our locale.
AaronB. is offline
Old 01-21-2009, 07:43 PM   #10
wmallock's Avatar
Trade: home improvment
I agree the problem is not ventilation now that you fixed that nor the metal you would still see condensation on a wood decking
The only thing i can see is the home has a great deal of heat loss due to lack of insulation vapour barrier lack of seam tape on vapor barrier etc.
wmallock is offline
Old 02-06-2009, 10:54 AM   #11
rtomsi's Avatar
Trade: Filc d.d.
If it is of any help to anybody, some producers (in EU most of them) are offering metal roof tiles and sheets with an anticondensation layer (e.g. dripstop etc). It is like some kind of thin textile glued to the metal sheet and it holds the condensate moisture inside, so that there is no dripping from the roof to the floor. This is only possible when deciding about a new roof and it does not help you to solve any problems with an existing problematic roofs.
rtomsi is offline
Old 02-06-2009, 11:08 AM   #12
Trade: siding
just thinking you may want to check into some of the synthetic underlayments that are rated for the high temperatures under metal roofs
Old 02-06-2009, 09:04 PM   #13
red_cedar's Avatar
If you do this then correct venting becomes more important. Most of the synthetic underlayments do not breathe. The synthetics are not a cure all for problems, they are an upgraded non breathable underlayment that can also act as a slip sheet for the metal.
red_cedar is offline
The Following User Says Thank You to red_cedar For This Useful Post:
Tom Struble (02-07-2009)
Old 02-08-2009, 08:58 AM   #14
Justusjeff's Avatar
Trade: Siding
One big problem most people don't recognize is moisture from the burning of non vented gas heaters such as propane wall heaters or free standing kerosene heaters. I had a customer call me because the plywood sheathing in attic roof was literally saturated with water, leaking on insulation and also to the outside soffit. I went to the attic and I swear, it looked as though you wet the sheathing with a hose. For 17 years the customer never had a problem, but that year he switched from a coal stove to 2 gas non vented heaters. I talked to a salesman from gas company and he informed me that the end bi-product from these heaters is moisture and that a non vented unit should be run with windows cracked in the room or vent the unit to the outside. I would tell the owner to shut down these heaters for a couple of weeks and see if thats the source of problem. Hope this helps.
Justusjeff is offline
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 10:50 AM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
Metal Roof OVER shingles? MHMConstruction Roofing 9 12-22-2008 10:14 AM
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 01:30 AM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
