Metal Roof To Sky Light Flashing?
Old 08-24-2007, 06:40 AM   #21
tinner666's Avatar
Re: Metal Roof To Sky Light Flashing?
When overlapping steel, starting at the penetration corner, I run 3-5 beads of caulk before locking that next panel in. The beads are mainly to seperate the pieces of metal. The seperation prevents water wicking, not leaks. I expect the panel placement to be the primary leak proofing!
Here, at this site, my links often end up with '...' and part of the word 'images' missing??????????????????????????
Go to my site and click on the 'My CoffeeShop Photo Albums' for direct link to ALL those pics.
The moderators here sometimes fix the 'problem'.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 08-25-2007, 09:37 AM   #22
Big Dog Dan's Avatar
Trade: General construction
Hi tinner666
I agree with the panel being the water barrier, and not giving anything else the opportunity to suck water.
If I go to your coffee shop, how will I know what photo shots you are referring to on your posts 13,and 14?
tinner
I talked the owner into standing seam and I have done this before, but I have never worked the metal around the sky lights.(Velux).
Can I bend or make my own flashing? Or would you recommend I buy the metal roofing sky light flashing kit (expensive)?
Also I noticed on my last job that when I bent the lower lip over the edge, that sometimes they were not exactly straight. I did square the roof before I started, but I was surprised at the drip edge looking slightly slanted. (like the panels were not perfectly straight with the building.
Can you give me an idea of how much I should let the panel overhang to have the correct bend.
Sorry for all the detailed questions. I do not expect you to help me with so many details, I just need a little advice if you are open to giving it.
Thanks
Big Dog Dan is offline
Old 08-25-2007, 03:13 PM   #23
tinner666's Avatar
Velux comes with it's own counter flashing. I make my panels to conform with the SL's. I don't start at the rake. I start from the Sl's. THe only piece I need to make is the piece at the top of the SL. And the cleats, not nails hold it on. Their metal 'roof' kit sucks and relies on the water getting under the panels and getting safely back out. I'll never use it.
Old 08-25-2007, 03:16 PM   #24
tinner666's Avatar
This is the L. front corner of one. No flashing necessary, and the side panel is continous to the eave. No joints either. The pans in front are boxed closed and behind the gasket.
Old 08-25-2007, 03:17 PM   #25
tinner666's Avatar
13 is Metal Details, 14 is COpper Work.
Old 08-25-2007, 03:23 PM   #26
Tech Geek
WarriorWithWood's Avatar
Trade: Property Management/Facilities Manager
Tinner,
Incredible work you do, keep it up, then write a book.
-Dennis
www.bowmanch.com
WarriorWithWood is offline
Old 08-27-2007, 12:14 AM   #27
Expert Roofer
theroofinggod's Avatar
Trade: ROOFING/HOME IMPROVEMENTS-WINDOWS/SIDING/GUTTERING/COPPER WORK,ETC
Send a message via MSN to theroofinggod Send a message via Yahoo to theroofinggod
Take notes,and copy his advice(print out),I do!
theroofinggod is offline
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 01:30 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Metal Roof tied to a Shingle Roof? JackOfAllTrades Roofing 2 11-15-2005 12:00 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
