Metal Roof Deck To Existing Shingle Roof Interface
Old 06-07-2016, 12:18 PM   #1
ranmoo's Avatar
Trade: Design
Rewards Points: 2
Application - new porch roof that I am laying out for a backyard porch. Client would like the new porch roof to be of metal roof construction, and not very steep. However, at the ends where the new roof will mate up to the existing roof at the house, it will overlay an existing asphalt shingle roof.
The new metal roof will be approximately 2 vertical to 12 horizontal slope. The existing asphalt shingle roof is approximately 9 vertical to 12 horizontal slope.
Is it practical to have a new metal deck roof that at its high point interfaces to an existing roof, with that roof be asphalt shingles? Can that work?
If so, what details and or precautions need to be taken? If you have reference to any details or illustrations or photos that would be greatly appreciated.
What details or precautions also need to be taken with concerns towards replacing the shingles on the older roof in say 5 to 7 years?
Thanks
ranmoo is offline
Old 06-12-2016, 09:00 PM   #2
At one with wood
RST's Avatar
Trade: ResBuilder/Apts
Rewards Points: 12
Re: Metal Roof Deck To Existing Shingle Roof Interface
Make sure you use long span bridging screws to hold the shingles to the felt at the metal roof junction box.
You may also want to get some roof flux washers to prevent downward pressure on the wassle bolt.
....Homeowner huh....
RST is offline
The Following User Says Thank You to RST For This Useful Post:
Tom Struble (10-11-2017)
Old 06-12-2016, 10:08 PM   #3
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 238
Send a message via Skype™ to jlhaslip
Check with the Manufacturer about installing metal roof on a 2/12 pitch.
They may not recommend it. That is very flat for a metal roof.
I would not consider Metal for a roof flatter than a 5/12. You will be chasing leaks for years to come.
jlhaslip is offline
Old 06-12-2016, 10:32 PM   #4
slowsol's Avatar
Rewards Points: 2,192
Why type of metal roof are we talking about? Standing seam? Exposed fastener?
-John
slowsol is offline
Old 06-12-2016, 11:21 PM   #5
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 296
Not necessarily true. I have done fairly flat roofs better with no problems. On a flatter roof the seals need a sealing tape on the laps and stitch screws.
Randy Bush is offline
Old 06-13-2016, 08:58 AM   #6
mako1's Avatar
Rewards Points: 1,094
Yea.Those wassle bolts are cool.
mako1 is offline
The Following 2 Users Say Thank You to mako1 For This Useful Post:
RST (06-21-2016), Tom Struble (10-11-2017)
Old 06-13-2016, 10:22 PM   #7
jlhaslip's Avatar
Rewards Points: 238
First site for Metal Roofing Manufacturers that I Googled listed the minimum of a 3/12 pitch. I stopped looking and wrote my comment above after the Google search.
You can Metal Roof all the 2/12 pitch roofs you want to. I won't do it based on my experience of having seen them leak too often.
jlhaslip is offline
Old 06-14-2016, 12:38 PM   #8
mastersroofing's Avatar
Trade: roofer
Rewards Points: 94
Are you installing this in a cold weather zone? This sounds like you could have some ice damn issues to consider on the low pitch roof to shingle roof interface.
Chuck
Masters Roofing
mastersroofing is offline
Old 10-11-2017, 03:58 PM   #9
Metalman5301's Avatar
Trade: Metal Roofing
Rewards Points: 22
Your going to have to go with a 1 3/4" snap lock standing seam that is rated for under a 3/12. My local vendor sells one it goes to a 1/4 / 12 pitch. Use transition trim at the place where they meet . Checkout your local metal vendor and see what trim they have.
Metalman5301 is offline
The Following User Says Thank You to Metalman5301 For This Useful Post:
Old 10-16-2017, 09:19 AM   #10
Fishindude's Avatar
Trade: Industrial
Rewards Points: 188
You can do a screw down roof as flat as 1":12 and a standing seam as flat as 1/4":12 if they are done properly.
Fishindude is offline
Joining new shingles from new hip roof to existing shingles on existing roof? Stoutmarine44 Roofing 5 03-04-2016 05:42 AM
Dormer Shed Roof, Barrel Roof, CutIn Dormer, Eyebrow Dormer sbebuilders Framing 33 04-18-2013 06:29 PM
Sealing Metal Valley Section artinall Roofing 20 11-07-2012 12:18 PM
Hidfast Gun redwood Decks & Fencing 28 06-08-2012 07:43 PM
Adding Roof over existing Deck FrehouseRemdlin Decks & Fencing 1 04-17-2010 05:41 PM
