Metal Roof Cutting Options
Old 04-12-2007, 05:50 AM   #1
Tonkadad's Avatar
What are my options regarding cutting metal sheet roofing (24 gauge steel).
The particular type is called J-rib. I was hoping for some type of solution other than a circular saw. Is there any type of power shears, nibblers or "whatchamacallits" that follow the corrugations without making you feel like you are hanging on to a bucking horse?
thanks
Tonkadad is offline
Old 04-12-2007, 06:19 AM   #2
joasis's Avatar
Re: Metal Roof Cutting Options
We use Kett shears exclusively for straightline cuts and to cut across the material, a nibbler is the tool of choice. If you have a lot to do, buy a Hitachi nibbler, simply because the punch and dies will not break you...like $30 a set...my Miwaukee nibbler is about $116 a set for replacement dies, and the Hitachi cuts as fast.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 04-12-2007, 07:09 AM   #3
Tonkadad's Avatar
Originally Posted by joasis View Post
we use Kett shears exclusively for straightline cuts and to cut across the material, a nibbler is the tool of choice. If you have a lot to do, but a Hitachi nibbler, simply because the punch and dies will not break you...like $30 a set...my Miwaukee nibbler is about $116, and the Hitachi cuts as fast.
How fast do they cut metal?
thanks
Tonkadad is offline
Old 04-12-2007, 07:56 AM   #4
joasis's Avatar
It takes a nibbler maybe 15 seconds to cut 90 degrees across a sheet....technique has a lot to do with it. If you have only 90 degree cuts, or cutting for length, a field shear is the choice, we have one as well, but rarely use it since I order metal cut to length...we have to cut hips and valleys on angles, and shears are not practical, plus, you have to have a different one for every profile of metal. Check the pawn shops, you might find a nibbler cheap, or of you are not doing a lot, buy a cheap air operated one...should last for 10 or 15 cuts......a set of dies will last us about 250 feet os cutting 26 gauge...24 usually isn't any differnt as to life of the dies.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline
Old 04-12-2007, 08:22 AM   #5
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
If youre doing a lot of metal and would like sharp, clean cuts, look at
http://www.kleenkutter.com/
It is easily worth the price if youre doing a lot of metal.
http://www.roseroofing.net/
Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality!
Free roof inspections within 12 miles of our locale.
AaronB. is offline
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 01:30 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Metal Roof tied to a Shingle Roof? JackOfAllTrades Roofing 2 11-15-2005 12:00 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
