Metal Roof Chimney Flashing...
Old 08-06-2010, 10:01 AM   #1
Jambruins's Avatar
Trade: Professional Engineer
Rewards Points: 83
I am replacing my shingle roof with a metal roof. My valleys will have to extend to the edge of the roof (see the red lines in the picture) correct? I know with shingles the valley would stop at the side of the chimney but with a metal roof if I stopped the valley there it would dump water underneath my panel. Is my thinking correct? Thank you.
Moser Engineering
www.jmoserengineering.com
Jambruins is offline
Old 08-06-2010, 05:30 PM   #2
red_cedar's Avatar
Rewards Points: 1,250
Re: Metal Roof Chimney Flashing...
I would consider doing something with your chimney prior to any proposed metal roof. Once the metal goes on your more at a disadvantage with repairing the chimney.
The priniple is the same for metal as with shingles for that detail. It will rely on valley metal lapping onto the panel.
red_cedar is offline
Old 08-06-2010, 07:48 PM   #3
jmiller's Avatar
Trade: Roofing
Rewards Points: 1,002
Lose the cricket and save a lot of headache.
jmiller is offline
Old 08-06-2010, 10:07 PM   #4
copper magnet
seeyou's Avatar
Trade: custom metal fabrication
Rewards Points: 512
Yeah, what I was thinking. Hope the next guy can flash a little better.
seeyou is offline
Old 08-07-2010, 01:43 PM   #5
red_cedar's Avatar
Depending on your long term expectations and the type and kind of 'metal roof' you plan on, losing the cricket could cause standing water.
Standing water overall shortens the life of most materials.
Losing the criket would simplify the installation, no doubt of that, but the detail been referenced would be the same for either a pan or criket ( saddle ),
meaning 'overlapping'.
Old 08-07-2010, 04:00 PM   #6
PA woodbutcher's Avatar
Rewards Points: 1,000
No doubt the cricket will be a pain in the ass, but I would keep it, use the valley flashing, flash up the chimney using your own bend and counter flash it.
You can use pre bent end wall flashing against the chimney, but that stuff never lands where I want it to. A nice chimney job takes time.
When you rob Peter to pay Paul, chances are pretty good you will receive Paul's vote. Apparently the object of the game is to create more Pauls than Peters....What happens when the Peters can no longer support the Pauls? .
PA woodbutcher is offline
Old 08-07-2010, 09:12 PM   #7
red_cedar's Avatar
Valley flashing would just add more work and pieces to the job if the cricket remained. Ff the criket were to remain, get some flat stock and have it bent to the shape of each side and fit them. Thats how I do it. But others ways are good too.
I just read my original post . Its says valley flashing, what I meant is what I wrote here. Metal formed to fit the saddle with the valley portion and extended area lapping onto the panel or shingle below.
Old 08-08-2010, 05:05 PM   #8
mikebooth's Avatar
Trade: general contractor
Rewards Points: 25
Leave the cricket as is. Use 'W' valley in the 2 valleys, pitch break on lower side of chinmey, rake wall on the other 3 sides, for counter, cut brick and install reglet on all 4 sides. You can purchase these items at Metal Sales Inc. Hope this is of some help. You will have to work lower roofing panels in under the valley. That should be the only problem with this chimney.
mikebooth is offline
Old 08-08-2010, 05:53 PM   #9
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
get rid of the chimney
Tom Struble is offline
Old 08-08-2010, 10:29 PM   #10
tinner666's Avatar
A 20" chimney doesn't need a cricket. Start panels from both sides of the chimney, Make a pan with folded hem on top, a lock strip midway up the pan, about 12", and incorporate the pan into the roof panels on either side of the chimney. Put on your upper panels, and fill in the center panel(s).
Though a skyligh, the same principal applied.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 08-13-2010, 03:57 PM   #11
Gutter-Maker
Ghostbeard's Avatar
Trade: Gutter & Downspouts
Yea, with copper thats fine. Not Steel. Standing water and deflection moisture issues can cause "edge-Creep" and this detail will void most panel finish warranties.
I would find out first, from the panel supplier, what they recommend or what their CAD drawings show. to deflect any future problems back to them, if you occur one with there recommendation.
I believe they would reccomend a cricket, muck like they would any "curb" type application.
Ghostbeard is offline
Old 08-14-2010, 12:19 PM   #12
jmiller's Avatar
Trade: Roofing
Originally Posted by Ghostbeard View Post
I would find out first, from the panel supplier, what they recommend or what their CAD drawings show. ...
I've looked at the drawings for his panel mfgr (from past threads of his) and they don't have a curb detail. This stuff usually goes on barns, which tend to not have chimneys or curbs.
jmiller is offline
Old 08-14-2010, 01:45 PM   #13
Framer53's Avatar
Trade: Handyman
Rewards Points: 242
Seeing as the OP is in upstate New York, the cricket is an essential part of the roof. To loose it is to invite even more problems.
Framer53 is offline
Old 08-14-2010, 01:54 PM   #14
232323's Avatar
Trade: remodeling contractor
Rewards Points: 154
I agree with Tom...remove the brick chimney just below the roof sheathing. You or your heating contractor should be able to drop a metal liner into the existing chimney then you could use a conventional jack, storm collar & cap on the roof. If this is possible, it will look alot better and save you alot of work.
232323 is offline
Old 08-23-2010, 05:26 PM   #15
Don't Eat Yellow Snow!
English Roofer's Avatar
Trade: Pro Slater and Roofer
Rewards Points: 254
Just one question? who pointed the back of the chimney!!! Stevie Wonder!!
Cheers
' I can resist anything but temptation' Oscar Wilde
www.drroofing.co.uk
English Roofer is offline
The Following 2 Users Say Thank You to English Roofer For This Useful Post:
Framer53 (08-24-2010), seeyou (08-23-2010)
Old 08-23-2010, 05:34 PM   #16
Trade: siding
Rewards Points: 4
isn't she lovely?
seeyou (08-23-2010)
Old 08-24-2010, 08:34 AM   #17
Jambruins's Avatar
Rewards Points: 83
We bought the house from my wife's grandmother after her grandfather passed away. He was an old farmer who basically fixed things just enough so they worked so he could get back to the farm. I am not sure if he did the chimney but I am guessing he did. Every project I do around the house always has some unexpected surprises. Thanks for all the help.
Moser Engineering
Old 08-24-2010, 06:51 PM   #18
Roofing and Architectural
Renegade's Avatar
Trade: Roofing and Architectural Metals
Rewards Points: 708
Cheers
It's a coded msg. I think it says "F*** all you smart-ass roofers!"
I concur with tinner. Cricket is not necessary on that small a chimney. A pan will do fine.
Renegade is offline
Old 08-24-2010, 06:56 PM   #19
Renegade's Avatar
Rewards Points: 708
If I had the time I could show you a half dozen mfr's pan detail for this application. In fact walk down the street to Imetco's office and ask them.
Renegade is offline
The Following User Says Thank You to Renegade For This Useful Post:
seeyou (08-24-2010)
Old 01-12-2013, 09:24 AM   #20
ets80's Avatar
Trade: roofing
Rewards Points: 75
I concur, do you use a saddle behind skylights? A 20" chimney doesn't need a cricket. Start panels from both sides of the chimney, Make a pan with folded hem on top, Put on your upper panels, and fill in the center panel(s).
ets80 is offline
Um, what is flashing ??? theflynner Roofing 13 03-20-2011 06:33 PM
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 10:50 AM
NEW Roof Leak at the chimney !! TheLastDaze Roofing 18 01-29-2010 08:20 AM
Flat roof installers! Metal roof installers! cms_roofing Help Wanted or Looking For Work 0 10-01-2009 10:54 PM
Metal chimney replacement trade Construction 5 04-06-2009 01:35 PM
