Metal Cold Roof Question .....
Old 07-22-2007, 12:25 AM   #21
Expert Roofer
theroofinggod's Avatar
Trade: ROOFING/HOME IMPROVEMENTS-WINDOWS/SIDING/GUTTERING/COPPER WORK,ETC
Send a message via MSN to theroofinggod Send a message via Yahoo to theroofinggod
Re: Metal Cold Roof Question .....
I covered it,whether the space between is 3",or a regular attic
theroofinggod is offline
Old 07-22-2007, 09:00 AM   #22
Remodeler
Vermonster's Avatar
Trade: Remodel
Thank you god ... I know you did.
However, in the confines of my very specific topic and the snowy cold weather of my region, a "Cold Roof" is a very specific construction technique (double decking, etc), not just a roof that is cold on underside of the final finish material, whatever that might be: shingles. shakes. tiles, etc. Again, I am talking only about cold and snow because I'm not in Florida.
It is recognized by all trades associations as such. Just to mention one is the "Cold Roof Manual" by NTRMA and WSRCA. Here is a section:
My original question was very specific and simple: is the initially described metal roof installation a "Cold Roof" or not.
... factor it in and move on ...
Vermonster is offline
Old 07-22-2007, 09:27 AM   #23
tinner666's Avatar
Would the Structural Roof Panels on long cleats qualify? They're about 3/8" higher than the seams. The roof is then suspended above the roof deck.
First time I walked on one, not knowing about it, I though I was walking on a mattress.The 24ga. panels would sag to the deck where I stepped, then spring back up.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 07-22-2007, 09:32 AM   #24
K2's Avatar
No.
K2 is offline
Old 07-22-2007, 02:27 PM   #25
tinner666's Avatar
Ah Hah. I see. The answer, as I know it, is indeed 'No'.
Old 07-23-2007, 12:27 AM   #26
Expert Roofer
I`m in NY,BUT iSEE WHAT YOUR SAYING,NO BECAUSE IT`S PROTECTED BY INSULATION ONE SIDE
Old 07-23-2007, 07:12 AM   #27
Remodeler
Vermonster's Avatar
Trade: Remodel
great ... thanks a lot for that input. That's what my opinion was and now I got confirmation.
Thanks again.
Old 07-28-2007, 11:52 PM   #28
Expert Roofer
but as I think about it,w/no heat touching the insulation wouldn`t it all be the same temperature in the system?????
Old 09-02-2007, 09:17 PM   #29
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
You will, indeed, find a \national standard on cold roof assemblies vs. warm roof assemblies.
A cold roof assembly is a roof that has the roofing/waterproofing not in contact with the insulation (most shingle roofing is cold roofing, but not cool roofing)
A warm roof assembly is a roof assembly which has the insulation in direct contact with the roof deck, with no ventilated air space between the insulation and the roof deck. Am I making sense? Most commercial steel bar joist and corrugated deck with insulation atop are warm roofs.
Ed?
http://www.roseroofing.net/
Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality!
Free roof inspections within 12 miles of our locale.
AaronB. is offline
Old 09-05-2007, 07:16 AM   #30
Remodeler
Vermonster's Avatar
Trade: Remodel
that's precisely my understanding .........
Old 09-06-2007, 01:30 AM   #31
Expert Roofer
but if the insulation is above the cool roof space,wouldn`t they technically be no more than padding/firring strips ??
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 09:10 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Pricing question for Baltimore rowhome roof AmateursGuide Roofing 11 11-10-2005 03:15 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
